Originally posted by ProfessorBuzz Tough question.
Dialing up the "gain" in post is likely just multiplying up the pixel values, so that will dial up the noise as well as signal; and I think you can see the histogram compression going on.
Increasing ISO (which increases the on-chip gain selected in the CMOS APS sensor) will bring up the low signal levels.
Say you have low in-camera gain, so the darkest areas barely register. No amount of post gain will bring out detail that isn't detected. (Put another way: Multiply 0 x 10000% post gain, you still get 0).
Dialing up the sensor's gain may get you a few more ADU counts in these darker areas; then you can tease out more detail.
In science cameras, we'll do "stacking" which co-adds repeated images; signal will rise in proportion to sqrt(noise) so it is more effective.
I see your point, although the signal value registered in the individual pixel would still be the same. Whether the gain is applied in camera during the analog to digital conversion, or if you apply the gain in post, neither of these two scenarios change the number of photons received which resulted in the signal voltage registered in the pixel. Stacking the signal is obviously different, since you are adding photons which in concept it will be the same as a longer exposure. (I know the practicality of stacking versus long exposure determines which is the best solution, but I am trying to just consider the process from sensor onwards).
What I am trying to determine is for the same signal strength captured on sensor, is there an advantage to let the camera add the gain by simulating a higher ISO value, or is the post processing software like ACR better equiped to add the gain? My gut feel is that in camera is always better, but that may not be true anymore. Post software has the potential to have an advantage in that it has a lot more processing power available (our computers for example) and new concepts can be applied and rolled out easier than with firmware updates to a camera, potentially resulting in a better image quality.
I suppose the nutshell question would be if the potential of the post software is real or even possible. Perhaps the answer is also camera dependant.
Maybe someone has already gone down this path with answers, which will be very helpful if shared.
I'll take a few more shots with the 645z and share the results.
