11-11-2009, 07:48 AM   #1
StephenMerola's Avatar
FA 80-160mm question
Does anyone have this lens? I don't have my adapter yet, or a 645 so I cannot test it. I bought it from Adorama (E-) for $179.00!!!
My question is this: On my lens, which appears to be in very nice condition (aside from some dust), the lens barrel around the part that extends rotates. Is this normal? Also, what is the purpose of exposed rubber ring that can be rotated. There is an opening in the barrel where you can see it.
I appreciate your help. I cannot wait to get my adapter. It is on backorder right now from BH Photo/Video. I am assuming since Pentax shows it for sale on their site I should be able to get it eventually.
11-11-2009, 09:21 AM   #2
D W
Perhaps a photo with arrows pointing to what you are asking about would be helpful.
11-11-2009, 09:29 AM   #3
Ha. I was thinking that when I was typing my question. I will try to do that tonight. I does not seem that there is anything wrong with the lens, but since I don't have a manual I have no idea what is going on.
11-12-2009, 05:20 AM   #4
I have this lens and it is a wonderful piece of equipment. If I understand your description correctly, the piece that rotates is at the very front of the lens and is used to rotate filters - e.g. polarizers - while the lens hood is on.
11-12-2009, 07:40 AM   #5
The entire extending part of the barrel rotates. I hope this is normal, but it was so cheap I would probably keep it as long as everything else works. I will try to post some photos tonight with colorful arrows pointing to what i am trying to describe.
Thanks yurihuta for the info.
11-12-2009, 02:48 PM   #6
Pål Jensen's Avatar
QuoteOriginally posted by StephenMerola Quote
Are you sure it is not the A 80-160 you have? I believe that the front tubus of this lens rotates; not sure about the FA version....
11-12-2009, 08:10 PM   #7
I am certain it is the FA.
Ok, here is the photo. Both indicated sections rotate either way. The top area rotates independently of the other section. However, if the bottom ring is rotated clockwise it will move the top barrel section with it, but it won't move the upper barrel section if you move the bottom ring counter-clockwise. Nothing affects the actual glass. So I am wondering if this is proper or if the barrel is only supposed to move by rotating the lower ring.
11-12-2009, 11:28 PM   #8
D W
Ahhhh picture worth 1000 words. The bottom ring is used to rotate the filter when the hood is mounted on the bayonet and you can't get to the filter. A window on the hood does not work in this case for the front ring moves in and out.
The two are supposed to rotate in sync. If one rotates and the other doesn't then there is something wrong.
11-13-2009, 07:26 AM   #9
I did notice that 2 extremely small screws are missing. One in the window below the lower arroe and one just up and to the left of the lower arrow....you can actually see the whole if you look closely. However, all other screws are intact so this may not be the problem. I think for $179.00 I will keep it since it sorta works.
11-13-2009, 07:34 AM   #10
I guess it would not hurt to make sure all exposed screws are tight, and replace the missing screws as well. I dont know if that will solve the issue though.
11-13-2009, 04:51 PM   #11
Stephen, if you send me a photo of where the screws are missing, I can check my copy of this lens as a comparison.
11-13-2009, 07:06 PM   #12
Ok here are some photos. I think the 3rd one is the most telling. It looks like there are 2 holes that are not lined up correctly and require a screw, just like the hole above it. And when you rotate the loose barrel part you can see the 2 holes line up. But I would think the top hole would hold that together. I just know know enough about lenses. I guess I could try to move the top screw to the bottom hole and try to see if that does anything.
11-13-2009, 09:58 PM   #13
ARCASIA's Avatar
Hi Steve,
I own the FA 80-160 (am looking at it as I type) and this is what I can tell you:
1) Your lens is indeed the FA 80-160.
2) When focussing or zooming, the barrel does not rotate.
3) The wheel exposed through the slot in the main lens housing is direct coupled to the lens barrel - turn the wheel and the lens barrel rotates the same, along with the front objective. This is convient for adjustment of a CP when the lens hood is on.
4) Turning the wheel does not affect the focus or the focal length.
It does appear that your copy has missing screws, which may affect the operation of the wheel and/or the rotating barrel - thanks for the pictures.
Regards, Alan
11-14-2009, 09:06 AM   #14
As Alan said and typed (I too am sitting typing with my copy of this lens), your lens is missing two screws. Mine has two on the filter rotating wheel and also one to the upper left of the rotating wheel (assuming your lens is sitting with the front element pointing up).
11-14-2009, 09:55 AM   #15
Thanks for the info. I will attempt to find replacement screws.
adapter, barrel, camera, fa 80-160mm, lens, medium format, question
For Sale - Sold: Pentax FA 645 80-160mm f/4.5 Zoom (US/UK/CAN/AUS) yurihuta Sold Items 3 11-14-2010 08:04 PM
For Sale - Sold: Pentax PH-RBF77mm for FA 645 80-160mm (CONUS) Swift1 Sold Items 2 10-25-2010 07:04 AM
For Sale - Sold: Pentax 645 FA 80-160mm/4.5 Zoom Lens (Worldwide) ARCASIA Sold Items 3 10-11-2010 11:13 PM
Pentax-A 645 80-160mm Halco Pentax Medium Format 5 05-14-2010 07:35 PM
Pentax A 645 1:4.5 80-160mm oomd Pentax Medium Format 3 02-28-2009 04:14 PM
All times are GMT -7. The time now is 10:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
