Show Printable Version 35479 Likes Search this Thread
08-18-2014, 07:33 AM   #5566
QuoteOriginally posted by itshimitis Quote
Some from Jo'burg:
Went to a lion park yesterday and was in awe at the majesty of lions, and the cuteness of the cubs:
Great wildlife photos with the Z. The lion cubs in particular adorable!
08-18-2014, 07:51 AM   #5567
mikeSF's Avatar
QuoteOriginally posted by Royce Howland Quote
Thanks for the comments on my Moraine Lake photo, Rick, Thomas & Mike.
Rick, my up-front HDR process is different than how I suspect most people use HDR. I'm not using the technique for a visual look, especially not an obviously surrealistic one. Rather I use it to generate a neutrally-toned intermediate file with a very full tonal range from shadows to highlights, great micro-contrast, and low noise. Consider it analogous to a neutral conversion of a super-RAW file, one that samples a much higher fidelity range of the scene's light. I mainly use a Windows-only app for this starting point these days -- Oloneo PhotoEngine. Oloneo makes it very fast and simple to get to a well-rendered file. I used to use Photomatix, and still do go back to it on occasion because it has some strong areas where it beats PhotoEngine; but it's a bit more work and slower to get to my preferred neutral starting point with Photomatix. Many other apps could be adapted to my type of approach, and I've looked at several of the other popular apps out there. But they're all slower and more work so I don't use them. Increasingly, my type of approach will be possible with little more than Adobe Lightroom (or Adobe Camera Raw within Photoshop) now that they support loading and working on some 32-bit HDR file types.
Once I have the neutrally-toned HDR file rendered back down into a 16-bit TIFF, I finish it in Photoshop using some layer blending but primarily curves work. Not dissimilar to Tony Kuyper-style luminosity masks & curves, but a bit more custom than that. I do very little colour adjustments in general, and when I do it's as often as not (as in this case) that I'm desaturating certain colour channels or hue ranges to make sure I retain a largely photorealistic (but still creatively interpreted ) rendition. My goal is a final image that looks like it could be from a single frame, but with a full tonal range that's as rich as I'd like in detail, and free of noise or other obvious processing artifacts. I half-jokingly say I often go to a lot of work to make it look like I don't do much work in post...
The Topaz filters I use most heavily are DeNoise and Detail, occasionally Remask to get a good initial selection in a particularly tricky area. I have most of the Topaz bundle but rarely use the others beyond these 3. My B&W work in particular isn't done with a filter, but rather manually in Photoshop.
The Z is proving to be killer, but the D remains eminently usable too. It's a win either way.
this is fascinating, thanks for sharing your technique. I am not sure I understand it, but the results say everything.
08-18-2014, 09:52 AM   #5568
managger's Avatar
My several albums after 645Z testing
http://fotkidepo.ru/?id=album:53915
http://fotkidepo.ru/?id=album:53916
http://fotkidepo.ru/?id=album:53917
http://fotkidepo.ru/?id=album:53919
08-18-2014, 10:54 AM - 2 Likes   #5569
An inner yard of a building (Rome, Italy)
Pentax 67
SMC Pentax 55mm
Ilford 100 Delta
08-18-2014, 11:21 AM - 2 Likes   #5570
A120 macro with tube 3.
a crop of the 645z images
marcus
08-18-2014, 12:29 PM   #5571
Pentax K5
SMC Pentax 67 100mm macro
Pentax 67 extension tubes (1+2+3)
Pentax 67 Lens to Pentax K-mount Body Adapter
A bird feather.
PENTAX K-5  Photo
08-19-2014, 12:23 AM   #5572
Rick, my up-front HDR process is different than how I suspect most people use HDR. ……………………………………………...The Z is proving to be killer, but the D remains eminently usable too. It's a win either way.
Royce, thanks for your comprehensive reply. I appreciate the detail and your willingness to share. My understanding of your comments would be to first produce a neutral file with rich tones with Oloneo PhotoEngine, Photomatix or other software. Then Photoshop with curves and layers, Tony Kuypers luminosity masks, or similar processes. Be very careful with color. Do final finishes which might include DeNoise or adding grain.
I think what is wonderful about your image is that you are well constrained with your processing and achieved your goal of a realistic yet artistic rendition.
Also, it's nice to see Moraine Lake represented in a way other than the typical iconic views. Well done and thanks.
Rick
08-19-2014, 05:29 AM   #5573
Some Great White Pelicans in a bird park in Johannesburg having a good splash about:
Pentax 645Z FA 120 f/4 macro:
1.
2.
3.
4.
5.
08-19-2014, 05:31 AM   #5574
s-tet, that first monochrome image of the doorway in Rome is my idea of a great image.
08-19-2014, 06:14 AM   #5575
QuoteOriginally posted by Richard Longseth Quote
... My understanding of your comments would be to first produce a neutral file with rich tones with Oloneo PhotoEngine, Photomatix or other software. Then Photoshop with curves and layers, Tony Kuypers luminosity masks, or similar processes. Be very careful with color. Do final finishes which might include DeNoise or adding grain.
Yes, that's right on.
Thanks for the kind words!
08-19-2014, 07:58 AM   #5576
gofour3's Avatar
QuoteOriginally posted by s-tet Quote
Pentax 67
SMC Pentax 55mm
Ilford 100 Delta
Nice shot, like the tones.
Phil.
08-19-2014, 09:19 AM   #5577
A tighter crop of no 2 from the previous series:
08-19-2014, 09:31 AM   #5578
mikeSF's Avatar
QuoteOriginally posted by marcusyoung Quote
marcus
this is lovely! love the detail and colors.
Who knew the 645 does macro? i am slightly joking, but need to give it a try myself as your pic is inspiring!
08-20-2014, 12:55 AM   #5579
QuoteOriginally posted by mikeSF Quote
Thank you, mike.
This was shot at max magnification more more than 1:1, 120A macro with additional tube 3 attached. with flash on.
Tripod used as the set up was heavy as well, more than 2 Kg.. Building up my muscles as well..haha..
marcus
08-20-2014, 06:02 AM   #5580
The Great White Pelicans what ISO and shutter speed did you use? Thank Bob
645d, 645z, camera, cameras, cheapo, drive, efex, film, flickr, format, frame, fujifilm, holes, lens, lomo, medium, medium format, p67ii, pentax 67, portra, post, road, roll, scanner, shot, shots, silver, software, strait, takumar 90mm
First Medium Format straightshooter Pentax Medium Format 7 12-02-2019 10:11 PM
Medium format... D4rknezz Troubleshooting and Beginner Help 9 04-06-2010 03:59 PM
Medium Format Soon? k100d Pentax News and Rumors 0 03-04-2009 12:09 PM
Medium Format Buffy Pentax Medium Format 5 03-19-2008 12:04 AM
All times are GMT -7. The time now is 06:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
