Tamron 70-200 F2.8 vs Sigma 70-200 F2.8 EX DG HSM II - Battle of the older telephotos
Posted By: JinDesu, 09-17-2014, 01:10 PM
My friend recently told me that he was planning to sell his Sigma 70-200 F2.8 EX DG HSM II lens, and I saw an opportunity to borrow it to make a comparison review before he sold it off. And thus, a long and arduous task of trying to keep everything comparable begun.
The lenses:
Sigma 70-200 F2.8 EX DG HSM II - Link to PF's user reviews/specifications (Not to be confused with the most recent Sigma 70-200 iteration)
Tamron 70-200 F2.8 - Link to PF's user reviews/specifications
My full album of sample shots and comparisons. Includes full size image links shot on the k-3 (24MP)
Physical comparisons
The Tamron 70-200 F2.8 is surprisingly longer than the Sigma 70-200 F2.8 HSM II. I always thought the Tamron was the smallest of the bunch, compared to Sigma, Canon, Nikon, and even Pentax. That being said, the Tamron comes in at 200g less than the Sigma (and that weight can be seen in the girth).
The Sigma has the older crinkle finish. It felt quite solid, and the zoom and focus rings were smooth. The focus ring was especially nice to use in comparison to the Tamron, which has a AF/MF clutch by shifting the focus ring forwards and backwards. In addition, the manual focus of the Tamron had a little more friction and was not as enjoyable. The Tamron has a deeper/longer/more substantial hood, and I believe that it is a better hood. It certainly gives the lens a better look when compared side to side:
Both lenses have 77mm front elements that are non-rotating or extending. The lenses are (as typical of lenses in this class) internal focus and internal zoom. They both mounted nice and tight on my k-3, and I felt no wobble in any way on either lens. Both lenses have the classic positioning of zoom ring closer to the body, and focus ring closer to the front. This was changed in the most recent iteration of the Sigma, where the focus ring and the zoom rings swapped (I assume for faster autofocus).
On both lenses, the hoods are reversible and help with storing the lens. There aren't any discernible differences between the tripod feet. Both tripod feet rings have markings to indicate 90 degree positions, and the knobs are easy to use and tighten. I had no issues mounting either lens onto my tripod, and the feet stayed on nicely even when shifting the lens around.
I will comment that both Tamron and Sigma makes some really terribly difficult to use rear caps. Tamron's requires you to align the correct dot before turning. Sigma's turns the other way. Pentax's rear caps are significantly easier to use and I would go get myself a bunch of those just to replace the OEM ones from Sigma and Tamron.
Since the Tamron is my lens, I can comment on durability. I have used the lens since 2011 and it has continued to chug along. I had one scary spell when the lens had some issues autofocusing (I took it on a flight to Malaysia), and I couldn't solve the reason. After a month, the issue went away and the lens performance never changed. I've dinged it many times and the body is extremely resilient. It is super susceptible to dust, so there's quite a lot inside - but I never noticed any optical issues caused by the dust. So now that it is late 2014, the only problem I have is that the hood quick-connect mechanism is a bit loose and the lens hood does not stay on as tightly. I assume it's loosened on the hood itself and not on the lens hood-ring.
Autofocus performance:
Well, here is where people would assume that Tamron would lose out to the Sigma. From my experience with both lenses, I would disagree. I didn't do much of an AF test as I don't have the tools to make a consistent and repeatable test, so this section is just my opinion.
My first camera was the Pentax k-x, and I used my Tamron 70-200 on that camera until this year when I got a k-3. On the k-x, it was somewhat slow to focus - a person walking towards me would be a difficult shot to get. On everything else, the lens focused well (with a little adjustment).
Fast forward to now, and on my k-3 the Tamron is fantastic. I can track people walking towards me, birds flying towards and perpendicular to me, and I can lock onto a target very quick. It's noisier than the Sigma of course (microadjustments is quiet, but racking from near to far and vice versa is loud enough to disturb animals), but it is by no means slow. And on the k-3, it barely hunts. I've shot in bright and dim conditions, and the Tamron is a new beast with the k-3.
The Sigma is no slouch on the k-3 either. Everyone knows of how the Sigma HSM is better than Pentax's SDM (or at least, that's the note I gather from this forum) - and I will admit, my Sigma 50 F1.4 HSM was faster focusing and had less hunting than my DA*55 F1.4. The Sigma was quick to focus and very silent. I sometimes wouldn't know if it actually performed the microadjustment, because there was no sound. When it hunts, it hunts very quickly (the image just goes in and out of focus so fast). It is fast enough for tracking a person walking towards me, and the limitation is mostly the k-3.
So for both lenses, I would say the AF is mostly equal in speed and consistency, with the edge going to the Sigma for quietness.
Bokeh!All my photos were edited for brightness and white balance only - I tried to get the white balance similar so that it doesn't bias anyone when dealing with sharpness. No sharpening was added to the images - but I did increase the clarity a little (on par with what I do for all my photos). All shots were processed in Lightroom 5.0.
So I am going to start with bokeh first, because the lens resolution section is long and arduous, and anyone who finishes through it is going to be too tired to look at anything else.
My impression after having looked at both lenses is that the Tamron has a marginally better bokeh overall, but the two of them create very smooth backgrounds that it doesn't really make a difference which lens to use. Their effect on specular highlights is not unpleasing, and at 200mm they make the background melt into a blur. This may be surprising as the Tamron is highly touted for bokeh, but the Sigma isn't often mentioned. I know that my DA*55 F1.4 had better bokeh than my Sigma 50 F1.4, but in the 70-200 - the bokeh is lovely and I don't really have any issues with it.
Tamron:
Sigma:
Full size link: https://farm4.staticflickr.com/3865/15264094812_cb54ae826f_o.jpg
Please see the album linked in the beginning for more bokeh samples.
Flare performance:
I tried to get the flare performance test to be the same framing for both lenses, but the Sigma (I think) changes the frame a little because it is slightly shorter than the Tamron. As such, the flare performance test is shorter and less comprehensive compared to the rest.
My opinion from the test is that the Tamron performs remarkably better on flare. In all scenarios, the Tamron either had less flare, or less distracting flare. I attribute it partly to the hood and to the better coatings perhaps.
Tamron (first) and Sigma (second) at 70mm F2.8:
Tamron (first) and Sigma (second) at 200mm F2.8:
Please see the album linked in the beginning for more flare samples.
Image Quality
And now we come to the section that most people (or at least, in my head) care about. Now to preface this section, I did this just for fun and I do not have all the tools to make perfect comparisons between the lenses. For one, the Tamron focuses closer than the Sigma, and for another, the Sigma has a tendency to frame a little more at the same camera distance. So I did my best to keep everything as similar as possible, and I know I made one or two focus mistakes in the whole set. Also, I didn't bother doing corner/edge performance because I don't have a subject flat enough to do that.
When doing this test, while there are some differences between the lenses wide open, they pretty much evened up by F4 at any aperture/focal length. By F5.6, they were pretty much equal and I would say both lenses are extremely sharp. I know that my Tamron 70-200 is sharp enough to resolve pores on half body portraits, so it's definitely sharp enough for my use. For a professional environment, I find both lenses sharp enough to get the job done (unless you want to compare it to a prime, but that's a different animal).
At F2.8 and their sharpest focal lengths, I would say that both lenses resolve as much detail as my DA*55 F1.4 when stopped down to F2. They are definitely not lacking in detail.
I will break down the comparisons into three parts. In each part, I will show the test image and a link to the full size image for perusal, because I can't link full size images to PF. The test image is a side by side comparison of center 100% crops. The full images are on my flickr in the album as linked at the beginning of this post. Each image has a full size link in the comments, so I am presenting everything up to scrutiny (including how dusty my area is).
Close focus (minimum FD for Sigma, close to minimum FD for Tamron)
At 70mm-135mm, I find the Tamron to have an edge over the Sigma at F2.8. They even out around F5.6. The difference is noticeable, but the Sigma isn't bad. At 200mm, the Tamron's performance drops significantly, introducing a lot of bloom. I attribute bloom to lack of contrast, and the hood not being size for 200mm (otherwise it'll vignette). As far as sharpness goes, the Sigma will win this round, but they both equalize around F4, and become very sharp at F5.6.
This test is also where I think I got the Tamron 200mm F2.8 focus slightly off, which can make a big difference. On the other hand, at minimum focal distance - the Tamron was always a little weak in my experience.
https://farm4.staticflickr.com/3836/15264095392_a9ef9014a1_o.jpg
https://farm6.staticflickr.com/5586/15077915917_623b71c6ec_o.jpg
https://farm6.staticflickr.com/5572/15264486505_9f400e0816_o.jpg
https://farm4.staticflickr.com/3887/15077915667_d99a46151c_o.jpg
Medium focus distance (About 12', or good for portraits)
At the medium focus distance, the IQ of the lenses followed a similar pattern to the close focus shots. From 70-135mm at F2.8, the Tamron is sharper at the center than the Sigma. At 70mm, the Sigma gets an edge at F4, but then they both tie up at F5.6. From 100-135mm, the Sigma ties up at F4. At 200mm F2.8, the Tamron and Sigma look about equal in performance. The Sigma shows a bit more contrast, but I don't think it's resolving more. By F4, they are both very sharp. I would say that at 200mm, the Sigma has an edge overall from F2.8-F8, while the Tamron wins out similarly at 135mm.
https://farm6.staticflickr.com/5565/15077782140_b11be2a045_o.jpg
https://farm4.staticflickr.com/3866/15077917077_a665f5fe4f_o.jpg
https://farm6.staticflickr.com/5558/15264096262_9b889b5ea0_o.jpg
https://farm4.staticflickr.com/3852/15261389501_dea802a07f_o.jpg
Semi-far focus distance (About 22-24', or where I take pictures of animals and stuff)
In the semi-far distance test, I found the Tamron to start outperforming the Sigma wide open at all focal lengths. i skipped the 100mm focal length in this test, but I could see a clear difference between the Tamron and the Sigma at F2.8 in the 70mm, 135mm, and 200mm range. The Sigma ties up around F4, but I would give the general edge to the Tamron at 70mm and 200mm, and the Sigma wins a little at 135mm.
https://farm4.staticflickr.com/3901/15241474896_8cefb225d7_o.jpg
https://farm6.staticflickr.com/5553/15264487095_2c24aaa0b2_o.jpg
https://farm4.staticflickr.com/3909/15264486785_f05a34106e_o.jpg
Infinity focus distance (About infinity, or where I take pictures of far away things)
I didn't take this test. I didn't really have a location where I could set up and do a consistent test in this range. I apologize for my laziness, but I think the above tests give a good indication of what the lenses can do. In addition, I've shot infinity shots with my Tamron before, and I find that the atmospheric aberrations and the heat effects do way more to the image than the lens will. Also, people don't tend to take infinity shots with these lenses at F2.8, so it may be a moot point anyways.
REMEMBER, EACH SAMPLE SHOT IS FOLLOWED BY A FULL SIZE LINK. THE SAMPLE SHOTS WERE SCALED DOWN TO BE POSTED ON PF.
Chromatic Aberrations/Coma/Vignetting
I must apologize that I do not have a way to test for CA/coma easily. Neither lens showed much CA in my testing, with the exception of LoCA in the OOF areas. As far as vignetting goes, I have not been bothered by either lens. Cycling between the photos in my Flickr album will give an example of how the vignetting shows up, but I didn't have a large flat white wall to do the test with.
Conclusion (i.e. which one is better?)
Well, I don't know. The Tamron is priced at $769 at B&H right now, and used is typically $450-500. The Sigma isn't even on B&H anymore for Pentax, and was replaced with a newer APO EX DG version that is also not available in stores for Pentax. The newer version is said to be sharper than the HSM II, and the retail price was around $1199 when I last saw it. The HSM II version was probably that price before it got replaced, and I see it used at around $800 now. So IQ/value wise, the Tamron definitely wins. Its sharpness practically the same (wins some, loses some) to the Sigma, but at $300-500 less it is a bargain. It's also the cheapest of the 70-200s, and from everything I've read on this forum, it and the Sigma are amongst the top performing.
I've used the Tamron for 3 years now and I always enjoy using it. It has a nice solid body, it has fast AF on my k-3, it hasn't let me down yet, and Tamron gives a nice 6 year warranty (I think Sigma is 2 years for non-EX, and 4 years for EX lenses). The Sigma's good points are the silent autofocus and the smoother focus/zoom rings. If I had the money to spend, I would go with the Sigma for the silent autofocus. Or even for the newer version, which is supposed to be sharper. If I were on a budget, or I didn't care about silent autofocus, the Tamron would be a sure buy for me.
Of course, there's also the DA*50-135, DA*60-250, the Tokina 80-200 F2.8 ATX, the Pentax FA*80-200 F2.8, and the Sigma 50-150 F2.8 EX DG HSM. There is a Pentax official review of the FA*, the newer Sigma (APO EX DG), and the Tamron at this link, but it doesn't provide much info on the image quality. To me, I think all these lenses will have similar sharpness and the overall difference is the features and handling.
Let me know if there are any questions and I will try to answer them to the best of my ability. I am limited by the fact that I had returned the Sigma to my friend for him to sell.
Also for convenience, so you don't need to scroll all the way back up, the link to the album is: https://www.flickr.com/photos/jindesu/sets/72157647685646442/
09-29-2014, 11:01 PM   #31
schnitzer79's Avatar
wow great detailed comparison.thanks for that
10-02-2014, 09:27 PM   #32
JinDesu's Avatar
QuoteOriginally posted by ElJamoquio Quote
No way I would sell my Tamron for less than $600. It's a bargain at $600. It gets bad reviews at non-Pentax sites because the screwdrive is so slow on Nikons and Canons.
I tried a copy on a Nikon D7000 and it was three-legged-dog-slow.
Is it actually screw drive on the CaNikons? I remember once reading that they had a cheap/slow micromotor for the CaNikon versions because the cheaper CaNikon bodies didn't have internal motors (hence not being compatible with the older actual screw drive lenses).
10-02-2014, 09:53 PM   #33
yes...
10-04-2014, 03:33 PM   #34
JimmyDranox's Avatar
One thing I have failed to mention, and is an important one. Tamron works in AF mode with almost any AF TC, while Sigma didn't work. Not even with their own TC. So, a Tamron 70-200mm F2.8 can be transformed in a 140-400mm F5.6 AF lens, with good results, while Sigma can work like this only in manual focusing. Don't ask me why, but even the Sigma site tell the same story. Of course, this is only for Pentax K mount. On other cameras, Sigma 70-200mm F2.8 HSM II works with TC in AF mode.
10-04-2014, 04:09 PM   #35
VisualDarkness's Avatar
QuoteOriginally posted by JinDesu Quote
Almost no new lenses uses the Nikon screwdrive, only old versions like the non-G version of the 50mm. Tamron and Sigma both use in-lens motors for Nikon as they otherwise would alienate most users of the brand, only the top models got the in-body screw.
Canon got no mechanical connection at all so they have to have a motor.
10-05-2014, 06:04 PM   #36
Something worth noting about the Sigma HSM II is that it is a full-frame lens. One thing this means is that the lens hood is too small for optimal use on APS-C and not as effective as it could be. The HSM II is quite vulnerable to flare between 70 and 135mm, and the standard hood does little to help protect against this. It needs to be deeper.
For the latest version of the Sigma 70-200 (the EX DG APO OS HSM), Sigma include a lens hood extender if you want to use the lens on APS-C (Sigma HA 850-01 - pic related) that should also fit on the HSM II.
Mine hasn't arrived yet (got one off eBay the other day), but the hood extender for the Sigma 85mm might also work. I've also used the deeper hood from the DA*300mm with success on the HSM II, instead of the standard HSM II hood. It doesn't fit the bayonet mount of the 70-200 perfectly, but it forms a reasonably snug pressure fit.
10-05-2014, 06:39 PM - 1 Like   #37
Stavri's Avatar
It is true, that little hood extension is needed. Sigma 85mm f1.4 has also a similar setup, two hoods, one FF and the APS-C addition. However (I've confirmed this myself) the 85mm f1.4 APS-C hood extension doesn't fit the 70-200mm f2.8 HSM II (so you need the buy the dedicated one)
10-05-2014, 07:12 PM   #38
QuoteOriginally posted by Stavri Quote
Aha. Thanks for confirming that. How silly of Sigma not to have the 85 f1.4 hood extender work on a lens like the HSM II. Both lenses accept 77mm filters so the bayonet size should be the same.
Another option is of course to use a 77mm screw-in lens hood. Ebay has lots of cheap screw-in 77mm hoods in metal and rubber that could also work OK, I guess, on the HSM II.
10-05-2014, 08:28 PM   #39
Stavri's Avatar
I agree, I also thought I'd be a no brainer. The APS-C hood extension is identical for the Ex 50mm f1.4 and 85mm f1.4, which seem to be newer designs. The Sigma Ex 70-200mm f2.8 HSM II seems to use a older hood bayonet (which don't match the other two) The OS version of the 70-200mm f2.8 might be able to use a different hood extension (identical to the 50 and 85 f1.4) since its a newer design, but Its pure conjecture since I don't own that version at this point.
10-05-2014, 10:26 PM   #40
...Its pure conjecture since I don't own that version at this point.
My copy of the Sigma HA 850-01 hood extension is on it's way from an ebay seller in Japan. When it arrives I'll try it out on the HSM II and report back. Fingers crossed.
10-05-2014, 10:34 PM   #41
Just to be clear - every 70-200 made by any manufacturer, to my knowledge, is a full-frame lens.
10-30-2014, 05:46 AM   #42
khanhtung's Avatar
Great job JinDesu!
this is exactly what i interest.im going to get myself the Tamron.
Thanks again!
11-02-2014, 10:47 PM   #43
My Sigma HA 850-01 Hood Adapter arrived today, via a very slow boat from Japan.
I can now confirm that this hood adapter fits perfectly on the Sigma 70-200 HSM II.
Yay! Less chance of lens flare when shooting in the direction of stadium spotlights.
So it is confirmed that the new (OS) and older (HSM II) Sigma 70-200's share the same bayonet.
11-03-2014, 12:22 AM   #44
Good information. Thanks.
11-03-2014, 02:35 AM   #45
That's interesting! Though the adapter costs over 50 here in Sweden, not worth it for a lens with bubbles in the front element.
f2.8, focus, hsm, image, k-3, lens, lenses, sigma, tamron, test
For Sale - Sold: Sigma 70-200 F2.8 II apo ex dg macro hsm terihanright Sold Items 3 11-22-2013 01:06 PM
Sigma - 70-200/2.8 EX DG OS APO HSM IF **** VS ****70-200/2.8 EX DG II APO Macro HSM lightningthief Pentax SLR Lens Discussion 13 10-19-2012 01:46 AM
Considering the Sigma 70-200mm 70-200 f/2.8 EX DG MACRO HSM II sbluems Pentax SLR Lens Discussion 7 03-22-2010 10:15 AM
Sigma 70-200 F2.8 EX DG MACRO HSM Peter Zack Pentax SLR Lens Discussion 60 01-02-2008 06:08 PM
All times are GMT -7. The time now is 10:03 PM. | See also: NikonForums.com, part of our network of photo forums!
