Originally posted by RiceHigh In fact, we can forget well about the actual sensor size, the ratio of the two standard lenses, i.e. 75mm/55mm tells well about the crop factor, which is 1.36X.
Originally posted by Sean Nelson Only if the two lenses have the same field of view (the 75mm on film vs. the 55mm on the 645D).
The 55mm lens being touted as what would ship with the 645D at this point really doesn't tell us squat about the sensor.
But for grins:
75mm on a 645/N/Nii yields an AOV of 50deg and a FOV of 9.33ft (7.47x5.6ft) from 10ft.
In order to make a
match you'd need a 41x30.8mm sensor (49.99deg / 9.32ft).
The closest I'm aware of is the Kodak KAF-31600 31.6MP sensor at 44.2x33.1mm and would yield 53.3deg AOV and 10.04ft FOV.
Then again, a 55mm lens on a KAF-39000 or a KAF-50100 (both 49.1x36.8mm) would offer 58.3deg AOV & 11.16ft FOV, which is pretty darn close (theoretically) to the average macular vision of the human eyeball.
So there ya go, depending on what spin to throw at it, a 55mm "kit" lens
could mean anywhere from a "new" 41x31mm sensor all the way up to Kodak's 50.1MP beast.
