Originally posted by MJB DIGITAL Exploitation is exactly what I'm up to.
I have another question: At, for example 150mm and f/4, would the DOF be thinner on a larger format if you were comparing to 35mm or aps-c formats?
for reference:
Online Depth of Field Calculator
proposition:
you are standing in spot X, shooting a subject 15 feet away, with 150mm lens @ F4 using your 645
1. standing in the same spot, to achieve the same field of view on a FF camera, you would need to use a focal length of 100mm, and to achieve the same depth of field, you would need to set your aperture value between 2.5 and 2.8
2. standing in the same spot, to achieve the same field of view on a APS-C camera, you would need to use a focal length of 66mm, and to achieve the same depth of field, you would need to set your aperture value between 1.2 and 1.4 (good luck)
(also, as a tid bit, if you wanted to replicate the field of view and dpeth of field capabilities of a 150-200 dollar FA 75mm F2.8 lens for the 645, on APS-C, you would need a 33mm F1.0 lens (well, actually, somewhere around 0.90 ish), heh..
also, using a 45mm F2.8 lens on a 645, shooting something 15 feet away, can give you a DOF coridor of only 9 feet!
to replicate that on APS-C, you need an F1.0 20mm lens, which doesnt exist.
the more readily available 21 F3.2, gives you a depth of field corridor of 80+ feet when shooting something 15 feet away, ie, everything is pretty much in focus.
this is the (in my opinion) true power of the medium format, the ability to shoot wide, encompasing photos, while mainting a thin depth of field, seperating your subject from the background.
the resolution and all that stuff is secondary.
