Originally posted by Shawn67 Tried checking under the rubber focus ring on the SMC Pentax 67 F4 45mm and there are no adjustment screws for the infinity stop so that must be done in a different manor on this lens.
To give a sense of what I am talking about.
This is at 100% zoom in with the image on the right focused at 'infinity' on the lens, left is focused like this:
This position is just about the same as what I found on the Pentax 6x7 optically using another camera as a collimator. The suggests the adapter on the 645D is the correct thickness.
A 45mm at f4 on the 645D focused at infinity should have everything from about 44' and on in focus. At 'infinity' on the lens nothing is in focus.
Pse let me know if I understand correctly:
1) The lens focus correctly? Near objects as well as far objects can be focused correctly?
2) The distance scale on the lens does not align with the actual distance?
3) when the focus ring is turned towards the infinity mark then the lens is focused beyond infinity, which is overrun?
If I am correct with the above I would suggest to use the lens as is. In my experience I have never found a lens with an accurate distance scale, unless it is a high end film/video lens where focus is set by measuring the distance from camera to the subject with a tape and dial in the lens focus on the distance scale accordingly.
In photography I have never seen that used as a means of focus, mainly because the scales on the lenses are too compressed to read accurately, focus is rather done visually, either by a human or camera, still visually. The only practical use I have found for the scales are to get an estimate of the depth of field. But since we can do a visual check of the depth of field since the 80's and before, which is in any way more accurate if checked visually, I don't see much practical use of the distance scales.
Hope this helps. I would still recommend to get a Bahtinov filter/screen, then you can do the same exercise on a bright star, or the moon and you may see a different result on the distance scale.
Hope this helps.
