FF lenses for the K-1 that can be bought new
Posted By: Class A, 02-20-2016, 07:36 AM
We all know there is a ton of great FF glass available on the used market that will work great with the K-1.
However, which are the currently available FF lenses (in current catalogues of lens manufacturers) that can be used with the K-1?
Below is a list that started with an initial compilation I did and then attracted a number of later additions by several contributors. There may be still some missing and please post to this thread with information about the lens (but please make sure the lens is in production). I'll then add it to the list.
If you have used any of the listed lenses on the K-1 and find that they do not perform like a proper FF lens, please post to this thread as well. There are some DA (APS-C) lenses included which have been tested as "good for FF" on film cameras but due to differences between film and digital sensors, there may be a few surprises (although I tried to be conservative and only included those that would be true surprises if they failed the "K-1 test".)
Thanks in advance.
P.S.: I realise that there is also another current FF lenses overview but the latter contains discontinued lenses and I think there is value in maintaining a list of lenses that can be bought brand new. Not everyone is prepared to go hunting on the used market. A very nice feature of the aforementioned alternative compilation is that many third-party FF lenses can found organised in roadmap-style charts.
Regarding the suitability of certain DA (APS-C) lenses, I included a few that a truly FF capable based on their design and user reports. There is a far larger number of DA lenses with OK to marginal performance on an FF camera. These have not been included in this list, even though some users may find them acceptable (in particular using the K-1's 1:1 crop mode). A useful resource on the performance of DA lenses on an FF camera is falconeye's "DA lenses on Full Frame: Test shots" thread.
Pentax
Zooms
HD Pentax-D FA 15-30mm F2.8 ED SDM WR
HD Pentax-D FA 24-70mm F2.8 ED SDM WR
HD Pentax-D FA 28-105mm F3.5-5.6 ED DC WR
HD Pentax-D FA* 70-200mm F2.8 ED DC AW
HD Pentax-D FA 70-210 mm f/4 ED SDM WR
HD Pentax-D FA 150-450mm F4.5-5.6 ED DC AW
SMC Pentax-DA* 60-250mm F4 ED [IF] SDM
(some vignetting in particular at 250 but very usable;
some owners replace an internal baffle to reduce the vignetting)
Primes
HD Pentax-D FA 21mm f/2.4 ED Limited DC WR
HD Pentax-FA 31mm f/1.8 Limited
HD Pentax-FA 43mm f/1.9 Limited
HD Pentax-FA 77mm f/1.8 Limited
HD Pentax-FA 35 mm f/2
SMC Pentax-FA 50mm F1.4
HD Pentax-D FA* 50mm F1.4 SDM AW
HD Pentax-D FA* 85mm F1.4 SDM AW
SMC Pentax-D FA 50mm F2.8 Macro
SMC Pentax-D FA 100mm F2.8 Macro WR
APS-C Primes, performing well on FF
SMC Pentax-DA 35mm F2.4 AL
SMC Pentax-DA 50mm F1.8
SMC Pentax-DA* 55mm F1.4 SDM
SMC Pentax-DA* 200mm F2.8 ED [IF] SDM
SMC Pentax-DA* 300mm F4 ED [IF] SDM
HD Pentax-DA 560mm F5.6 ED AW
Sigma (as long as current stock lasts)
Zooms
70-300mm F4-5.6 APO DG Macro
70-300mm F4-5.6 DG Macro
50-500mm F4.5-6.3 APO DG OS HSM
Primes
15mm F2.8 EX DG Diagonal Fisheye
28mm F1.8 EX DG ASP RF
35mm F1.4 DG HSM | A
85mm F1.4 EX DG HSM
300mm F2.8 EX APO DG (HSM)*
500mm F4.5 EX DG APO (HSM)*
Tamron
Zooms
SP AF 28-75mm f/2.8 XR Di LD Aspherical [IF] Macro
AF 70-300mm f/4-5.6 Di LD Macro 1:2
Samyang
Primes
12mm F2.8 ED AS NCS Fisheye
14mm F2.8 ED AS IF UMC
20mm F1.8 ED AS UMC
24mm F1.4 ED AS IF UMC
24mm F3.5 ED AS UMC TILT/SHIFT
35mm F1.4 AS UMC
50mm F1.4 AS UMC
85mm f/1.4 AS IF UMC
100mm f/2.8 Macro
135mm f/2 ED UMC
(Most, if not all, of the above are also available as "Cine" lenses that for instance feature click-less apertures.)
500mm MC f/6.3 Mirror (best Samyang mirror lens, decent sharpness but awful bokeh)
500mm MC IF f/8 Mirror
800mm MC f/8 Mirror
500mm MC f/8 Preset (not mirror, a little bit long but very light with decent sharpness)
650-1300mm f/8-f/16 (long and light, almost usefull as a monopod)
(The above comments come courtesy of banep, thanks!)
Schneider-Kreuznach
Primes
PC-TS 4.5/28MM Super-Angulon Tilt/Shift
PC-TS 2.8/50MM Super-Angulon Tilt/Shift
PC-TS 4.5/90MM Makro Symmar Tilt/Shift
Laowa (Venus Optics)
Primes
12mm f/2.8 Zero-D
15mm f/4.5 Zero-D Shift
15mm f/4.5R Zero-D Shift
15mm f/4 1:1 Macro
20mm f/4 Zero-D Shift
25mm f/2.8 Ultra Macro (2.5-5 x magnification, no infinity focus)
60mm f/2.8 2:1 Macro (2x life size magnification)
100mm f/2.8 2x Ultra Macro APO
105mm f/2 (t/3.2) STF (Smooth Transition Focus)
Irix
Primes
Irix 15mm f/2.4
Irix 11mm f/4
Irix 21mm f/1.4 Dragonfly
Irix 30mm f/1.4 Dragonfly
Irix 45mm f/1.4
Irix 150mm f/2.8 Macro 1:1 (Dragonfly)
AraxFoto
Arax 35mm f/2.8 Tilt & Shift
Arax 80mm f/2.8 Tilt & Shift
Meyer-Optik Görlitz (liquidated in 2018, but revived in 2020)
Primes
Lydith 30mm f/3.5
Trioplan 35+ f/2.8
Nocturnus 50 mm f/0.95 (DSLR variant)
Primotar X 50mm f/2.8
Trioplan 50mm f/2.9
Primoplan 58mm f/1.9
Primoplan 75mm f/1.9
P75 II (advanced version of the Primoplan 75)
Somnium II 85mm f/1.5
Lydith 30 f3.5 II
Trioplan 35mm f/2.8 II
Trioplan 50 f/2.8 II
Biotar 58mm f/1.5 II
Biotar 75mm f/1.5 II
Primoplan 58mm f/1.9 II
Primoplan 75mm f/1.9 II
Trioplan 100 f2.8 II
Apo-Makro-Plasmat 105mm f/2.7
net SE (-> resurrection of Meyer-Optik Görlitz, Emil Busch and Oprema Jena lenses, liquidated in 2018)
C. P. Goerz Citograph 50mm f/2.8 (currently a Kickstarter project)
Emil Busch Glaukar Anastigmat 97mm f/3.1 (scaled version of the 1910 Glaukar 210mm f/3.1, a lens for 8x10cm and 13x18cm field cameras)
Oprema Jena Biotar 75mm f/1.5 (re-edition of the Carl Zeiss Biotar 75mm f/1.5 (Willy Merté, 1938))
Zeiss (M42 mount lenses; require an M42 -> K-mount adapter, the genuine Pentax adapter supports infinity focus)
ZEISS Distagon T* 2,8/25
ZEISS Distagon T* 2/28
ZEISS Distagon T* 2/35
ZEISS Planar T* 1.4/50
ZEISS Planar T* 1.4/85
Zhong Yi Optics
Primes
Mitakon 20mm f/2 4.5x Super Macro
Mitakon Creator 35mm f/2
Mitakon 85mm F1.2
Mitakon 85mm F2
Mitakon Creator 85mm f/2.8 1-5x Super Macro
Mitakon Creator 135mm f/2.8 version II
Mitakon Speedmaster 135mm F1.4
Lensbaby (as long as stock is available, K-mount discontinued in 2019)
Primes
Burnside 35 (with variable vignetting)
Velvet 28
Sol 45
Velvet 56
Twist 60
Velvet 85
Optic Swap System
Dongzheng Optics
Primes
Kerlee 35 mm f/1.2 (info)
Lomography
Primes
Naiad 15mm F3.5 Art (135° FOV, 1cm close focusing)
Lomogon 2.5/32 Art Lens
Daguerreotype Achromat 64mm f/2.9 Art (info)
Neptune Convertible Art Lens System
Kenko
Primes
Kenko 400mm f/8 N II S (via T-mount adapter)
KMZ (sometimes difficult to buy outside Russia; some are easily available though)
Primes
MC Zenitar-K 16mm f/2.8 (fisheye)
MC Helios 77K-4 50mm f/1.8
MC Zenitar-K 50mm f/1.9
MC Zenitar-K 50mm f/2
MC Helios 44K-4 58mm f/2
MC Apo Telezenitar-K 135mm f/2.8
MC Apo Telezenitar-K 300mm f/4.5
Zooms
MC Variozenitar-K 25-45mm f/2.8-3.5
02-20-2016, 04:32 PM - 1 Like   #31
Both those lenses only got a "+" rating on the "DA lenses on Full Frame: Test Shots" thread. A single "+" rating means they require stopping down to work on the K-1 and I hence do not consider them as true FF lenses.
You have adopted a strange perspective indeed on what qualifies a lens as FF.
Look at the level of vignetting of some pure FF lenses for Canon, Nikon, Sony FF sometime. High vignetting is almost standard on FF.
And if the Sigma 35 f1.4 (with it's -3.16 EV, 66% light fall-off at the edges wide-open) on full-frame were to display more vignetting on the K-1 than a DA 40 wide-open, would that render the Sigma an invalid FF lens?
So lets wait and see about some of these DA lenses. DA40 will, I suspect, perform fine on the K-1.
02-20-2016, 07:12 PM   #32
monochrome's Avatar
@beholder3
FA Limited production has started again for sure? Wow! That's great news!!
02-20-2016, 07:23 PM   #33
Class A's Avatar
I would only include lenses that are in production.
Yes, I 100% agree.
The category "can still be bought new but is out of production" does not qualify as "current" or "can be bought new (easily) to me. For those lenses it is just a matter of time when they will become true "legacy" lenses.
Add the laowa 15mm, Mitakon 85mm, and Schneider 24, 50, and 85 T/S to your list .
Thanks!
I think you've got the focal lengths a bit mixed up but due to your pointer I looked up the Schneider-Kreuznach page and added the K-mount lenses I found.
BTW, I believe the Sigma 24 and 28 primes are discontinued too.
According to Sigma, the 28mm is still being offered for K-Mount (-> 28/1.8). I swear I've seen the 20mm and the 24mm primes offered for K-mount as well (and they are not showing in their "discontinued" list) but I cannot find them anymore so I deleted them from the list above.
Tamron 28-300 should still be available.
Yes, it is. thanks!
Not sure how I missed it because I went to Tamron's website to find all the others.
P.S.: The Sigma 24-70mm F2.8 is not currently offered for K-mount. You may want to update your list.
02-20-2016, 07:34 PM   #34
Digitalis's Avatar
It would be a spectacular mistake for pentax not to put the FA Limiteds back into production.
The Leica Noctilux 50mm f/0.95 has slightly more vignetting than that, and it is considered to be an excellent Full format lens..
02-20-2016, 07:44 PM   #35
monochrome's Avatar
Yes, but that was the first affirmative statement I have read.
02-20-2016, 07:47 PM   #36
Class A's Avatar
QuoteOriginally posted by banep Quote
There are a few additional exotic Samyang telephoto lenses.
Thanks a lot for these!
For my Samyang compilation I went to Samyang's website and included all FF lenses for K-mount, but missed the T-mount section (which only require a T2 adapter).
In addition to that Lensbaby Composer Pro is probably also full frame lens and it is available in K mount.
Thanks!
The only model I could confirm to be truly FF is the Velvet 56 and I've added it.
Thanks again!
02-20-2016, 07:58 PM   #37
Class A's Avatar
For DA lenses I consulted the "DA lenses on Full Frame: Test Shots thread" thread which contains reports from users who tested a multitude of APS-C lenses on film cameras.
I accepted those rated "+++" and "++" but drew the line before "+".
The motivation of this list is twofold:
  1. Provide a resource for anyone interested in looking which FF lenses are available for the K-1, and
  2. dispel the myth that the K-1 is lacking a proper FF lens selection.
For the latter aspect, I don't want any "ifs and buts". All lenses included should be proper FF lenses not something that can be used at certain focal lengths or for a certain aperture range or that yields OK IQ when cropping in a bit.
The ratings of the aforementioned thread are not based on vignetting only. The "+" rating in particular mentions diminished IQ in the corners (meaning more IQ loss than is normal for an FF lens).
Exactly.
I believe that those I already included are safe, i.e., will be confirmed (often based on construction principles, not just on user testing).
For others (like the DA40 and DA70), let's wait till we know how they perform with a digital sensor before we include them in a list of "current FF lenses".
02-20-2016, 09:58 PM - 1 Like   #38
The SamYang Cine lenses (and the Rokinon clones) could also go on this list. Most, if not all of them, are available for Pentax K. That might add another dozen lenses to the K-1 compatible list.
These Cine lenses are near identical to the 'Photo' series SamYang's, except for the click-less aperture and other cine-friendly external hardware features, but are generally newer build, and hence may have some subtle optical differences compared to the 'Photo' series lenses. (DxO Optics Pro certainly thinks there are differences, from experience).
02-20-2016, 10:08 PM   #39
Class A's Avatar
Yes, but I refrained from adding them, as I believe they are just variants of the regular "photo" lenses.
I'll add a comment, though.
Thanks.
02-20-2016, 10:44 PM   #40
True, but they exist as completely seperate products, and usually with different prices too in store. Build quality also seems to be better than 'normal' SamYangs, FWIW.
02-20-2016, 11:05 PM   #41
Upon doing a little bit of research, it looks like there are at least 5 different options from LensBaby in the K-mount. I'll be adding those to the third-party database shortly.
Also, I'm sure I got my Schneider lenses mixed up as I was on the go
02-21-2016, 12:05 AM   #42
The Sigma 12-24mm f4.5-5.6 EX DG IF HSM Aspherical in Pentax mount is available new on Amazon.com
02-21-2016, 01:37 AM   #43
I still think it makes sense to include what people who want a FF lens can buy globally. Hiding a lens which I can easily buy brandnew is not helping the reader.
EDIT: My simple, clear-cut, "no grey zone" criterion is whether the lens manufacturer includes the lens in their current catalogue. I don't mean "discontinued" in the sense that some online dealers use it. I mean it in the sense that the lens manufacturer has moved the lens from the current catalogue into the legacy catalogue.
If you just follow the catalogue, you need to:
  1. add the 4 A-teleconverters
  2. add the F teleconverter
  3. remove the DA50
  4. remove the DA35
  5. remove the DA*55
because the TCs definitely are in the brandnew catalogue and the primes definitely in the catalogue are listed as not FF compatible.
And I think it should be obvious that this gets silly to a certain degree.
02-21-2016, 02:21 AM - 1 Like   #44
QuoteOriginally posted by beholder3 Quote
remove the DA50 remove the DA35 remove the DA*55
IMO, these should remain listed by they should get their own category called something like "good enough for non-crop usage on full-frame".
According to the US Sigma web site, the 24mm and 28mm are gone, but the 24-70mm is still available.
I doubt that the old EX primes are still in production, but it's hard to say for use when different official websites provide inconsistent info.
Also, this lens supports FF for macro use, which I guess is the intended application:
Venus 60mm F2.8 2:1 Macro Lens Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
A couple new Mitakon additions:
Mitakon Creator 135mm F2.8 Mark II Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
Mitakon Creator 35mm F2 Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
02-21-2016, 03:26 AM   #45
Digitalis's Avatar
I should mention the Hartblei 40mm f/4, 80mm f/2.8, and 120mm f/4 [makro] IF TS Superrotator lenses by Zeiss - all of which are FF capable.
yes, that makes thing distinctly frustrating, even more so when suppliers list lenses as available: when in fact they have been discontinued for some time.
40mm, 50mm, birds, copies, da, discounts, dslr, f1.4, f1.8, f2.8, ff, full frame, full-frame, k-1, k1, lenses, macro, mode, new, pentax k-1, photographer, price, profit, sdm, smc, umc, world, xs, yer
So much for the new FF and MF lenses 2351HD Pentax Medium Format 19 03-08-2016 09:24 AM
Will the new Pentax K1 FF be DOA?? Shanti Pentax Full Frame 87 02-17-2016 06:42 PM
New lenses for the FF ... Pentax and Third Party mikeodial Pentax Full Frame 33 01-14-2016 06:06 PM
Can C-mount lenses (CCTV) be used with the K3 or the K-cameras? Ryuno Pentax K-3 & K-3 II 8 02-22-2015 07:45 PM
DA lenses that could be used on FF toukan Pentax SLR Lens Discussion 4 11-28-2013 05:04 AM
All times are GMT -7. The time now is 12:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
