01-20-2009, 12:58 AM   #1
troyz's Avatar
How should I inspect a used 645??
I have no medium format experience, but I like 35mm film and I'm toying with the idea of picking up a used Pentax 645 (original), mostly for scenic photography.
I know how to inspect a 35mm body -- what else do I need to know about inspecting a 645? Are there any particular problems I should look out for?
Thanks.
01-22-2009, 06:40 AM   #2
Buffy's Avatar
Re: How should I inspect a used 645??
Inspect it the same way you would a 35mm body. In most respects, a 645 is essentially the same, just larger. One significant difference is that the film holders (inserts) are removable, so take the time to inspect those.
01-25-2009, 06:56 PM   #3
Also take a look at the mirror. If you see a lot of black spots on it the silver is flaking off and a dealer in the local area told me you could stop the process, but not repiar it and that the mirror couldn't be replaced.
If it's too bad it could effect the meter since in the no flash mode the camera meters off the mirror. I went from a 35mm to a 645 and it was a great step for me.
Cheers,
Scott
01-27-2009, 06:03 PM   #4
troyz's Avatar
Thank you both for your advice.
I just missed out on a 645 that was available locally but it's good to know what to look for the next time.
01-29-2009, 07:54 AM   #5
Buffy's Avatar
645s
You know, even if you don't plan to use autofocus, I'd think about getting the 645N instead of the original. The 645N (and 645NII) have more traditional dial controls instead of the push buttons. Just food for thought.
35mm, camera, medium format
About to go to a store to inspect a used 77mm 1.8 Limited. What should I look for? uchinakuri Pentax SLR Lens Discussion 3 07-06-2010 10:54 AM
How to inspect used lens? caffix Troubleshooting and Beginner Help 6 05-20-2009 05:19 PM
Tips on how to inspect K200D please! esman7 Pentax DSLR Discussion 4 12-31-2008 09:44 AM
All times are GMT -7. The time now is 03:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
