04-15-2010, 07:25 AM   #46
Found One
OK, it took a while, and this is what I've settled on, found it at Adorama for $9.95: WAMLH77 Adorama 77mm Wide Angle Metal Lens Hood. It doesn't deform like the rubber hoods do, and I had terrible vignetting with the plastic petal shaped hood. The paint job on this hood is not the best. I may sand it down and repaint it.
The first photo below is what the hood looks like on the 35mm lens.
The second photo was taken with the 645N and the hood on the SMCP-A 645 35/3.5. I'm sure there would be flair if the hood wasn't on.
04-16-2010, 06:56 PM   #47
I managed to find an original Pentax hood for my A 35mm - it is a collapsible rubber type hood. If you want, I could measure it to give you an idea how close the one you have is. Let me know via PM.
04-16-2010, 11:55 PM   #48
Good job in finding this hood. I had the original A 35mm hood and it didn't do to much for me. Just a floppy piece of rubber. But yours looks very subbstantial and could block a lot of light.
And the location?? the entrance to Buckskin Gulch?
04-19-2010, 08:28 AM   #49
QuoteOriginally posted by yurihuta Quote
Yuri, thanks for the offer, but it would be more trouble than it's worth. This is my forth hood in this search. It doesn't vignette like the others, or deform like the rubber one I tried. A mm or three difference might prompt me to continue the search and I'm sick of looking for hoods at this point. I just want to take photos.
04-19-2010, 08:43 AM   #50
QuoteOriginally posted by wkkato Quote
Close, good eye. They were taken last month (March, 2010) just above and to the east of The Wave. The photo with the 645 is looking southwest, with Ektachrome 100VS. It's the original low res scan from the lab that does my film processing. No adjustments, hence the somewhat over-saturated look.
04-19-2010, 11:06 AM   #51
Ratmagiclady's Avatar
Incidentally, for anyone still looking, I like S&W brand metal hoods, (there's a seller on Ebay with darn near everything they make) The wide ones will generally be more compact, (not as big in diameter but not as deep, either: this makes them easier to deal with as well as carry around, but apart from that not quite as protective. Still, very good if you'd otherwise leave the lens at home, etc. Otherwise, something like what you've got, there would be my preference.)
I do like them in general, though, this brand, (at least if I can't have round hard plastic, but that's hit-or-miss, ) ...they're usually pretty nice of finish. Very occasionally, there'll be one that the black coating won't hold on, (I've heard of one or two cases of such, but I've used them for years, myself without finding such flaws, but I believe those who do: (I don't really baby things excessively: neither, though, do I 'use gear hard:' just a *lot:* knocks and hard abrasions and other things that might do violence to a finish are quite rare around me, but things see lots of carry and casual wear. I presume that some reports just an occasional rare problem with a batch of coating, and that it almost always has gone right. It's not B&W or Heliopan, but it's great, especially for lenses that wouldn't rate a fifty dollar hood, anyway. )
Occasionally, they'll be a little inconsistent in appearance, (not so most would notice,) but all in all very nice for the price.
Wides and hoods are always harder to fit, I think, but there's another option if anyone's interested. (I've actually got a wide 77 from this company, for my big Sigma 28, (Was shipped the wrong one, and sort of bought-at-discount instead of sending it back while the proper one came. On this lens it's a token hood at best, particularly on crop, but it's better than walking around with a big 'naked' lens. And also compact and takes an easy-enough cap. )
I usually don't mind at all if a hood flares out like the one pictured, (more protection,) but sometimes with a bigger diameter lens, that's majorly in the way when it comes to carry.
Just a few thoughts.
04-21-2010, 06:32 AM   #52
Here's a view from the same location, only looking east. Still trying to get the color correction dialed in on the Ektachrome.
PENTAX 654N  Photo
04-21-2010, 07:36 AM   #53
Might be the scan or the lens or the hood - are you getting a little vignetting in the top left corner?
04-21-2010, 08:02 AM   #54
I'm sure it's post processing artifact. It's gone from (scanned) TIFF to PSD back to TIFF then JPG. It looks good printed out at 18x24 as a PSD, but converting that for the web sends it right into the toilet... I'll have to work on my 'scanning for the web technique'.
04-21-2010, 08:15 AM   #55
What are you scanning your film with again?
QuoteOriginally posted by iCrop Quote
04-21-2010, 09:27 AM   #56
Epson V750. Scans are pretty sharp with a BetterScanning film holder and ANR glass. I get good color from EpsonScan but don't like its batch mode. I get poor colors from SilverFast, but like its batch mode. Trying Vuescan next... Just trying not to fall off my learning curve.
What are you using, and are you happy with it?
04-22-2010, 06:05 AM   #57
Are you sure it's due to digital processing? Because I am about to go for the same hood—as well as the 58mm one for my 2.8/55mm—since I cannot find the original hood anywhere. And if it was never any good, as wkkato suggests, I'll try this one.
I prefer metal or plastic hoods over rubber, too. Don't mind plastic, as some do, my original hood for the M-series 2/85mm is still without fault after 20 years of use.
04-22-2010, 06:10 AM   #58
And now that I'm at it: how long should the lens hood be for the 120mm Macro (MF)? I found one on Adorama that would seem to be smallish: MLH67 Adorama 67mm Metal Lens Hood
04-22-2010, 07:23 AM   #59
QuoteOriginally posted by Smolk Quote
Yeah, I'm pretty sure that's a good deal shorter than it needs to be. Tolerance for vignetting seems to get way better as focal lengths past 'normal.' With the broader hoods, you can probably go as deep as you can find without much worry (Cause I don't think those come terribly deep to begin with, but you could do better.) If the lens' front element itself isn't close to the edge of the lens barrel, that's a good amount of clearance for a deeper hood of that style, in general.
04-22-2010, 07:27 AM   #60
I just found an original metal hood for the 120mm, and ordered it right away! Thanks for your reply, however, it is useful to know this.
angle lens, camera, filter, hoods, lenses, medium format, smcp-fa
Best wide angle lens A.M.92 Pentax SLR Lens Discussion 8 06-29-2010 02:21 PM
looking for a wide angle lens lazyeye Pentax SLR Lens Discussion 8 05-12-2009 02:51 PM
Wide angle lens? needtime2scrap Pentax SLR Lens Discussion 12 02-25-2009 09:29 PM
Lens hoods for Wide-Angle Trawlerman Pentax SLR Lens Discussion 4 04-28-2008 09:20 AM
Wide Angle Lens Toshi Pentax SLR Lens Discussion 6 09-26-2006 03:04 AM
All times are GMT -7. The time now is 03:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
