11-11-2009, 02:03 PM   #31
OK, I've done it. I ordered this: 77mm Paddle Flower Camera Lens Hood Sun Shade Black - eBay (item 390087434678 end time Nov-26-09 07:47:56 PST)
It's inexpensive enough ($7.61 USD), and shouldn't vignette. If it does, no big loss. I'll try it with step-down rings on the other lenses as well. I'll post results after I get the hood and process test shots.
Thank you all for your thoughts on this.
11-11-2009, 04:00 PM   #32
Ratmagiclady's Avatar
Cool. I think you're at least safe from vignetting with that: those things are usually made for (any number of unspecified) wide-zooms and if anything are going to be quite short. Better than running around with a bare lens, though.
P.S: Step-*down?* What do you have that's bigger than 77mm?
11-12-2009, 05:25 AM   #33
Mike, it looks like you are onto the right solution here. The filter looks very much like the one for the Pentax 14mm f/2.8, which is a 90 degree field of view - like the 645 A 35mm f/3.5 - except you have found one that attached via the filter thread. I was thinking of buying the one for the 14mm and then gluing on a stepping ring or a blank 77mm filter.
Let us know how it works.
11-12-2009, 07:41 AM   #34
QuoteOriginally posted by Ratmagiclady Quote
I guess stepping up or down depends on how you look at it. I figure, since I'll be using this hood, meant for a 77mm thread, on a lens with a thread of 67mm, or 58mm, it'll be stepping down. Another matter of perspective I suppose.
11-12-2009, 08:01 AM   #35
QuoteOriginally posted by yurihuta Quote
Will do Yuri. I'll see if I can improve on this, taken with the FA 45/2.8 on Provia:
11-12-2009, 02:50 PM   #36
Pål Jensen's Avatar
QuoteOriginally posted by iCrop Quote
The FA 45/2.8 is one of the worst lenses Pentax have made. It flares more than most zooms(!), as you can see, and is a mediocre performer....
11-12-2009, 07:15 PM   #37
For ease of shopping, the terms make it a step-up ring when it's a smaller lens thread going up to a bigger filter, and a step down when you're putting a smaller filter on a lens with a bigger thread: the size of the lens thread comes first, and the filter size it adapts to is second.
11-13-2009, 08:11 AM   #38
QuoteOriginally posted by Pål Jensen Quote
Pål, thanks for the reply. Since we're very limited in our choices for wide angle lenses on the 645, which do you prefer?
11-13-2009, 08:13 AM   #39
Thanks, step-up it is...
11-16-2009, 04:32 PM   #40
So, the hood arrived. Unfortunately, the plastic threads have a tendency to cross-thread on the lens. Given that the lens was used, but new to me, I tried a filter on it, and that threaded on smoothly. I suspect the thread pitch on the hood may be off, but I haven't checked it yet. If I force it, I can get it threaded on by about 1 thread, and it holds because the hood is so light, but if bumped, it will probably fall off. I'll still test to see if there is any vignetting on film. There's none detectable in the viewfinder. Since the hood was only $7.61 it's no big loss, but disappointing none the less.
I'll continue to look for other hoods and post as appropriate.
11-16-2009, 04:37 PM   #41
Lesson Learned
Right you are! I had a DH! moment when the rings arrived and didn't work. Thank you for the education.
11-16-2009, 08:42 PM   #42
Sarright, Icrop. It sounds as it you may just have gotten a hood with badly-cast or machined threads, there really should be only one pitch you'll find on any such accessory. (The lens and hood are both 77mm size? And the hood will neither thread onto the filter nor the lens properly? Sometimes the front threads of a filter are shallow, and those of a cheap hood may have a lot of 'blank' on them. So that may cause some problems.)
Probably, if everything's the right size, the hood's just badly made.
If what Pal says about that lens and flare is true, it could be worth a bit of a hood-hunt to get the best you can out of it.
One could probably make a decent 'custom' hood with a flowery thing like that (or a wide angle hood, and adding empty filter rings (if you can get any) until it starts to vignette on you.
Picking a random Ebay link, you might try something shaped like this: http://http://cgi.ebay.com/77mm-Wide-Angle-Metal-Lens-Hood-for-Canon-Nikon-etc_W0QQitemZ110434531805QQcmdZViewItemQQptZLens_Accessories?hash=item19b66939dd
A hood shaped like this has a big diameter, if you're willing to deal with that, (It's not convenient for storage,) but it means you have more hoosdey goodness in several ways without as much risk of vignetting.
You can also get things shaped like this: http://http://cgi.ebay.com/New-Metal-Wide-Angle-77mm-Screw-in-Lens-Hood_W0QQ...item19b4e6ec0b
Skinny, but about as convenient for storage as it'll get: I have a few hoods made by this company, including one much like this which I replace with a rubbery one when I am going to be walking around in the bright with my big ol' Canon zoom. (Which lens has many virtues, but flare-proofness is not one of them) The skinny metal one fits in a bag. The big rubber one actually keeps rain and snow and stray light off pretty well.
I generally consider petal hoods to be not worth the trouble if they aren't designed to be matched to your lens: in general, they'll make em shorter at the corners than they have to be, so the right sized round one will serve as well.
11-18-2009, 01:54 PM   #43
What I may do is get an old filter ring and mount the petal hood on it permanently. If that doesn't work I'll try the skinny round hood you mention. I've seen a few metal versions of those around.
11-19-2009, 09:27 PM   #44
Hood Page
Hi Group,
I've set up a page listing specs on most of the P645 A and FA lens. Hoods are in the last column.
Instead of using an old filter, I made a flower hood for the A 35/3.5 out of a Cokin P adapter for 77mm and hot glued a plastic bowl to it, cut it out and painted it black. The official hood is a sort of floppy rubber thing that I don't really think works much at all. I sold it off on OBoy a long time ago. It doesn't really extend that much past the lens and is too small to exclude a large portion of brightness.
Warren
PS, If you see any errors on my page, please send me a correction.
11-19-2009, 09:28 PM   #45
Whoops
This might help.
http://www.120scan.us/p/eq/P645lens.html
angle lens, camera, filter, hoods, lenses, medium format, smcp-fa
Best wide angle lens A.M.92 Pentax SLR Lens Discussion 8 06-29-2010 02:21 PM
looking for a wide angle lens lazyeye Pentax SLR Lens Discussion 8 05-12-2009 02:51 PM
Wide angle lens? needtime2scrap Pentax SLR Lens Discussion 12 02-25-2009 09:29 PM
Lens hoods for Wide-Angle Trawlerman Pentax SLR Lens Discussion 4 04-28-2008 09:20 AM
Wide Angle Lens Toshi Pentax SLR Lens Discussion 6 09-26-2006 03:04 AM
All times are GMT -7. The time now is 02:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
