What are the checksums of the K10D/K100D firmware updates?
Posted By: mattdm, 11-01-2007, 05:53 PM
The camera's internal firmware update routine may have some sort of checksumming capability of its own, but better safe than sorry. A really corrupt firmware file probably wouldn't even load, but maybe a single or double bit error would slip through. So, here's md5 and sha1 checksums for the files from firmware 1.30 for the K10D:
$ md5sum fwdc162b.bin readme.txt
2afa718d2aadbf283a54d123c9178a6b fwdc162b.bin
88a666c31eb5c7cf3b0ca2095307c38f readme.txt
and
$ sha1sum fwdc162b.bin readme.txt
177db82b63efd1a7b7f693b87e84f53de80c579b fwdc162b.bin
124e85ea4043900796b632c68661a3e15b6508bd readme.tx
Please follow up with checksums for other firmware versions for the K10D and other Pentax digital cameras.
11-06-2007, 02:54 PM   #2
For those who have never heard of checksumming, it's a method for verifying that your downloaded file wasn't corrupted during the transfer process.
An md5 or sha1 checksum program will read through the bits of any file and calculate a unique (for our intents and purposes) "hash" value for that file. If your downloaded file is a perfect copy of the original, then the hash value calculated from both files should be the same.
11-16-2007, 04:39 PM   #3
Lowell Goudge's Avatar
For all those who really want an explanation, a checksum is a numerically calculated value which has taken some specific file information such as create date etc, and added a calculated value shich performs specific arethmitic calculations on each byte of the code, to create a unique number.
It is used in software to insure that the software is original and not corrupted.
It is used in communications, to insure that messages are transmitted without error.
In some instances, depending on the technuique employed it can be used for error correction of transmitted data.
If you change one line of code in several megabytes of a program, it will usually generate a different checksum.
As a result, V1.1, 1.2 and 1.3 of the K10D software (for example) each have different checksums, and if there is an error in loading the software this is the first way the camera detects it. The checksum is downloaded as part of the software loading process, and compared with the calculated value the camera makes. The probability of having an error in the checksum as it is downloaded, and an error that produces the same erroneous checksum, or multiple errors that result in the calculation of a valid chechsum is very very low.
11-16-2007, 07:58 PM   #4
mattdm's Avatar
In fact, if it doesn't produce a different checksum result, the checksum algorithm in use is seriously flawed.
11-16-2007, 10:12 PM   #5
Fl_Gulfer's Avatar
I just wish I could get it to load into my camera, I've tryed 3 different cards and 3 different ways to load it onto the card. So my K100 will have to go without.
03-29-2008, 03:44 AM   #6
Firmware update for K100D
Mine does the same. No way will it update, I've done everything the readme says. I've even changed the name from FWDC156B.BIN to fwdc156b.bin and nothing.
Is there anywhere else I can get this file from as I think there is a problem with the one on the pentax site. I've downloaded it four times to differant locations on my PC. but still the screen comes up with 1.00 and then nothing.
Please help!!
03-29-2008, 04:22 AM   #7
ftpaddict's Avatar
I don't get it. My firmware update worked flawlessly.
03-30-2008, 02:09 AM   #8
I have now tried it with 3 differant memory cards and still no go. Has anybody got any ideas
03-30-2008, 04:28 AM   #9
mattdm's Avatar
Can you describe exactly what you are doing?
Edit: and, let's not handle this here in the Knowledge Base forum, which I think should be for solved problems. Can you post something over in the DSLR forum?
04-12-2008, 10:13 PM   #10
QuoteOriginally posted by mattdm Quote
and
I could check my firmware before using it, thank you !
04-13-2008, 01:29 AM   #11
falconeye's Avatar
This procedure isn't necessary.
The download of firmware files is an archive.
(At least, this is the case for download from
Downloads - Digitalkameras, Fotografie und Ferngläser - PENTAX Europe GmbH
-> you get an .exe which actually is the WinSFX32M Self Extractor for Win32)
So, save the downloaded file and just prior to your update, run/unpack it
The checksum is then automatically checked for you by the unpack routine as the archive format is checksum protected anyway.
So please, save your time and don't check checksums again.
04-17-2008, 09:18 AM   #12
mattdm's Avatar
It makes me feel better to check the checksum of the bin file on the SD card itself.
Also, that exe file uses an LHA format archive, which I believe uses the CRC-16 BISYNCH checksum protocol, which is much less robust than the sha1sum or md5sum algorithms. It's unlikely that there'd be an error undetected by this, but it doesn't hurt to double-check.
08-09-2008, 08:06 AM   #13
K100D firmware v1.02
K100D Firmware v1.02 MD5
244d1b7af0c4a75355679a1ab3e9de43 *FWDC156B.BIN
Followed the instructions carefully and it worked. Now, how do I upgrade the firmware in my Spotmatic?
checksums, firmware, k10d
Firmware updates yahmon Troubleshooting and Beginner Help 6 04-23-2010 07:46 PM
K-X firmware updates xmen Troubleshooting and Beginner Help 1 01-19-2010 02:43 AM
Kx 1.01 firmware checksums are different opiedog Pentax DSLR Discussion 18 01-02-2010 07:01 AM
How many firmware updates for K-7? ronin67 Pentax DSLR Discussion 2 12-12-2009 07:29 AM
Pentax K10D firmware updates riverwatcher Pentax DSLR Discussion 6 09-22-2008 08:20 PM
All times are GMT -7. The time now is 02:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
