If you are attaching to an Arca-Swiss style system, the only L-bracket now being made as far as I can tell is the Kirk BL-67II. At least when I was searching for one a few months ago, that was all I could find (but I will happily stand corrected if there is something else out there!)
According to Kirk the BL-67II is only for the 6x7II, but after reading several reports that it was actually compatible with the older bodies as well, I took the chance and bought one for my 6x7. Happily I can say that it fits fine, with the only slight annoyance being that you have to remove the bracket to change the battery. There are no other interferences or incompatibilities, although when I first installed it, I thought there was - it seemed like I couldn't open the back. But I quickly found that if I biased the bracket in one direction when mounting it (using the slight slop in the mounting hole) then there is just enough clearance to open and close the back.
The one think I should point out about the bracket is that when shooting in vertical orientation there is a noticeable camera flex or vibration when the shutter fires. This hasn't translated into images softness in my limited number of shots so far (I'm only on my 5th roll or so). But then again I use MLU for every shot, so I can't make any claims about what you would get without using MLU. In any event I do wish they had made the bend area of the bracket beefier.
There is apparently an older version of this bracket too, as I saw one once on eBay. I don't know for sure if it was for the 67II or the older bodies (or both). The thing looked both simpler and beefier than the newer version (particularly in the bend area if I recall correctly). So it might be worth looking into if you can find one.
