09-08-2009, 12:59 PM   #1
Swift1's Avatar
67 MLU Question.
First of all, I should introduce myself. I am new here but I have been reading this forum for months and have found the forum and the lens reviews to be an indispencable resource.
I purchased a K10D a year and a half ago and since then have developed a serious case of CBA and LBA. I now own 15 lenses, 6 bodies and all kinds of accessories.
My most recent acquisition is a 67 kit. After purchasing the kit I sent it to a reputable repair shop for a full CLA and to have the pressure plate and winding mechanism repaired.
Since getting it back, I have run 2 rolls of film through it using MLU on 90% of the shots and I have randomly had the problem of the mirror getting stuck on its way up.
I then have to press the little black button below the shutter release and it will finish going up.
The battery is brand new.
Is this a common problem?
Any help will be much appreciated,
Swift1
09-08-2009, 07:51 PM   #2
Hi Swift1,
Sometimes when a tech must repair many area's of a unit each function is checked maybe once or twice. If the tech is aware of the type of problem incountered by the user this section can be tested several times and adjusted to work each time used. If might be a case where you need to return it for further testing. The shutter release soleniod is not working correctly.
Eric
camera, forum, kit, medium format, mlu
Mirror up (MLU) on the K7 - Who's using that ... jpzk Pentax DSLR Discussion 16 09-18-2010 07:09 PM
Kx - MLU w/ bracketing? bnorikane Pentax DSLR Discussion 8 12-24-2009 12:29 PM
what to do if 1.01 doesn't fix MLU hotpixels on K20D? kenyee Pentax DSLR Discussion 6 01-08-2009 09:28 AM
Pentax 6x7 non MLU Mark S. Pentax SLR Lens Discussion 0 11-16-2008 10:42 AM
SR and MLU awetmore Pentax DSLR Discussion 9 06-05-2007 11:14 AM
All times are GMT -7. The time now is 07:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
