03-25-2010, 11:09 AM   #1
Marketplace Reseller
6x7 45mm F4.0
I see some advertised... some say late model others don't the Late model ones are more expensive, is there anything optically different between them?
03-25-2010, 11:38 AM   #2
Here is a Pentax 6x7 Lens Guide. You'll note the comment that the optics are unchanged.
03-25-2010, 11:42 AM   #3
Thanks i guess i'll pick up the cheaper early model then
Here is a Pentax 6x7 Lens Guide. You note the comment that the optics are unchanged.
03-25-2010, 11:59 AM   #4
I have the earlier 45mm model too. I'm satisfied with it. But unless the extreme wide angle is called for, it takes a back seat to my SMC 67 generation 55mm. YMMV.
03-25-2010, 02:59 PM   #5
bensonga's Avatar
I have the later version and for extreme wide angles, it's one of my favorite lenses. Just got the 55mm a few months ago and haven't really had a chance to use it much yet.
Here's a shot with the 45mm lens.
Gary
03-25-2010, 10:33 PM   #6
Hi bensonga,
Great tonality and gradations.. would you advise what scanner you used please? Thank you.
03-25-2010, 11:02 PM   #7
bensonga's Avatar
Hi Bob.....I use the Epson V750 Pro with Silverfast AI v6. The V700 with Vuescan would work equally well. Before I got the V750 I used an Epson 2450 for many years and those scans were very good too.
I think it's hard to do wrong when you're working with that big, beautiful 6x7 negative! :-)
Even so, someday I'd love to see what a Hasselblad Flextight or a high end drum scanner could do with my P67 negs and transparencies.
Gary
03-26-2010, 03:30 PM   #8
Well, I 've made the assumption that the old version and new version are optically the same, although I've never seen the cross section of the old version. I have the new version cross section and it would be interesting to see the old cross section in the old owner's manual of the 45. Anyone have the cross section of the old 45?
6x7 45mm, camera, medium format, model
Pentax 6x7 45mm: Vignetting using Cokin Z-Pro filter holder? leoyblam Pentax Medium Format 2 08-19-2010 08:04 PM
6x7 45mm F4 for sale MightyMike Pentax Medium Format 1 05-07-2010 10:00 PM
All times are GMT -7. The time now is 11:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
