Originally posted by Swift1 Thanks guys, but battery is new, tried remounting lens, tried changing lenses, and still nothing.
Swift1
I once had a cable release screwed into my 67's shutter button. I set the camera on the ground. I went to pick it up and I inadvertently had my foot on the other end of the cable release. The force bent the shutter button assembly slightly and broke off the tip of my shutter cable.
My shutter wouldn't work after that as you describe. I'd push the button and nothing. I took a flat-tip screw driver and wrapped tape around it. I wedged it between the body and the shutter assembly base. I gently forced the shutter button in the direction away from the prism. It started to work again. Every now and then it stops working. I repeat the process and she is good to go.
Don't use much force. Give that a try if you're desperate.
