I was wondering if the depth of field between two similar focal lengths for different formats would give different or similar DoF when used on the same camera. My experiment is limited and definately not scientific, but I tried to get an honest guideline for myself. So here is the setup:
Camera: 645z on a sturdy tripod.
Lens 1: M* P67 400mm f/4 lens with Pentax adapter to 645.
Lens 2: FA 645 400mm f/5.6
"Studio": Dining room table with house light overhead and house style background objects.
Camera settings:
ISO 100
Lens setting f/5.6 for shallow DoF and F/8 for deeper DoF
Shutter speed: P67 lens 2s for both pictures; P645 2s for f/5.6 and 4s for f/8. Dont ask me why the last pic was 4s, it is just the way it happened, I felt it was under exposed.
Object:
Pentax KP with 28-70mm lens.
Methodology:
Take two pictures with each lens, one at f/5.6 and one at f/8. When I changed from the 67 lens to the 645 lens I roughly measured the distance from the front of the lens to the object and moved the tripod forward to match the distance with the 67 lens distance.
Post editing is minimal and no cropping, but with WB set the same for all pictures. The distance from the camera to the object is slightly more than at the minimum focussing distance.
Both lenses were focussed manually on the name plate of the 28-70mm lens, using magnified live view.
The 67 lens pictures are at the top and the 645 lens pictures are at the bottom.
Observations:
1. The KP needs a good cleaning.
2. The magnification between the two lenses are not similar and the 67 lens magnifies slightly more despite being at the same distance. A rough measure in Photoshop indicates a difference of about 5%.
3. Comparing the blurring of the backgrounds between the 67 and 645 lenses, the 67 lens blurring is much more creamy.
Conclusion? Well I thought I would ask you guys to help draw some conclusions, because sometimes the obvious is incorrect.
