03-12-2009, 07:34 PM   #1
6x7 to digital?
Hi,
My husband has a 6x7 that his Dad gave him. Over the years, we've acquired 45, 105 and 200mm lens.
Is there a pentax digital body that can fit these lenses? The 6X7 is always having mirror problems..
It would be great to use the lenses on a digital body.
(I posted this question already on the general photography forum, but this is a probably a appropriate forum)
Thanks, Isabel
03-12-2009, 07:36 PM   #2
there's an adapter you can use to mount it on a K-mount body
03-12-2009, 07:48 PM   #3
QuoteOriginally posted by k100d Quote
Is there a k-mount body that you recommend?
03-12-2009, 08:17 PM   #4
Ole
Ole's Avatar
QuoteOriginally posted by isabel Quote
Pentax K2000, K200D, K10D and K20D! The K10D is discontinued but could be available at a good price.
The K2000 is easiest to use if you're new to DSLR's, but still has a lot of advanced features so that it can grow with you.
03-12-2009, 08:36 PM   #5
RawheaD's Avatar
Frankly, I have a feeling that your husband would be mildly-to-terribly let down by the double crop factor of any Pentax digital body (MF->FF->APS-C). E.g, the 45 is a super wide angle on the 67, on a K20D, it's going to look like a medium tele.
And the 645D that may or may not come out within the next couple of years is going to cost over 10K for sure.
If you're really serious about using Pentax MF lens on a digital body and cannot wait a year or two and/or cannot justify the expense, then I suggest you at least consider a full frame dSLR. I'm sure there are Pentax 67 to any one of the three FF mounts (Nikon F, Canon EF, Sony Alpha). i'd recommend the alpha if, for nothing else, the built-is optical image stabilizer. my2c.
03-12-2009, 08:36 PM   #6
TomE's Avatar
Personally I would pick up a newer model, a 67 instead of a 6x7 and you will not have any mirror problems like they had with the first versions, the 6x7.
I find the 67 lenses to be extremely heavy on my K10D/K20D and kind of a pain to use and my 645 lenses are not much better. You could wait to see what Pentax is doing with the 645 digital camera they have had in the works for quite a while now, but I expect it will be fairly expensive.
Tom
03-14-2009, 07:17 PM   #7
Thanks, for all your expert suggestions, I'll look into the dSLRs, as well as the 67.
Isabel
03-15-2009, 10:29 PM   #8
Jewelltrail's Avatar
Perhaps this will be of some help to you...
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/49428-medium-f...20-sensor.html
03-20-2009, 04:23 PM   #9
You can also get a Nikon or Canon FF body. There are adapters that let you mount the 67 lenses on them.
6x7, body, camera, forum, lenses, medium format
Pentax Medium Format Resources: 645 & 6x7 Cameras and Lenses, 645 & 6x7 Accessories Adam Pentax Medium Format 9 02-12-2017 03:38 AM
6x7 ad from '73 Nesster Pentax Medium Format 20 09-14-2009 04:07 PM
switching to a 6X7 digital body isabel Pentax Medium Format 16 07-21-2009 08:58 PM
Digital Filters in Pentax Digital Camera Utility 4? lawsonstone Digital Processing, Software, and Printing 0 07-19-2009 04:44 PM
are 6x7 lenses good on digital bodies? vagrant10 Pentax SLR Lens Discussion 5 01-18-2009 03:04 PM
All times are GMT -7. The time now is 11:52 PM. | See also: NikonForums.com, part of our network of photo forums!
