FF lenses for the K-1 that can be bought new
Posted By: Class A, 02-20-2016, 07:36 AM
We all know there is a ton of great FF glass available on the used market that will work great with the K-1.
However, which are the currently available FF lenses (in current catalogues of lens manufacturers) that can be used with the K-1?
Below is a list that started with an initial compilation I did and then attracted a number of later additions by several contributors. There may be still some missing and please post to this thread with information about the lens (but please make sure the lens is in production). I'll then add it to the list.
If you have used any of the listed lenses on the K-1 and find that they do not perform like a proper FF lens, please post to this thread as well. There are some DA (APS-C) lenses included which have been tested as "good for FF" on film cameras but due to differences between film and digital sensors, there may be a few surprises (although I tried to be conservative and only included those that would be true surprises if they failed the "K-1 test".)
Thanks in advance.
P.S.: I realise that there is also another current FF lenses overview but the latter contains discontinued lenses and I think there is value in maintaining a list of lenses that can be bought brand new. Not everyone is prepared to go hunting on the used market. A very nice feature of the aforementioned alternative compilation is that many third-party FF lenses can found organised in roadmap-style charts.
Regarding the suitability of certain DA (APS-C) lenses, I included a few that a truly FF capable based on their design and user reports. There is a far larger number of DA lenses with OK to marginal performance on an FF camera. These have not been included in this list, even though some users may find them acceptable (in particular using the K-1's 1:1 crop mode). A useful resource on the performance of DA lenses on an FF camera is falconeye's "DA lenses on Full Frame: Test shots" thread.
Pentax
Zooms
HD Pentax-D FA 15-30mm F2.8 ED SDM WR
HD Pentax-D FA 24-70mm F2.8 ED SDM WR
HD Pentax-D FA 28-105mm F3.5-5.6 ED DC WR
HD Pentax-D FA* 70-200mm F2.8 ED DC AW
HD Pentax-D FA 70-210 mm f/4 ED SDM WR
HD Pentax-D FA 150-450mm F4.5-5.6 ED DC AW
SMC Pentax-DA* 60-250mm F4 ED [IF] SDM
(some vignetting in particular at 250 but very usable;
some owners replace an internal baffle to reduce the vignetting)
Primes
HD Pentax-D FA 21mm f/2.4 ED Limited DC WR
HD Pentax-FA 31mm f/1.8 Limited
HD Pentax-FA 43mm f/1.9 Limited
HD Pentax-FA 77mm f/1.8 Limited
HD Pentax-FA 35 mm f/2
SMC Pentax-FA 50mm F1.4
HD Pentax-D FA* 50mm F1.4 SDM AW
HD Pentax-D FA* 85mm F1.4 SDM AW
SMC Pentax-D FA 50mm F2.8 Macro
SMC Pentax-D FA 100mm F2.8 Macro WR
APS-C Primes, performing well on FF
SMC Pentax-DA 35mm F2.4 AL
SMC Pentax-DA 50mm F1.8
SMC Pentax-DA* 55mm F1.4 SDM
SMC Pentax-DA* 200mm F2.8 ED [IF] SDM
SMC Pentax-DA* 300mm F4 ED [IF] SDM
HD Pentax-DA 560mm F5.6 ED AW
Sigma (as long as current stock lasts)
Zooms
70-300mm F4-5.6 APO DG Macro
70-300mm F4-5.6 DG Macro
50-500mm F4.5-6.3 APO DG OS HSM
Primes
15mm F2.8 EX DG Diagonal Fisheye
28mm F1.8 EX DG ASP RF
35mm F1.4 DG HSM | A
85mm F1.4 EX DG HSM
300mm F2.8 EX APO DG (HSM)*
500mm F4.5 EX DG APO (HSM)*
Tamron
Zooms
SP AF 28-75mm f/2.8 XR Di LD Aspherical [IF] Macro
AF 70-300mm f/4-5.6 Di LD Macro 1:2
Samyang
Primes
12mm F2.8 ED AS NCS Fisheye
14mm F2.8 ED AS IF UMC
20mm F1.8 ED AS UMC
24mm F1.4 ED AS IF UMC
24mm F3.5 ED AS UMC TILT/SHIFT
35mm F1.4 AS UMC
50mm F1.4 AS UMC
85mm f/1.4 AS IF UMC
100mm f/2.8 Macro
135mm f/2 ED UMC
(Most, if not all, of the above are also available as "Cine" lenses that for instance feature click-less apertures.)
500mm MC f/6.3 Mirror (best Samyang mirror lens, decent sharpness but awful bokeh)
500mm MC IF f/8 Mirror
800mm MC f/8 Mirror
500mm MC f/8 Preset (not mirror, a little bit long but very light with decent sharpness)
650-1300mm f/8-f/16 (long and light, almost usefull as a monopod)
(The above comments come courtesy of banep, thanks!)
Schneider-Kreuznach
Primes
PC-TS 4.5/28MM Super-Angulon Tilt/Shift
PC-TS 2.8/50MM Super-Angulon Tilt/Shift
PC-TS 4.5/90MM Makro Symmar Tilt/Shift
Laowa (Venus Optics)
Primes
12mm f/2.8 Zero-D
15mm f/4.5 Zero-D Shift
15mm f/4.5R Zero-D Shift
15mm f/4 1:1 Macro
20mm f/4 Zero-D Shift
25mm f/2.8 Ultra Macro (2.5-5 x magnification, no infinity focus)
60mm f/2.8 2:1 Macro (2x life size magnification)
100mm f/2.8 2x Ultra Macro APO
105mm f/2 (t/3.2) STF (Smooth Transition Focus)
Irix
Primes
Irix 15mm f/2.4
Irix 11mm f/4
Irix 21mm f/1.4 Dragonfly
Irix 30mm f/1.4 Dragonfly
Irix 45mm f/1.4
Irix 150mm f/2.8 Macro 1:1 (Dragonfly)
AraxFoto
Arax 35mm f/2.8 Tilt & Shift
Arax 80mm f/2.8 Tilt & Shift
Meyer-Optik Görlitz (liquidated in 2018, but revived in 2020)
Primes
Lydith 30mm f/3.5
Trioplan 35+ f/2.8
Nocturnus 50 mm f/0.95 (DSLR variant)
Primotar X 50mm f/2.8
Trioplan 50mm f/2.9
Primoplan 58mm f/1.9
Primoplan 75mm f/1.9
P75 II (advanced version of the Primoplan 75)
Somnium II 85mm f/1.5
Lydith 30 f3.5 II
Trioplan 35mm f/2.8 II
Trioplan 50 f/2.8 II
Biotar 58mm f/1.5 II
Biotar 75mm f/1.5 II
Primoplan 58mm f/1.9 II
Primoplan 75mm f/1.9 II
Trioplan 100 f2.8 II
Apo-Makro-Plasmat 105mm f/2.7
net SE (-> resurrection of Meyer-Optik Görlitz, Emil Busch and Oprema Jena lenses, liquidated in 2018)
C. P. Goerz Citograph 50mm f/2.8 (currently a Kickstarter project)
Emil Busch Glaukar Anastigmat 97mm f/3.1 (scaled version of the 1910 Glaukar 210mm f/3.1, a lens for 8x10cm and 13x18cm field cameras)
Oprema Jena Biotar 75mm f/1.5 (re-edition of the Carl Zeiss Biotar 75mm f/1.5 (Willy Merté, 1938))
Zeiss (M42 mount lenses; require an M42 -> K-mount adapter, the genuine Pentax adapter supports infinity focus)
ZEISS Distagon T* 2,8/25
ZEISS Distagon T* 2/28
ZEISS Distagon T* 2/35
ZEISS Planar T* 1.4/50
ZEISS Planar T* 1.4/85
Zhong Yi Optics
Primes
Mitakon 20mm f/2 4.5x Super Macro
Mitakon Creator 35mm f/2
Mitakon 85mm F1.2
Mitakon 85mm F2
Mitakon Creator 85mm f/2.8 1-5x Super Macro
Mitakon Creator 135mm f/2.8 version II
Mitakon Speedmaster 135mm F1.4
Lensbaby (as long as stock is available, K-mount discontinued in 2019)
Primes
Burnside 35 (with variable vignetting)
Velvet 28
Sol 45
Velvet 56
Twist 60
Velvet 85
Optic Swap System
Dongzheng Optics
Primes
Kerlee 35 mm f/1.2 (info)
Lomography
Primes
Naiad 15mm F3.5 Art (135° FOV, 1cm close focusing)
Lomogon 2.5/32 Art Lens
Daguerreotype Achromat 64mm f/2.9 Art (info)
Neptune Convertible Art Lens System
Kenko
Primes
Kenko 400mm f/8 N II S (via T-mount adapter)
KMZ (sometimes difficult to buy outside Russia; some are easily available though)
Primes
MC Zenitar-K 16mm f/2.8 (fisheye)
MC Helios 77K-4 50mm f/1.8
MC Zenitar-K 50mm f/1.9
MC Zenitar-K 50mm f/2
MC Helios 44K-4 58mm f/2
MC Apo Telezenitar-K 135mm f/2.8
MC Apo Telezenitar-K 300mm f/4.5
Zooms
MC Variozenitar-K 25-45mm f/2.8-3.5
05-30-2018, 07:28 AM - 1 Like   #121
Mistral75's Avatar
RRP is €/$3,999. Early birds get special discounts: €/$1,899 (50 copies), then €/$1,999 (100 copies).
That's Meyer Optik's way of doing business: apply huge discounts to insane RRPs to entice people whilst making a comfortable profit from the discounted price. I wonder how many lenses they sell at RRP...
05-30-2018, 07:47 AM   #122
I wouldn't think so but why not check out the Pentaxforums Third-Party Pentax Lens Review Database?
This thread isn't the ideal place to discuss questions like that.
Will do, I actually never bother to check if those 70-300 were ff compatible lol
05-30-2018, 09:47 AM   #123
Class A's Avatar
QuoteOriginally posted by Mistral75 Quote
RRP is €/$3,999.
OK, I'm out.
Would they be able to justify the design and production of a lens based on 150 sold copies only?
05-30-2018, 02:08 PM - 1 Like   #124
Mistral75's Avatar
That's hard to determine. Sadoyasu Miyazaki (MS Optics / MS Optical, do you remember the MS Optical Sonnetar 25mm f/1.1 for Pentax Q?) manufactures and sells less than hundred copies of each of his creations and their price is below $1,000 but his activity is pretty much that of a craftsman.
Besides, Meyer Optik often use Kickstarter, Indiegogo after Kickstarter to sell a second batch of the same lens, have regular discounts on their website, send coupon codes to their newsletter subscribers and so on.
03-05-2019, 04:33 PM - 1 Like   #125
Mistral75's Avatar
One more since today: Lomography added the Pentax K mount to the list of mounts available for their Lomogon 32 mm f/2.5 which includes a dial-styled aperture mechanism (five circular apertures: f/2.5 - f/4 - f/5.6 - f/8 - f/11).
Kickstarter page (the projects run from 20 February until 22 March 2019): The Lomogon 2.5/32 Art Lens by Lomography — Kickstarter
Addition of the Pentax K mount: The Lomogon 2.5/32 Art Lens by Lomography » Brand New Pentax K Mount Compatibility & Newly Discounted Pledges — Kickstarter
50 pledges until 22 March are needed for the K-mount Lomogon 32 mm f/2.5 to become a reality. As of now, 10 such lenses have been pledged.
Press kit: Press Kit - Google Drive
Gallery of 13 pictures shot with the Lomogon: Lomogon 32mm F2.5 Sample Photos | Digital Photography Review
03-07-2019, 10:23 PM   #126
Class A's Avatar
Many thanks for the pointer to the lens.
I'll add it if the project goes ahead.
EDIT:
Seems that more than enough backing has been obtained so it seems safe to add it.
03-08-2019, 06:46 AM - 1 Like   #127
Mistral75's Avatar
You're welcome. The Lomogon project will definitely go ahead but the K-mount Lomogon will need 50 pledges to be made:
QuoteOriginally posted by Lomography:
The only thing we need to make this extra compatibility a reality is 50 Pentax mount pledges. (...)
If the total number of Pentax K backers fails to reach 50, every person who backed these tiers will have a choice: be refunded, or choose another mount (Canon EF & Nikon F).
For the time being only ten K-mount Lomogons have been pledged (same as two days ago).
03-08-2019, 08:43 AM   #128
Class A's Avatar
Ah, I didn't read the project description to this level of detail...
Thanks, again!
03-09-2019, 09:07 AM   #129
QuoteOriginally posted by Mistral75;4596431Addition of the Pentax K mount: [URL="https://www.kickstarter.com/projects/lomography/the-lomogon-25-32-art-lens/posts/2436082":
The Lomogon 2.5/32 Art Lens by Lomography » Brand New Pentax K Mount Compatibility & Newly Discounted Pledges — Kickstarter[/URL]
Looks like 12 total now... 6 black brass (including mine) and 6 brass. Hopefully that'll go up... as I'd really like the lens.
I'll probably get their 64mm when it's back in-stock in Pentax mount as well.
11-29-2019, 06:03 AM - 1 Like   #130
Mistral75's Avatar
One more: Zhong Yi Optics Mitakon Creator 85mm f/2.8 1-5x Super Macro.
Mitakon Creator 85mm f/2.8 1-5X Super Macro | Mitakon - ZY Optics
- allows you to vary the maximum magnification ratio between 1x and 5x (it can only do macrophotography)
- focal length: 85mm at 1:1 and 25mm at 5:1
- very long working distance: 27.2cm at 1:1 and 10cm at 5:1
- 12 elements in 8 groups
- apochromatic design
- near telecentric design
- 9-blade aperture
- filter diameter: 58mm
- dimensions: 67mm (maximum diameter) x 122mm (length)
- weight: 750g
- available in Canon EF, Canon EF-M, Fujifilm X, µ4/3, Nikon F, Pentax K, Sony A and Sony E mount
- price: 499 USD.
Set on 1:1 on the left, 5:1 on the right.
11-29-2019, 06:52 AM   #131
Class A's Avatar
Thanks!
Interesting design. Seems to be a "reversed lens" design similar to the Canon MP-E 65mm f/2.8 1–5x Macro.
N.B., at some point I should probably remove the Sigma lens models.
11-29-2019, 07:22 AM - 1 Like   #132
Mistral75's Avatar
Thanks!
You're welcome.
Same with Lensbaby I would say:
Lensbaby no longer making Pentax mounts - PentaxForums.com
In addition you should remove the lenses under Meyer Optik Görlitz and net SE since net SE was liquidated last year.
11-29-2019, 05:49 PM - 1 Like   #133
BruceBanner's Avatar
You're welcome.
Yeah I wouldn't remove lensbaby just let, they just got a massive shipment come into Australia last month with heaps of K Mount versions, and they have also said they would make a version of their lenses in K Mount if contacting the team directly, I think they just whipped up a storm a little to get some more sales imo (and it worked! I bought the 'what I believed to be' the last Burnside 35 in Australia!). Grr...
11-30-2019, 06:08 AM   #134
Class A's Avatar
Thanks a lot.
I changed the colour for these entries.
I hope that provides enough indication that these are not technically available as new anymore but may be available as residual stock.
11-30-2019, 06:44 AM   #135
Mistral75's Avatar
sadly liquidated in 2018
I'm not so sure I'm sad that net SE were liquidated. Those guys with their Ponzi scheme were crooks who embezzled around three million US dollars and swindled thousands of people.
40mm, 50mm, birds, copies, da, discounts, dslr, f1.4, f1.8, f2.8, ff, full frame, full-frame, k-1, k1, lenses, macro, mode, new, pentax k-1, photographer, price, profit, sdm, smc, umc, world, xs, yer
So much for the new FF and MF lenses 2351HD Pentax Medium Format 19 03-08-2016 09:24 AM
Will the new Pentax K1 FF be DOA?? Shanti Pentax Full Frame 87 02-17-2016 06:42 PM
New lenses for the FF ... Pentax and Third Party mikeodial Pentax Full Frame 33 01-14-2016 06:06 PM
Can C-mount lenses (CCTV) be used with the K3 or the K-cameras? Ryuno Pentax K-3 & K-3 II 8 02-22-2015 07:45 PM
DA lenses that could be used on FF toukan Pentax SLR Lens Discussion 4 11-28-2013 05:04 AM
All times are GMT -7. The time now is 04:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
