05-14-2011, 10:06 PM   #1771
goddo31's Avatar
Nice results from the Arista.EDU Ultra 100. What was your developer?
Thanks Steve. It was just developed with Kodak Tmax developer. I like it 'cos I just mix up what I want each time Actually developed this roll with a roll of Tri-X at the same time.
QuoteOriginally posted by Makten Quote
That's a bit sharper than what I get most of the time at 2400 (which is the resolution I scan at). The main problem for me is getting the damn film flat. B&W films are usually OK, but the color negs tend to curl more. Especially Ektar. But since I don't do prints (at all, yes I'm crazy), the V700 is more than I'll ever need.
Edit: I think you could improve your downsizing though. I sharpen and resample the images in 2-3 steps, which gives much crisper results at 1024 pixels width.
Yep, film curl is a pain for me too. This film was left under some books for only a day or two and flattening it actually worked! So I managed to get it very flat in the holder for once. Must of been the fire extinguisher I was using to weigh down the books
And thanks for the note about sharpening. Yes, normally I am just 'lazy' and do it in one go exporting from Lightroom. Will have to try what you suggest.
cheers
05-14-2011, 10:08 PM   #1772
goddo31's Avatar
QuoteOriginally posted by desertscape Quote
Thanks Tuco- A lot of time and effort went into that one, not to mention the frames that didn't turn out.
It's a nice shot, I bet it would have been difficult to get right!
05-15-2011, 02:03 AM   #1773
A couple of shots from my first roll using a Jobo C-41 kit
Both using Pentax 67, 105/2.4, Cokin 121S 0.9 ND Grad + 154 0.9 ND, Ektar 100
05-15-2011, 02:59 AM   #1774
4x5 Wet Scan Test On Epson 4990
I purchased a variable height mounting station for my 4x5's from BetterScanning.com. It does both dry and wet scans. I was mostly interested in its ability to adjust its height and scan the long direction of the negative instead of the short that the OEM carrier does. So I thought I'd give wet scanning a try with it.
Things didn't start off well. The glass plate for the mounting station did not fit. Some of the glass edges were not cut square making it too wide. Fortunately, I have a oscillating drum sander that I was able to square up the edges and make it fit. And the masks they send are blanks and you have to make the 4x5 cutout in the center yourself. Mounting the wet scan was pretty easy as there is so much space to work with.
Here is a shot I have already scanned some time ago with the OEM carrier and the wet scan version. I tried to adjust it the same as the first time I did it. As far as saving time with dust, that really is not much of issue for me with 4x5's on this scanner and the OEM carrier. There is usually not much dust to clean up on them. Most certainly a piece of cake compared to the 9000ED and its glass carrier. And the wet scan was not 100% free of touch up either. So it's a push in that department, I'd say.
Both scans are 2400dpi. I really don't see much of a difference on a web display version. A little more definition looking at the river rocks and trees up stream. But that's hard to say if that's just not tone adjustment. And on the full size files, there was more detail in those dark trees. So for most web display, I don't think I'd bother with the wet scan and save it for maybe when doing a print from a scan instead.
Wet Scan With BetterScanning's Variable Height Mounting Station
Schneider Super-Angulon 90mm f8, f64, Tri-X Pan, PMK Pyro
Dry Scan With Epson's OEM Carrier
05-15-2011, 04:35 AM   #1775
Are you using stainless steel (aka CRES - corrosion resistant steel) reel and tank? Cutting an approx 45 chamfer on the film edges that clips onto the reel helps getting it started on that system.
Yes I am, I'll have to try that.
05-15-2011, 07:58 AM   #1776
lbenac's Avatar
Thanks Tuco for the feedback, you might have saved a few of us $119 plus shipping. It is a pity that the product was not well finished. One of the aspect of a third party carrier is that it should be stronger easier, better fit and more robust than the OEM. I certainly like the 120 Betterscanning carrier for my Epson 700. It feels great EXCEPT the little screws to adjust the height. The glass not at the exact size to fit, is a big disappointment.
I guess that if you did not see much improvement with the carrier wet mounted, there is no point to compare dry mounted as well (i.e. Betterscanning dry mounted and height adjusted versus OEM) I have been assuming that with the negative taped to the glass as described in their manual film flatness might improve the scan compare to potential flex in the OEM carrier.
Cheers,
Luc
05-15-2011, 09:09 AM   #1777
goddo31's Avatar
QuoteOriginally posted by kkado Quote
Nice work, but what's with the magenta-ish cast in the highlights? Eg. in the sky on the second one?
...<snip>
I think Luc is right, when you go to that much effort I guess you hope for a pretty noticeable difference. Still could be useful for a large digital print though.
This is nothing special really, but I'm starting to get to the B&W photos from my recent trip. Have another couple of rolls drying in the bathroom right now.
Lake Brunner Houses, New Zealand
Pentax 67, 105/2.4, Tri-X @400
Back at home, I recently met a friendly group of local film shooters and we went on an outing to a dam. Also tried out some Arista EDU ultra 100 film that I forgot I had. Seems like a really nice film. The camera on the tripod is a big 6x8 MF Mamiya. I think it was an RB67. A lovely beast of a thing. Oh and the guy on the left is just about to get a Chamonix, like some of you have!
Film Photographers of Perth meet - Mundaring Weir
Pentax 67, 105/2.4, Arista EDU ultra 100 developed in Tmax EI100
05-15-2011, 09:35 AM   #1778
Nesster's Avatar
I'm finally getting samples out from the Autocord... HP5+ in D-76 1:1 per Ilford instructions.
It was a pretty dark day so the aperture was either 5.6 or between 5.6 and 8...
1400pix square down from ~2600pix square scan at 1200DPI
"100% crop" from the 1200DPI, lightened a little from the above
05-15-2011, 10:10 AM   #1779
Otis Memorial Pentaxian
QuoteOriginally posted by goddo31 Quote
He was using a colored graduated filter.
05-15-2011, 12:22 PM   #1780
As far as I can tell, the Cokin 121S 0.9 ND Grad is advertised as a grad Neutral Density that is soft as opposed to a colored grad often advertised. If it's a colored grad, I'd be unhappy with that advertisement.
05-15-2011, 12:38 PM   #1781
QuoteOriginally posted by Nesster Quote
I really like the subtile nuances of the deep tones.
05-15-2011, 01:32 PM   #1782
They are advertised as "neutral density" but if you stack enough of them, they end up giving a heavy magenta cast. It's possible to correct this in post, but it's so diffuse that it's a pain in the neck so I opted not to. I think I will switch to Hitech filters in the future.
05-16-2011, 02:12 AM   #1783
fs999's Avatar
I have a V700 too
Here's a quick and dirty 2400dpi full size scan from the V700. It could improved in some areas but there's still a lot of detail. Click through to the "original" size for the 2400dpi version.
Check out the lower part of the roof and the top of the arch. Film is Arista EDU ultra 100.
Nice shots, well scanned
I am very happy with the MF holder, the glass sits well. The only problem is that the Epson software (V500) doesn't recognize the four shots, I have to manually select the shots...
Really nice shot, the greys are fantastic !
Nice details on this tank ! I love the dark tones !
05-16-2011, 07:21 AM   #1784
goddo31's Avatar
QuoteOriginally posted by fs999 Quote
Thanks Frederic. I like the greys too, just the compositions are a bit bland :P There wasn't much around to shoot.
But here is something I find infinitely more interesting...
Sopwith Camel
Pentax 67, 55/4, Ektar 100
05-16-2011, 07:27 AM   #1785
goddo31's Avatar
Lovely dark tones in this one Jussi!
645d, 645z, camera, cameras, cheapo, drive, efex, film, flickr, format, frame, fujifilm, holes, lens, lomo, medium, medium format, p67ii, pentax 67, portra, post, road, roll, scanner, shot, shots, silver, software, strait, takumar 90mm
First Medium Format straightshooter Pentax Medium Format 3 08-24-2010 07:10 AM
Medium format... D4rknezz Troubleshooting and Beginner Help 9 04-06-2010 03:59 PM
Medium Format Soon? k100d Pentax News and Rumors 0 03-04-2009 12:09 PM
Medium Format Buffy Pentax Medium Format 5 03-19-2008 12:04 AM
All times are GMT -7. The time now is 10:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
