02-11-2010, 02:04 AM   #1
Pentax SMC 300mm f4
If you have used both, do you find the added reach of the 300 significant for field sports compared to a 200 ?
I was shooting a rugby match recently and was wishing to be in a bit tighter in the scrum but I do not know if the 100 difference in the 67 format will really be all that noticeable or not.
02-11-2010, 07:10 AM   #2
Lowell Goudge's Avatar
the difference will be the same regardless of format.
images from a 300mm will be 50% bigger than those from a 200mm lens.
it all goes back to math
Image size = Subject size x Focal length / Subject distance
02-11-2010, 09:49 AM   #3
I have the 67 300mm M* ED IF lens. And, yes, there is a difference. But if it is enough of a difference for you I can't say. I take it you are aware of the precautions you need to consider when you shoot the older 300mm? Even with the newer 300mm, I find it needs to be really supported by both its tripod mount and the camera body mount for shutter speeds under 1/60. But for sports, you'll be above that most likely.
If you get the older 300mm, consider an inexpensive video camera rail system to mount it and the camera on then mount the rail to a sturdy tripod.
camera, medium format
Pentax SMC DA 55-300mm F4-5.8 Ed JimD_K10D Troubleshooting and Beginner Help 6 08-20-2010 05:58 PM
SMC PENTAX FA* 300MM F2.8 available netuser Photographic Technique 4 11-14-2009 08:14 PM
For Sale - Sold: Pentax 300mm F/4: SMC-A* and SMC-Takumar SOldBear Sold Items 7 11-05-2009 07:14 PM
All times are GMT -7. The time now is 06:27 PM. | See also: NikonForums.com, part of our network of photo forums!
