Which remote cables can be used?
Posted By: Ole, 09-07-2006, 09:21 PM
The more recent Pentax cameras do not accept the classic threaded cable releases.
They instead accept an infrared remote (Remote Control F) and/or a dedicated cable release as listed below:
DSLR:
  • K20D, K10D, K200D, K100D, K110D, *istD, *istDS, *istDS2, *istDL, *istDL2
    • Cable Switch CS-205
    • Remote Confrol F
  • K2000/K-m
    • Remote Confrol F
Film SLR:
  • *ist
  • MZ-S
    • Cable Switch CS-105
    • Cable Switch CS-130
    • Release Timer Switch TS-110
  • ZX-5N/MZ-5N, ZX-5/MZ-5, Z-70/PZ-70, Z-20/PZ-20, Z-10/PZ-10, Z-1/PZ-1, Z-1P/PZ-1P
    • Cable Switch F
  • SFXN/SF1N, SFX/SF1, SF7/SF10
    • Cable Switch F
Last edited by Ole; 01-31-2009 at 12:37 PM. Reason: Link in previous post no longer valid
07-17-2007, 03:44 AM   #16
Mechan1k's Avatar
To add to this ... there are better pictures on the manufacturers site.
SECULINE Innovative Product Maker
Go to Products and then select Twin 1
07-20-2007, 04:26 PM   #17
Hi. I just started using my new K10D yesterday and have obviously been labouring under the mistaken impression that this camera could only be remotely fired/triggered via its front/rear infrared sensors ? I 'm not entirely sure what the 2.5mm jack socket is intended for, as the instruction manual states that it is a 'cable switch terminal'..........precisely what does that mean in layman's language ?
07-23-2007, 04:41 PM   #18
Mechan1k's Avatar
With the IR remote it really only allows the use on a momentary button. The the remote that is cabled (using the 2.5mm jack that plugs into the left side of the K10D body behind the door) .. it allows the use of half shutter holding the button down ... also the bulb mode with some remotes as well (holding the shutter open for as long as you like and closing it when you want as well).
The K10D can use both ... in your setup menu in the camera though you can select AF on remote button press prior to shutter release ... and this works well in many instances.
Hope this helps.
07-25-2007, 03:57 AM   #19
pixelsaurus's Avatar
For cable switch read electronic cable release.
10-18-2007, 10:14 PM   #20
NYpHoToGraphEr's Avatar
Pentax K100D
QuoteOriginally posted by joele Quote
The remotes that work are the original Pentax cs-205 or the Canon RS60-E3
Or aftermarket versions of either.. (just check ebay)...
Does the pentax cs-205
work for Pentax K100D?
10-19-2007, 03:07 PM   #21
Hi NYpHoToGraphEr
Re you question:
"Does the pentax cs-205 work for Pentax K100D ?"
Sorry, I don't have this camera so can't comment, but thought that you might nevertheless be interested in the following three links:
Wireless Shutter Release for Pentax K10D K110D K100D - (eBay item 230156798294 end time Aug-01-07 18:45:04 PDT)
https://www.pentaxforums.com/forums/84720-post29.html
https://www.pentaxforums.com/forums/84728-post30.html
I bought one of these brilliant little devices off E-bay a few months ago. It possesses a massive operational range (will even work through solid walls etc) and IMHO is ideal for many potential applications such as discrete wildlife photography amongst others. It's ridiculously good value for the build-quality it offers, although the internal battery in the transmitter is of a slightly unusual variety. However this is not a problem, as the batteries in both transmitter and receiver are easily user-replaceable !
Just my 2-cents worth and hope this info might be of some help ?
Best regards
Richard
10-19-2007, 04:37 PM   #22
creampuff's Avatar
QuoteOriginally posted by NYpHoToGraphEr Quote
If only you would read page 191 under Optional Accessories of your K100D operating manual... duh
12-15-2007, 09:50 AM   #23
bananarama's Avatar
Pentax Remote
Someone else found another idea that works with the K10D....a universal remote!
I tried it with a GE Universal laying around not being used. I programmed the AUX button with code 012 and it works!
10-16-2008, 06:34 PM   #24
Class A's Avatar
Sony remote controls often work as well. The one for my older TV set does.
10-17-2008, 10:04 AM   #25
QuoteOriginally posted by bananarama Quote
That sound good. Can you show what you have done with the AUX button
10-17-2008, 11:16 AM   #26
Spongefingers's Avatar
QuoteOriginally posted by Khukri Quote
Can anyone kindly throw light on the most suitable wireless remote for the K10D? There seem to be a few versions of the Remote F and I am confused. Looking to use it for time photography (bulb) and would of course prefer it to focus prior to releasing the shutter. (Apropos, doesn't Pentax have a camera back for teh K10D to control functions? (Example: Command Back 90 for the Canon T90). Thank you.
The remote F can fit inside the D-BG2 battery grip, but doesn't have wired operation for autofocus / bulb control.
I have a Seculine TWIN1 R3-UT - that is a bit more expensive, but it does both wireless infra-red and wired control (with a button lock-down too). It has a small white LED that flashes when you press the button in IR mode - it also doubles up as a tiny flashlight. It takes one A23 battery. It works with any camera that uses a 3.5mm stereo-jack type control socket.
05-25-2009, 06:19 PM   #27
Class A's Avatar
QuoteOriginally posted by Mechan1k Quote
But it is possible to use the IR remote in bulb mode. The shutter will be open as long as you press the button on the IR remote.
09-14-2009, 08:04 AM   #28
QuoteOriginally posted by Ole Quote
DSLR:
    • Remote Confrol F
  • K2000/K-m
    • Remote Confrol F
Film SLR:
  • *ist
  • MZ-S
    • Cable Switch F
    • Cable Switch F
Hi, I am new to the forum, have just purchased a K2000 and wanted to confirm that the Remote Control F is the correct one I buy
09-14-2009, 01:31 PM   #29
Class A's Avatar
QuoteOriginally posted by markpa888 Quote
To the best of my knowledge it will work with your camera. Just be aware that the wireless remote (Remote Control F) only
  • allows you to release the shutter, i.e., no AF triggering.
  • works from the front of the camera (where the IR sensor is).
It will support "bulb mode" though. I find the wired remote more useful most of the time, the main advantage of the wireless remote being that it is tiny and easy to carry around (even fits into a battery grip).
11-05-2018, 12:15 PM   #30
angerdan's Avatar
Great list, would be nice to see an article with table about it
cable, cs-205, pentax cameras, release, switch
Trigger voltage, radio triggers and cables question bdery Flashes, Lighting, and Studio 10 08-30-2011 11:33 AM
kx and cables! trishytee Pentax DSLR Discussion 12 08-08-2011 05:02 AM
Cables to connect k20D to Metz & Pentax flash bessa66 Ask B&H Photo! 2 02-06-2011 09:44 AM
For Sale - Sold: Pentax Off Camera Flash Adapters and Cables mrchris Sold Items 7 03-17-2010 03:10 PM
Triggering 2 flashes at once w/ sync cables? gsrokmix Pentax DSLR Discussion 5 12-31-2009 09:31 PM
All times are GMT -7. The time now is 10:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
