03-25-2011, 08:20 AM   #31
It was with a few different items - both MF and standard 35mm. Some of the items were still on the website a few days after I phoned, so even having had a poke, they did not update the website. It's no skin off my nose in that they didn't pretend they were in stock to me when I phoned, but it does mean that I won't bother calling them now since in my experience I can't trust them to actually have advertised items in stock.
03-27-2011, 10:22 AM   #32
QuoteOriginally posted by Matus Quote
5/4
The zooms mentioned are about 2 pounds each. The body is under 3 pounds, so weight is less than 5 pounds. At 45 degrees, tripod legs form an equilateral tetrahedron, which can handle handle forces better than any other geometric structure! The problem is mechanical vibration that can be caused by the wind, tripod design, or distribution of weight on the tripod head. You're right that top heavy is not a good thing. What photographers generally do is install a hook under the center column and attach a sand bag or a bean bag with some heft. That will dampen or eliminate vibrations altogether. You want to bring the tripod weigh up to 5 or 6 pounds this way.
This may seem like a dumb idea if you've got to carry another 3 pounds, but if you're going to get camera shake, why bring a camera at all! Also, a bean bag or sand bag makes an excellent camera rest, with excellent vertical and horizontal stability, enough for slower than normal speeds (but not very slow speeds called for with small apertures).
Some photographers make it their mission in life to eliminate vibrations that rob images of their sharpness and will carry a 15 pound tripod (like my big boy Gitzo with Majestic geared head). Rock steady, rock on!
04-05-2011, 04:21 PM   #33
GeneV's Avatar
I've run through some rolls on the 645n, and it handles so nicely, I wonder why I didn't spring for one earlier. Now, if I just had the money for some AF lenses.
645n, camera, fa, forum, gear, lenses, medium format, pentax, price, reason, weight
Pentax 645N Ole Pentax Medium Format 2 04-05-2011 04:17 PM
Pentax 645N vs. 67 netrex Pentax Medium Format 41 04-01-2011 02:06 PM
Bought a 645N ve6raj Pentax Medium Format 4 11-25-2009 08:57 AM
Need help choosing between 645N and 67!! artistcjconrad Pentax Medium Format 6 07-24-2009 09:30 AM
645n Camera jbrowning Pentax Medium Format 7 02-02-2009 04:56 PM
All times are GMT -7. The time now is 01:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
