K-x focus screen drawing & Travor focus screen issue
Posted By: xjx, 06-08-2010, 01:27 PM
Forum member Luma discussed focusing issue of Travor focus screen on K-x (see: Travor focusing screen - BE AWARE!). The main part of the observation is that the object in the center of the split-image circle will not appear at the center of the captured image. Instead it is located above the center. When AF is used, the center AF point doesn't agree with the perceived point of focus in the split-image circle. As a result, AF will be off if one tries to focus to an angled surface (such as the 45 degree focus chart) using the center of the circle as focus target.
Being curious how this happens, I took out the stock focus screen of K-x and did some measurement. Here is a drawing I made based on the result:
From the drawing we can see the K-x focus screen has edges that appear clearer than the main part and will be covered by the metal clip when installed. The edge at the upper side is wider than the one at the bottom. The center focus point is located at the center of the grounded area (shaded in the picture) and thus should be a little bit below the center of the whole screen (offset by 0.5mm).
As a comparison, the Travor screen (which I also have) has the split-image circle exactly at the center of the whole screen. When installed on K-x, the circle will appear off center. One can see that by just looking into the view finder.
06-08-2010, 07:20 PM   #2
MSM
MSM's Avatar
Looks interesting. Thanks for the update.
06-06-2012, 10:13 PM   #3
xjx
Don't know why the picture disappeared from the article. Just added it back.
af, center, circle, focus, k-x, k-x focus screen, screen, split-image, travor
Travor focusing screen - BE AWARE! luma Pentax Camera and Field Accessories 18 04-08-2011 09:04 AM
K-x focus screen drawing xjx Pentax Camera and Field Accessories 2 06-08-2010 02:03 PM
Installing Travor focusing screen on Pentax KX luma Pentax Camera and Field Accessories 4 04-11-2010 03:25 PM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Pentax Film SLR Discussion 2 01-06-2009 01:21 AM
K10, split-screen, LF80 & LL60 : Focus and exposure accuracy dlacouture Pentax DSLR Discussion 24 11-18-2008 06:20 AM
All times are GMT -7. The time now is 04:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
