Originally posted by ivanvernon Yes, I believe it is. I am not a big tripod user, and the 90mm lets me hand hold the Z at 1/60 sec with no problems, meaning that for landscape use I can go to smaller apertures than otherwise. It seems to me that the SR is giving me about two stops.
Rather than embedding motion stabilization (MS) into every lens, Pentax should consider providing an MS device performing the function that was once provided by the Dynalens product, manufactured by Dynasciences Corp. (back in the '70s). This device would fit to the front of the lens assembly. It would have to have an aperture equal to that of the lens being stabilized plus enough extra for the beam width, which would make it practical where it was most needed, long telephotos of modest f/#. One device could potentially stabilize a range of lenses.
The Dynalens comprised a pair of flat windows with an index-matched liquid in between them within a bellows, along with servo motors, rate sensors and drive electronics. When one window was dynamically tilted, a prism was effected, deviating the beam. Chromatic aberration would have to be addressed, but in our case, the motion being corrected would be so small that this might not be significant. How the scheme would compare to a common alternative scheme of counter rotating acromatic prisms in cost and performance is unclear to me.
I assume modern comparable devices exist for television work, but have no idea what their designs and limitations are.
