FF lenses for the K-1 that can be bought new
Posted By: Class A, 02-20-2016, 07:36 AM
We all know there is a ton of great FF glass available on the used market that will work great with the K-1.
However, which are the currently available FF lenses (in current catalogues of lens manufacturers) that can be used with the K-1?
Below is a list that started with an initial compilation I did and then attracted a number of later additions by several contributors. There may be still some missing and please post to this thread with information about the lens (but please make sure the lens is in production). I'll then add it to the list.
If you have used any of the listed lenses on the K-1 and find that they do not perform like a proper FF lens, please post to this thread as well. There are some DA (APS-C) lenses included which have been tested as "good for FF" on film cameras but due to differences between film and digital sensors, there may be a few surprises (although I tried to be conservative and only included those that would be true surprises if they failed the "K-1 test".)
Thanks in advance.
P.S.: I realise that there is also another current FF lenses overview but the latter contains discontinued lenses and I think there is value in maintaining a list of lenses that can be bought brand new. Not everyone is prepared to go hunting on the used market. A very nice feature of the aforementioned alternative compilation is that many third-party FF lenses can found organised in roadmap-style charts.
Regarding the suitability of certain DA (APS-C) lenses, I included a few that a truly FF capable based on their design and user reports. There is a far larger number of DA lenses with OK to marginal performance on an FF camera. These have not been included in this list, even though some users may find them acceptable (in particular using the K-1's 1:1 crop mode). A useful resource on the performance of DA lenses on an FF camera is falconeye's "DA lenses on Full Frame: Test shots" thread.
Pentax
Zooms
HD Pentax-D FA 15-30mm F2.8 ED SDM WR
HD Pentax-D FA 24-70mm F2.8 ED SDM WR
HD Pentax-D FA 28-105mm F3.5-5.6 ED DC WR
HD Pentax-D FA* 70-200mm F2.8 ED DC AW
HD Pentax-D FA 70-210 mm f/4 ED SDM WR
HD Pentax-D FA 150-450mm F4.5-5.6 ED DC AW
SMC Pentax-DA* 60-250mm F4 ED [IF] SDM
(some vignetting in particular at 250 but very usable;
some owners replace an internal baffle to reduce the vignetting)
Primes
HD Pentax-D FA 21mm f/2.4 ED Limited DC WR
HD Pentax-FA 31mm f/1.8 Limited
HD Pentax-FA 43mm f/1.9 Limited
HD Pentax-FA 77mm f/1.8 Limited
HD Pentax-FA 35 mm f/2
SMC Pentax-FA 50mm F1.4
HD Pentax-D FA* 50mm F1.4 SDM AW
HD Pentax-D FA* 85mm F1.4 SDM AW
SMC Pentax-D FA 50mm F2.8 Macro
SMC Pentax-D FA 100mm F2.8 Macro WR
APS-C Primes, performing well on FF
SMC Pentax-DA 35mm F2.4 AL
SMC Pentax-DA 50mm F1.8
SMC Pentax-DA* 55mm F1.4 SDM
SMC Pentax-DA* 200mm F2.8 ED [IF] SDM
SMC Pentax-DA* 300mm F4 ED [IF] SDM
HD Pentax-DA 560mm F5.6 ED AW
Sigma (as long as current stock lasts)
Zooms
70-300mm F4-5.6 APO DG Macro
70-300mm F4-5.6 DG Macro
50-500mm F4.5-6.3 APO DG OS HSM
Primes
15mm F2.8 EX DG Diagonal Fisheye
28mm F1.8 EX DG ASP RF
35mm F1.4 DG HSM | A
85mm F1.4 EX DG HSM
300mm F2.8 EX APO DG (HSM)*
500mm F4.5 EX DG APO (HSM)*
Tamron
Zooms
SP AF 28-75mm f/2.8 XR Di LD Aspherical [IF] Macro
AF 70-300mm f/4-5.6 Di LD Macro 1:2
Samyang
Primes
12mm F2.8 ED AS NCS Fisheye
14mm F2.8 ED AS IF UMC
20mm F1.8 ED AS UMC
24mm F1.4 ED AS IF UMC
24mm F3.5 ED AS UMC TILT/SHIFT
35mm F1.4 AS UMC
50mm F1.4 AS UMC
85mm f/1.4 AS IF UMC
100mm f/2.8 Macro
135mm f/2 ED UMC
(Most, if not all, of the above are also available as "Cine" lenses that for instance feature click-less apertures.)
500mm MC f/6.3 Mirror (best Samyang mirror lens, decent sharpness but awful bokeh)
500mm MC IF f/8 Mirror
800mm MC f/8 Mirror
500mm MC f/8 Preset (not mirror, a little bit long but very light with decent sharpness)
650-1300mm f/8-f/16 (long and light, almost usefull as a monopod)
(The above comments come courtesy of banep, thanks!)
Schneider-Kreuznach
Primes
PC-TS 4.5/28MM Super-Angulon Tilt/Shift
PC-TS 2.8/50MM Super-Angulon Tilt/Shift
PC-TS 4.5/90MM Makro Symmar Tilt/Shift
Laowa (Venus Optics)
Primes
12mm f/2.8 Zero-D
15mm f/4.5 Zero-D Shift
15mm f/4.5R Zero-D Shift
15mm f/4 1:1 Macro
20mm f/4 Zero-D Shift
25mm f/2.8 Ultra Macro (2.5-5 x magnification, no infinity focus)
60mm f/2.8 2:1 Macro (2x life size magnification)
100mm f/2.8 2x Ultra Macro APO
105mm f/2 (t/3.2) STF (Smooth Transition Focus)
Irix
Primes
Irix 15mm f/2.4
Irix 11mm f/4
Irix 21mm f/1.4 Dragonfly
Irix 30mm f/1.4 Dragonfly
Irix 45mm f/1.4
Irix 150mm f/2.8 Macro 1:1 (Dragonfly)
AraxFoto
Arax 35mm f/2.8 Tilt & Shift
Arax 80mm f/2.8 Tilt & Shift
Meyer-Optik Görlitz (liquidated in 2018, but revived in 2020)
Primes
Lydith 30mm f/3.5
Trioplan 35+ f/2.8
Nocturnus 50 mm f/0.95 (DSLR variant)
Primotar X 50mm f/2.8
Trioplan 50mm f/2.9
Primoplan 58mm f/1.9
Primoplan 75mm f/1.9
P75 II (advanced version of the Primoplan 75)
Somnium II 85mm f/1.5
Lydith 30 f3.5 II
Trioplan 35mm f/2.8 II
Trioplan 50 f/2.8 II
Biotar 58mm f/1.5 II
Biotar 75mm f/1.5 II
Primoplan 58mm f/1.9 II
Primoplan 75mm f/1.9 II
Trioplan 100 f2.8 II
Apo-Makro-Plasmat 105mm f/2.7
net SE (-> resurrection of Meyer-Optik Görlitz, Emil Busch and Oprema Jena lenses, liquidated in 2018)
C. P. Goerz Citograph 50mm f/2.8 (currently a Kickstarter project)
Emil Busch Glaukar Anastigmat 97mm f/3.1 (scaled version of the 1910 Glaukar 210mm f/3.1, a lens for 8x10cm and 13x18cm field cameras)
Oprema Jena Biotar 75mm f/1.5 (re-edition of the Carl Zeiss Biotar 75mm f/1.5 (Willy Merté, 1938))
Zeiss (M42 mount lenses; require an M42 -> K-mount adapter, the genuine Pentax adapter supports infinity focus)
ZEISS Distagon T* 2,8/25
ZEISS Distagon T* 2/28
ZEISS Distagon T* 2/35
ZEISS Planar T* 1.4/50
ZEISS Planar T* 1.4/85
Zhong Yi Optics
Primes
Mitakon 20mm f/2 4.5x Super Macro
Mitakon Creator 35mm f/2
Mitakon 85mm F1.2
Mitakon 85mm F2
Mitakon Creator 85mm f/2.8 1-5x Super Macro
Mitakon Creator 135mm f/2.8 version II
Mitakon Speedmaster 135mm F1.4
Lensbaby (as long as stock is available, K-mount discontinued in 2019)
Primes
Burnside 35 (with variable vignetting)
Velvet 28
Sol 45
Velvet 56
Twist 60
Velvet 85
Optic Swap System
Dongzheng Optics
Primes
Kerlee 35 mm f/1.2 (info)
Lomography
Primes
Naiad 15mm F3.5 Art (135° FOV, 1cm close focusing)
Lomogon 2.5/32 Art Lens
Daguerreotype Achromat 64mm f/2.9 Art (info)
Neptune Convertible Art Lens System
Kenko
Primes
Kenko 400mm f/8 N II S (via T-mount adapter)
KMZ (sometimes difficult to buy outside Russia; some are easily available though)
Primes
MC Zenitar-K 16mm f/2.8 (fisheye)
MC Helios 77K-4 50mm f/1.8
MC Zenitar-K 50mm f/1.9
MC Zenitar-K 50mm f/2
MC Helios 44K-4 58mm f/2
MC Apo Telezenitar-K 135mm f/2.8
MC Apo Telezenitar-K 300mm f/4.5
Zooms
MC Variozenitar-K 25-45mm f/2.8-3.5
03-24-2018, 10:24 AM   #106
Thank you. This lens was already part of the list, though (listed as "24mm F3.5 ED AS UMC TILT/SHIFT").
I knew it was on the list. I saw it there, and thought people reading the article might like to know that there's an excellent bargain on it available at the moment.
I hope that wasn't inappropriate.
03-24-2018, 01:07 PM   #107
BruceBanner's Avatar
QuoteOriginally posted by Parallax Quote
Right!
He's a forum member and an anti-Pentax troll.
RiceLow is an Uber anti-Pentax Troll.
ahh... haha, I haven't seen him around/before, I been here a little while now as well. Good to know.
03-25-2018, 12:55 AM   #108
Class A's Avatar
QuoteOriginally posted by Heebie Quote
No, of course not.
I just thought you were suggesting the inclusion of the lens to the list.
04-20-2018, 10:19 AM - 1 Like   #109
Mistral75's Avatar
One more: Venus Optics Laowa 100mm f/2.8 2x Ultra Macro APO.
04-20-2018, 06:55 PM - 1 Like   #110
Class A's Avatar
QuoteOriginally posted by Mistral75 Quote
Thanks!
This time, I've been quicker and had added the lens before, but I'm very grateful for the updates!
04-21-2018, 01:19 AM - 1 Like   #111
Mistral75's Avatar
One more: Meyer Optik Görlitz Apo-Makro-Plasmat 105mm f/2.7
Pentax K and M42 mounts added as per update #1: Glorious Dr. Rudolph's APO Plasmat Lens 105mm f2.7 returns by Meyer Optik USA — Kickstarter
04-25-2018, 11:02 AM   #112
Tamron
Zooms
SP AF 28-75mm f/2.8 XR Di LD Aspherical Macro
SP AF 70-200mm f/2.8 Di LD Macro
I have both of these lenses. The 28-75 is really nice. I've never noticed vignetting around the edges... the 70-200 on the other hand, has pretty significant vignetting on K-1 (and Z-1p 35mm) It can be adjusted for in Lightroom/Photoshop/Camera Raw, but it would be nice if it didn't need it.
One note on my 70-200.. I bought it back a fair few years now, and I think it might be several revisions old... and it is still a nice lens even with the vignetting.
04-25-2018, 02:16 PM   #113
Class A's Avatar
Thanks for the input. You weren't suggesting that this lens shouldn't be part of the list, though, right?
It is not unusual for FF lenses to show levels of vignetting that one isn't used to when shooting FF lenses on APS-C cameras, for instance.
The Tamron 70-200/2.8 is definitely a bona fide FF lens, it has been sold as an FF lens for other mounts as well.
04-26-2018, 10:58 AM   #114
No, just pointing out that it's possible some people won't be completely happy with it if vignetting scares them off. I shot a production of Oliver Twist a few weeks ago, 726 images in 2 hours, all with that lens. Looks like I'll be handing off around half of those to the director. (I haven't upgraded my K-1 to a Mark II yet, so some of the lower-light areas of the stage just didn't work well. Stupid stage lighting, always uneven.)
05-29-2018, 06:31 AM - 1 Like   #115
Mistral75's Avatar
One ore: Meyer Optik Görlitz Nocturnus 50 mm f/0.95 DSLR
The optical formula of this lens is different from the one of the mirrorless version (the latter being a rebadged Mitakon Speedmaster): 8 elements in 6 groups for the Nocturnus DSLR, 10 elements in 7 groups for the Mitakon-Nocturnus.
Available in two colours (matte black or silver) and four lens mounts: Canon EF, M42, Nikon F and Pentax K. Estimated delivery date: April 2019.
I'm a bit sceptical about the reality of the f/0.95 aperture with narrow SLR mounts such as M42 and, to a lesser extent, Nikon F and Pentax K. Even Canon, whose EF mount has a much larger throat diameter, limited themselves to 50mm f/1.
05-29-2018, 07:32 AM   #116
Class A's Avatar
Added, thanks!
I think your concerns regarding f/0.95 with respect to mount diameters are justified. Another question is to what extent sensors can "see" such wide apertures. Even f/1.2 or f/1.4 lenses are typically not used to their maximum potential because the rays from the outer areas of the lens are coming in at too steep an angle for the sensels to fully capture them.
Many cameras automatically account for the loss of light caused by this "sensor blindness" by cheating with an internal exposure boost.
05-29-2018, 12:51 PM   #117
Mistral75's Avatar
You're welcome!
This is really for the sake of exhaustiveness: the price/performance ratio of those Meyer Optik lenses is much too high for them to be of any interest.
05-30-2018, 05:59 AM   #118
Class A's Avatar
I didn't check the pricing, actually.
"Exhaustiveness" is a good cause, though!
Please keep the updates coming.
05-30-2018, 07:16 AM   #119
Curious - would any of the 70-300 4-5.6 zooms stack up to the Tamron 70-200 2.8 optically stopped down? I was thinking to wait for the 70-200 f4 from Pentax, but if there's something good available now, maybe I don't have to
05-30-2018, 07:23 AM   #120
Class A's Avatar
QuoteOriginally posted by awscreo Quote
I wouldn't think so but why not check out the Pentaxforums Third-Party Pentax Lens Review Database?
This thread isn't the ideal place to discuss questions like that.
40mm, 50mm, birds, copies, da, discounts, dslr, f1.4, f1.8, f2.8, ff, full frame, full-frame, k-1, k1, lenses, macro, mode, new, pentax k-1, photographer, price, profit, sdm, smc, umc, world, xs, yer
So much for the new FF and MF lenses 2351HD Pentax Medium Format 19 03-08-2016 09:24 AM
Will the new Pentax K1 FF be DOA?? Shanti Pentax Full Frame 87 02-17-2016 06:42 PM
New lenses for the FF ... Pentax and Third Party mikeodial Pentax Full Frame 33 01-14-2016 06:06 PM
Can C-mount lenses (CCTV) be used with the K3 or the K-cameras? Ryuno Pentax K-3 & K-3 II 8 02-22-2015 07:45 PM
DA lenses that could be used on FF toukan Pentax SLR Lens Discussion 4 11-28-2013 05:04 AM
All times are GMT -7. The time now is 10:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
