04-03-2010, 05:31 PM   #1
Pentax 6x7 winding lever stuck -- please help!
Hi everyone -- I have a problem with my 6x7.
I have some 120 film loaded, camera is working 100% fine, but the problem is this: I took a picture, then advanced the film using the winding lever.
Then a while later, I had forgotten I had wound the camera, and wound it AGAIN. The lever is now stuck at the half-way point, and the shutter will not fire.
I feel like a total idiot and I hope I haven't damaged anything!
Is there a release mechanism? Or something that will reset the lever? Thanks in advance for your help.
04-03-2010, 06:52 PM   #2
UPDATE -- I located the teeny tiny "mechanism release button" on the 6x7 body, and held pressure on it with the tip of a house key while gently moving the winding lever. Success! Everything's back to normal.
04-03-2010, 08:29 PM   #3
What's confusing about that is you should not be able to wind the lever again after you've advanced the film without firing off a shot.
04-05-2010, 01:41 PM   #4
My camera is an Asahi Pentax 6x7, not sure which year (haven't checked the serial numbers yet). But it's an early one, I believe. I think the winding mechanism might be a little worn out ... that might explain why I was able to push the lever even AFTER I had advanced the film.
The camera otherwise seems to function OK. I will have to keep an eye on it.
camera, film, lever, medium format, pentax 6x7, wound
Another 6x7 with shutter and mirror stuck open Denverdad Pentax Medium Format 17 11-10-2016 02:14 AM
Dismental MX Winding Lever Assembly? frank Pentax Film SLR Discussion 3 12-13-2009 11:55 PM
Pentax ME Super Winding Issues Inafinus Pentax Film SLR Discussion 8 11-04-2009 06:41 AM
ME Super stuck winding lever & unresponsive shutter Charles Hueter Pentax Film SLR Discussion 11 07-12-2009 11:26 AM
6x7 MLU mirror and shutter stuck open mk07138 Pentax Medium Format 2 03-17-2009 03:07 PM
All times are GMT -7. The time now is 03:34 PM. | See also:, part of our network of photo forums!
