What is a good source for DIY camera (wooden box) parts using medium to large format films, other than photography specific equipment (=expensive).
I'm particularly interested in shutters and lenses.
Is there any pervert way of making DIY a fast shutter?
I'm thinking of two rotating discs where one (1) has a slit and the other (2) one has a window.
When "idle" (2) is obstructing the light path.
For exposure (1) is being rotated at a constant speed. (2) Is moved to position where window is passing light to film.
Each revolution of (1) can be monitored. When a certain count of revolutions is achieved (1) engages with (2) moving the window away from the path of light. (1) and (2) are instantly stopped.
Probably very similar to horizontal running cloth shutters, only made simpler because no need of back and forth movement and instant acceleration.
Exposure would be determined by the times slit moves over window, slit width and rotation speed.
