Pentax Coatings: Ghostless, SP & Aero Bright
Posted By: Blue, 06-16-2010, 07:43 AM
Has anyone besides me noticed how little information there is available on some of the specialty coatings used by Pentax? The SMC coating is also limited and apparently had undergone numerous revisions since the early 70s. Some rumors say it was originally designed at the request of Japanese police for traffic cameras.
The Ghostless Coating was announced in 1992 and is considered a milestone for Pentax. It was apparently 1st used in 1997 on the the FA 43mm ltd and all subsequent limited lenses as well as certain * lenses. However, besides the LTD lenses, the other lens it was used on is unclear.
SP Coating The front surface of the optics is treated with the Pentax-original Super Protect (SP) coating. Applying a special fluorine compound to the lens surface through a vapor deposition process, this coating effectively repels dust, water and grease, making it easy to wipe off annoying stains such as fingerprints and cosmetic marks.
The Aero Bright Coating enhances image-description performance by effectively reducing reflections over a wider wavelength range. Compared to conventional multi-coatings, this new coating greatly improves light transmittance in the lens, while drastically reducing flare and ghost images that deteriorate image quality. It is an original lens coating using a silica aerogel with uniform porous structure as a base material to produce clear high-quality images by assuring and outstanding anti-reflection performance over a broad range of wavelengths. It is currently used on internal elements of the DA* 55mm for improved light transmission and reduced flaring and ghosting. Apparently the DA* 60-250mm also has the A.B. It is used on the new 645D lenses as well.
Update as of 2012:
Pentax released a new coating called the HD coating, which offers better reflectance (i.e. less ghosting/flare) compared to SMC, and it is more durable than Aero Bright and thus suitable for use on the front element as well as other elements.
 SMCHDAero Bright
Reflectance-+++
Durability++-
Cost+++-
That is all I've turned up on these. However, Pentax has been close to the vest on Coatings all the way back to the 50s. This info is from Pentax Imaging, Dimitrov and Pentax press releases.
09-16-2012, 05:48 PM - 1 Like   #16
Blue's Avatar
Is this the Aero Bright Patent or SMC
United States Patent: 8199404
Abstract An anti-reflection coating comprising first to seventh layers formed on a substrate in this order, the first layer being an alumina-based layer, the seventh layer being a porous, silica-based layer, and each of the first to seventh layers having predetermined refractive index and optical thickness in a wavelength range of 400-700 nm.
Inventors: Yamada; Kazuhiro (Saitama, JP), Nakayama; Hiroyuki (Tokyo, JP), Suzuki; Mineta (Saitama, JP) Assignee: Pentax Ricoh Imaging Company, Ltd. (Tokyo, JP)
Appl. No.: 12/342,128 Filed: December 23, 2008
Is the the Aero or is it HD (High Definition) Patent
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fn...ntax&RS=pentax
Abstract An anti-reflection coating comprising a mesoporous silica coating composed of mesoporous silica nano-particles formed on a substrate or a dense coating formed on the substrate, the mesoporous silica coating having a refractive index of more than 1.10 and 1.35 or less.
Imai; Hiroaki (Kanagawa, JP), Nakayama; Hiroyuki (Tokyo, JP), Shiokawa; Takanobu (Kanagawa, JP), Yamada; Kazuhiro (Saitama, JP), Suzuki; Mineta (Saitama, JP) Assignee: Keio University (Tokyo, JP)
Appl. No.: 12/393,333 Filed: February 26, 2009
09-16-2012, 06:18 PM   #17
Blue's Avatar
Some HD info . . .
"Compared with conventional multi-layer coatings, the new multi-layer HD Coating, exclusively developed by PENTAX, offers much improved light transmittance and a much lower refractive index. Because it minimizes reflections, it delivers sharp, clear images free of flare and ghost images, even under demanding lighting conditions such as backlight. This coating assures optical performance almost equal to Aero Bright Coating, another PENTAX-exclusive lens coating process made possible by advanced nanotechnology and applied to higher-class lenses."
09-16-2012, 07:09 PM   #18
monochrome's Avatar
From Asahi Optical Historical Club
"As I already wrote, Asahi didnít invent the multicoating, since they bought patents from Optical Coatings Laboratories Inc. (OCLI), based in California. The merit of Asahi Opt. Co. was to understand the importance of anti-reflective coating, looking for the proper technology, developing their own industrial process and put it into production at acceptable costs. That marked a turning point in the evolution of photographic optics, allowing the development of modern ultrawide-angle and wide-range zoom lenses. With the growing popularity of zoom lenses and their ever-increasing focal length extension (needing more and more elements), multicoating became almost as necessary as glass in order to obtain quality optics."
Also, there were Ghostless (coated) Pentax filters, usually UV and Skylight.
09-16-2012, 07:17 PM - 1 Like   #19
Blue's Avatar
"As I already wrote, Asahi didn’t invent the multicoating, since they bought patents from Optical Coatings Laboratories Inc. (OCLI), based in California. The merit of Asahi Opt. Co. was to understand the importance of anti-reflective coating, looking for the proper technology, developing their own industrial process and put it into production at acceptable costs. That marked a turning point in the evolution of photographic optics, allowing the development of modern ultrawide-angle and wide-range zoom lenses. With the growing popularity of zoom lenses and their ever-increasing focal length extension (needing more and more elements), multicoating became almost as necessary as glass in order to obtain quality optics."
The filters were different than the later Ghostless Coating that was developed for street cameras in the early 90s. It was first used in 135 format lens, the FA 43mm LTD. This thread has focused mostly on the coatings newer than the SMC. However, Asahi Optical was the first to start using multicoatings on production lenses.
That said, there is not much available on the coating(s) used on the Takumars, Auto-Taks and Super Taks.
09-26-2012, 02:43 AM   #20
QuoteOriginally posted by Tom in Delaware Quote
The FA 28-105, f3.2-4.5 has the ghostless coating.
Which 28-105? The one with powerzoom or the newer ones?
BTW, the DA*55 and DA* 60-250 both have Aero Bright, but how about the DA*50-135?
04-16-2013, 05:45 AM   #21
Blue's Avatar
They are both nano technology. I would assume there are enough differences to deal with patent issues. Nikon calls their Nano Crystal Coat.
Nikon's exclusive Nano Crystal Coat nearly eliminates the ghosting and flare seen with some wide-angle lenses for improved clarity and contrast. Impressive on both FX- and DX-format cameras,
I have seen also Nikon (Crystal Clear Coat) and Canon (Sub Wavelength Coating) which are also nano tech coatings.
04-16-2013, 05:52 AM - 1 Like   #22
Blue's Avatar
The announced PENTAX D FA 645 90mm HDmacro lens apparently couples both the HD Coating and the Aerobright Coating. This lens was announced in Dec 2012.
This lens is treated with HD Coating*, a newly developed, high grade multi-layer lens coating , which offers higher light transmittance with reduced reflection, to deliver sharp, clear images free of flare and ghosting, even under demanding lighting conditions such as backlight. By coupling this coating with the PENTAX-exclusive, high grade Aero Bright Coating,** this lens optimizes light transmittance while minimizing refraction.
04-16-2013, 06:00 AM   #23
PEG Moderator
Kerrowdown's Avatar
Interesting read this thread, didn't realise the was quite such a variance in all the coatings.
04-16-2013, 06:10 AM - 1 Like   #24
Here is a little from an Asahi Pentax lens catalog 06101, I think from 1961.
04-16-2013, 06:17 AM   #25
Blue's Avatar
QuoteOriginally posted by wombat2go Quote
Thanks Wombat. That is more likely from the early 70s though, perhaps 1971 since that is when Asahi Optical unveiled the S-M-C.
04-16-2013, 06:37 AM   #26
You are correct, as confirmed by Herbert Keppler page 95
04-16-2013, 07:09 AM - 1 Like   #27
I have a magazine from 1974 where a similar comparison is made. A picture of a woman and a building with flare and one without. The difference is stunning.
Also stunning is that they thought nobody would notice how the perspective is ever-so-slightly not identical, enough to have the sun covered by the girl.
05-03-2013, 12:18 PM   #28
what do you think my is the coating of my pentax 50mm 1.4 ??
JUST CURIOUS
thanks
05-03-2013, 12:37 PM   #29
MSM
MSM's Avatar
QuoteOriginally posted by mingkoy Quote
JUST CURIOUS
thanks
@mingkoy: Which 50 mm/1.4? Pentax has made a few over the years. The type of coating is often in the name of the lens such as the 'Pentax SMC FA 50 mm f/1.4'
mark
05-03-2013, 04:22 PM   #30
Blue's Avatar
JUST CURIOUS
thanks
Based on what your profile says, you have an SMC 50/1.4 so that means it has the SMC coating. The Super Tak 50/1.4 had different coatings. There are no 50/1.4 with the Ghostless , Aero or HD coatings, at least yet.
coatings, da*, images, k-mount, lens, lenses, light, pentax, pentax lens, range, slr lens, sp, surface
DA* Lens coatings... sebberry Pentax SLR Lens Discussion 3 12-22-2009 12:28 AM
Tamrac Aero Speed Pack - Anyone have one? JohnBee Pentax Camera and Field Accessories 6 11-28-2009 01:50 PM
Multi coatings & CA Query FruitLooPs Pentax SLR Lens Discussion 14 10-12-2009 12:16 AM
Different Coatings on SMC Pentax-F 35-70/3.5-4.5 ?? arpaagent Pentax SLR Lens Discussion 2 12-16-2008 11:52 AM
All times are GMT -7. The time now is 09:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
