02-07-2023, 10:40 AM   #1
Pentax 645 Grip Battery Terminal & Holder
Picked up an untested/broken 645 and before I can test it, I'm in need of some battery grip repair advice.
Per my attached photo, you can see a battery terminal within the grip is bent, which appears to have been the source of the following problems. How can I bend the contact back? Pressing down on it does not work. Can I glue the bottom of the contact to the plastic grip holder?
Because that contact was lifted, someone put the battery tray in and the terminal basically ripped it to shreds/got stuck within the tray and ripped it to shreds upon removal.
Best way to repair this? See attached photo for the state of the battery tray, I know there are 3d printed versions out there but none of the battery contacts are clear with how to install on the 3d print version. How can I just get temporary battery connections? A detailed write up would be very appreciated.
IPhone 12  Photo
IPhone 12  Photo
02-07-2023, 02:39 PM   #2
Hi, I have a similar issue with my camera.
My holder is cracked but not broken, so the camera is fully usable for now.
Last week I asked a friend of mine to 3D print a new battery holder, not the usual 6xAA, but a converted version that will require 2x9V.
After a bit of sanding the piece fits well (there's a gap on the side but we will probaby print it again). In the next couple of days he will complete the wiring, I believe in the converted model is quite straight forward.
This is the link to the 3D part
There's also a traditional 6 battery version from the same user
I will keep you posted if you are intrested
02-07-2023, 06:28 PM   #3
Thanks! Actually since I posted this I 3D printed both AA & 9v battery trays on my printer in PETG. The AA fits perfectly and I got a pretty successful print going, the 9V tbd. I actually used a 9v to test the grip and it works though I have no lens on and my camera isn’t firing. Settings adjustments work. Anyway I think I know how to wire up the 9v in the battery tray, just need the parts. Disappointed that both models don’t have a bezel surface for the leatherette to be transferred. Seems that was lost in the design somewhere.
3d, 645d, 645z, battery, camera, contact, grip, grip battery, holder, medium format, pentax 645 grip, photo, repair, tray
Battery grip terminal cover K3 Pixeltrove Ask B&H Photo! 4 02-18-2022 10:14 AM
Wanted - Acquired: Battery Grip Terminal Cover for K-7, K-5, K-5 II, K-5 IIS, K-3 or K-3 II jhaji Sold Items 2 04-12-2020 01:24 AM
For Sale - Sold: [US] K7 Body & grip, K20 Body & grip, DA* 16-50 2.8, DA* 50-135 2.8, & more andyschwartz Sold Items 4 03-09-2010 10:23 PM
All times are GMT -7. The time now is 12:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
