Originally posted by alexfoto Thanks for the explanation.
Could i ask two other related questions?
On the mountain you have used only two legs (extended) and that increase the stability.
With your previous tripod and with your new light tripod, do you never use the max extended heigh (but without the center column)?
And about the head, if you don't need to change the horizont, don't you can doing the same thing even with a ballhead with a pan on its base?
So you move only the base while the horizont remain untouched?
Or i missing somethings?
The weight difference between a carbon and aluminum tripod of this size is not much at all - almost insignificant, IMHO. I got the carbon because I broke the aluminum one. The carbon version had a larger, stronger leg locking ratchet system but it's still not ideal (hence a relatively inexpensive tripod) and it has larger diameter legs.
I rarely - if ever - have extend that tripod to standing eye-level height because I use a waist level finder. This is my backpacking and street walking tripod. For bigger lenses and extending to standing height (especially with the Pentax 6x7) I use a larger tripod. But I would take my compact carbon tripod to standing height with my Hasselblad in a pinch ( I'm not that tall, BTW, so that helps).
The configuration of the tripod legs in that mountain picture is purely a function of where I could put it and the distance I wanted to be. The mountain edge was only a few feet away. It had nothing to do with setting it up for ideal stability.
Like I said, with a split focus matte, rarely is it only a pure horizontal movement to find a good focusing object after I have finalized the composition. An up/down tilt is almost always inevitable.
