DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
12-17-2011, 12:32 PM - 1 Like   #166
falconeye's Avatar
Thanks beholder3, that's exactly the kind of content I was hoping for. Great and thank you very much!
QuoteOriginally posted by beholder3 Quote
That generally is true, but on the long end it has shaded corners: 250mm:
The corner shading is vignetting as the loss of light isn't 100%. I've seen some of it too but not as strong. And vignetting was kind of normal for a FF zoom if remember the old days correctly
In order to judge the vignetting you showcase, I'd like to know what image area you scanned (some film cameras expose more than 24x36mm), at which aperture and focal distance you shot (shorter distances could be worse) and what gradation your film emulsion was (some hard gradation films can make a little vignetting look like shading).
12-17-2011, 01:58 PM   #167
I understand what you are asking but I just posted results of a totally non-scientific cheap approach...
I used the cheapest color negative film 200 ISO (dm, Paradies) and let it develop (Rossmann) the cheapest way including a CDROM with scanned pictures. The whole investment film, development, CDROM was about 6 EUR...
It was not meant for publishing, I was just curious and wanted a rough impression. The distance was about 6m I guess. Aperture I didn't write down, sorry.
I can scan the film myself if that is of any help for the specific picture.
12-17-2011, 05:22 PM   #168
drougge's Avatar
It's worth noting (again) that the DA*50-135 has a smaller image circle somewhere in the middle than in the tested extremes. (Smallest around 70mm IIRC.)
12-18-2011, 09:33 AM   #169
QuoteOriginally posted by drougge Quote
Ok, but what does that mean? Its not fully usable on FF on both ends anyway. If I understand you correctly that just means its even worse in the middle.
12-18-2011, 06:53 PM   #170
drougge's Avatar
Correct, but I just know someone is going to conclude it will work fine on APS-H from those shots, and I doubt it actually will.
12-20-2011, 05:24 AM   #171
Little Info added:
Aperture was F4 for both shots. Distance was 1,44m for 60mm and 2,1m for 250mm.
All shots were done in A-Mode on the MZ-5N and in the absence of a aperture ring the aperture always was open for all lenses.
12-20-2011, 08:15 AM   #172
falconeye's Avatar
Little Info added:
Ok, this is kind of the worst case scenario. I did a series at 250mm at various apertures and at f/5.6, vignetting is much less and kind of disappears at f/8. However, a close focussing distance like 2.1 m increases the focal length (using the thin lens formula) to an effective 280mm which probably intensifies the corner vignetting.
Moreover, in my scans I cropped to 24x36mm before evaluating for vignetting. The original scans were only slightly wider but it made an effect in the corners. I'd say that if you crop to a 97% viewfinder area like a framed dia positive does, then the effect is much less.
12-20-2011, 06:44 PM   #173
What aperture was the DA70mm taken at?
03-05-2012, 06:01 PM - 2 Likes   #174
Marketplace Reseller
vjacesslav's Avatar
Hi there
I made some test photos of DA 55-300mm on Full Frame Pentax MZ-6.
My copy of this lens is definately not +/++ suitable for FULL FRAME.
Here are the results: vjacesslav: SMC PENTAX DA 55-300MM F4-5.8 vs FULL FRAME
03-05-2012, 06:26 PM   #175
falconeye's Avatar
QuoteOriginally posted by vjacesslav Quote
I agree, so I'll revise the rating as the earlier report doesn't seem to be correct.
You removed the lens hood, did you?
03-05-2012, 10:01 PM   #176
Ron_Man's Avatar
I honestly kinda like the vignetting effect it makes when putting a DA lens on a ff body........... *runs away*
03-06-2012, 01:56 AM   #177
vjacesslav's Avatar
Yes,
the lens hood was removed...
I know this is not proffesional shooting, has to only show basic DA lens performance of Full Frame.
I´ve already done 70mm limited on Full Frame, next test will be DA 35 macro Limited.
But already preparing to try DA lenses on Canon Full Frame body with help of Pentax K-Canon EOS adapter...
Vjacesslav
03-17-2012, 04:03 AM - 1 Like   #178
vjacesslav's Avatar
Next try is DA 35mm Macro on Full Frame Film SLR Camera (Pentax Mz-6):
vjacesslav: SMC PENTAX DA 35MM F2.8 MACRO LIMITED vs FULL FRAME
03-17-2012, 04:16 AM   #179
aurele's Avatar
some vignetting, but i seems acceptable
03-17-2012, 09:38 AM - 1 Like   #180
topace's Avatar
Please be advised that lenses with a classical focusing mechanism, like the 35mm f/2.8 macro, are bound to have very different corner properties (vignetting as well as resolution) at different focus/magnification settings. Generally, the closer you focus, the less lens surface is used, resulting in a loss of center resolution, but generally an increase in corner resolution as well as less vignetting. This is significantly more true with a macro lens since there's so much difference between it's focus limits.
So to be able to provide the complete story on a lens like this, samples must be taken at varying points of focus, as well as aperture settings,
Then again, for usage as a macro lens, the 35mm should be OK, for the above mentioned reasons.
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 02:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
