Originally posted by mattb123 on the 32-64 but I think I'm going to get rid of that lens (and keep the 35-70 which is smaller)
When I saw that you first bought the 32-64, I was already anticipating that you would sooner or later sell it and keep the 35-70.
Originally posted by mattb123 I'm tempted to get 82mm filter(s) and step up/down rings but that may not be the best solution.
I went down your route with circular and square filters. Initially I used circular filters, then I acquired a cokin 100mm square system which cause lots of vignetting from 24mm (FF) and wider. Then I acquired a Nisi/Haida 150mm square system for the 15-30, plus adapter rings to 82 and 77. Then I acquired a 67mm circular kit + 1 67-62mm ring that fit on both DFA21 and 28-105, which doesn't take much space in camera bag. The problem with square filters is that I got bored of having to carry one or two bags with large filter holders just for the occasional picture that requires using a filter, too much hardware to carry around to just a few pictures taken. Whereas intentionally limiting myself to some key circular filters (1 CPOL + 3 ND), is actually cheaper and much more compact. For the choice of the square filters, the wide angle end and the gap between filter and lens front is what define the minimum size of the filter, rather than the diameter of the lens thread. Anyway, IMO, the critical thing is the widest angle lens you want to use the filters on, so I would select a filters kit that work for the 20-35, and than have a couple of rings to adapt on the other lenses. If you go for a square filter system, I would predict that you will have vignetting problems if you use a 100mm square filter on your 20-35, 130mm square (Cokin) would be the right size, or 150mm square from other brands. If I was buying again from scratch , I'd buy the 130mm cokin system to cover all lenses.
To summarize: If you plan to use your filters on the 20-35, I would recommend either a circular filter kit 82mm with step down rings to other lenses OR a square filter system at 130mm or larger.
---------- Post added 11-05-23 at 07:25 ----------
Originally posted by Roadboat24 I started with the Cokin P filters "84mm". They will vignette on wider lenses. I use K&F 100mm on lenses down to 15mm, but that's getting really close. If you use step rings, it sees the holder earlier.
Exactly. That's important and a good thing to be aware of.
