03-17-2009, 11:38 AM   #1
mk07138's Avatar
6x7 MLU mirror and shutter stuck open
Ok, I tried using the search function to see if this has ever cropped up before but it doesn't seem to get along well with me and I found nothing.
Ok, here is my issue. I went ahead and purchased a used 6x7 with Mirror Lock Up. When I got the body and checked it out I found that the shutter was completely open and the mirror was stuck in the locked up position. After some fiddling everything snapped back down and I went about examining it some more. I opened the film back and set it so that the shutter would fire without any film. Everything worked the first time I cocked it, but on the second time the mirror stuck up and the shutter stayed open. I can't figure out how to get everything to reset. Any suggestions on this? Is this body in need of serious repair or is this normal for trying to fire the shutter more than once in a row with no film loaded?
Thanks for any help you all can give.
Morgan
03-17-2009, 02:51 PM   #2
Try installing a new battery, check the contacts to make sure they're clean.
03-17-2009, 03:07 PM   #3
mk07138's Avatar
Thanks, that was it, I had put the new battery in there so I didn't realize that was the issue. When I took the battery out this afternoon and put it back in everything worked fine, cleaned the contacts and haven't had an issue since. Already ran my first roll of film through it too. Looking forward to seeing the results.
6x7, body, camera, film, fire, medium format, mirror, shutter, time
Another 6x7 with shutter and mirror stuck open Denverdad Pentax Medium Format 17 11-10-2016 02:14 AM
Is this a shutter problem? (6x7 with MLU) Denverdad Pentax Medium Format 8 02-04-2010 06:50 AM
6X7 mirror/shutter slap Gooshin Pentax Medium Format 21 01-15-2010 11:31 PM
Pentax 6x7 non MLU Mark S. Pentax SLR Lens Discussion 0 11-16-2008 10:42 AM
All times are GMT -7. The time now is 06:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
