Originally posted by Smolk I want to buy a flash for the 645, but wonder which flash is best
suited to ad hoc use (i.e. outside a studio hence controlled
environment). Considerations are:
1. fill in flash and
2. normal but indirect flash, yet without a convenient wall.
Any advice or experiences? Way back I coveted a Metz rather than
Pentax, but things may have changed.
(it's been a long time since I used my old 35mm camera and even longer
since I used it regularly, and I never had TTL back then).
Do you intend to buy a DSLR as well? If you do, then the AF360FGZ or the AF540FGZ would make sense. If you are only shooting film, then you might be better off with a used flash from the TTL-only days. I have used the AF540 successfully, but my flash of choice is the AF400T. The potato-masher style works well with the 645 body, and mine has a nice High Voltage AC adapter which makes it nice for strobist work. If you buy with the useful accessories, these older flashes are not real cheap used--typically more than the AF360 and less than the AF540. Power is also in between the two current flashes.
