03-03-2010, 02:54 PM   #1
645D crop view
I was sort of grumbling to myself about the new 645D and the reduced format, making my 35mm lens less wide. But on the other hand I recall several pics that I have taken, especially with the Harblein 45mm T/S, that had a lot of vignetting that I could not see in the viewfinder. I also saw my feet or my hat in a lot of the 30mm Arsat fisheye and the 35mm/3.5 shots.
So I looked up the viewfinder in the regular 645 and found that it only showed 92% of the view, ergo my vignetting problems. Assuming that the new 645D will have live view, it will only crop to 88% of full 645 frame (assuming a 49mmx37mm sensor).
So, assuming live view, I'm happy.
Warren
03-10-2010, 12:03 PM   #2
Laurentiu Cristofor's Avatar
The 645D viewfinder has 98% coverage.
03-12-2010, 04:05 AM   #3
falconeye's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
Yes. 645D has no LV, a 44x33mm sensor (an 1.27x crop of 41.5x56mm film) and an 98% VF (of that cropped region).
03-13-2010, 07:39 AM   #4
Kguru's Avatar
... and an 98% VF.
I'm curious why 98% not 100%.
Is the last 2% very difficult to achieve?
03-13-2010, 05:18 PM   #5
D W
QuoteOriginally posted by Kguru Quote
No getting 100% is not a problem, getting 100% accurately is the issue. That is why most SLR's show 95-98% to cover the margin of error. In a mounted 35mm slide you are getting less than 100% of the frame.
03-13-2010, 05:25 PM   #6
QuoteOriginally posted by D W Quote
That sort of thing is usually margin of error - else someone will go and set out just to prove you wrong.
645d, camera, crop, lot, medium format, view, viewfinder
Crop Factor, Focal Length and Field of View Ole Pentax Lens Articles 15 05-26-2013 12:41 PM
Do you shoot and crop in camera or shoot loose and crop in photoshop? hockmasm Pentax DSLR Discussion 23 05-02-2010 06:10 PM
Field of View Tables, APS-C, 24x36, 645D, 645, 6x7 Ole Pentax Lens Articles 0 03-14-2010 06:38 PM
Interesting article at B & H re: angle of view, crop factors, etc. noblepa Troubleshooting and Beginner Help 8 06-24-2009 02:46 PM
Crop Factor and Field of View Ole Photography Articles 0 02-01-2009 09:31 AM
All times are GMT -7. The time now is 12:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
