Show Printable Version 134 Likes Search this Thread
DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
05-29-2012, 11:40 PM   #181
Sandy Hancock's Avatar
I just took some test shots of the following lenses: DA10-17, DA40, DA*55, DA70, DA55-300, DA*60-250 and DA*300
My film camera can not control the aperture of these lense, but as far as I could tell by looking backwards through the lenses, all photos were taken at wide open aperture. I used Fuji slide film at ISO 100 on a Pentax P30T. Rough metering was done with my iPhone.
The zooms were shot at both extremes of their range; in the case of the DA10-17 that meant ~13mm at the wide end, because before that the non-removable hood gets in the frame.
*All* of these lenses appeared to give good coverage of the viewfinder frame. I will post the shots as soon as I develop and scan them.
Hopefully this might fill in some of the remaining gaps.
05-30-2012, 02:14 AM   #182
Clavius's Avatar
The DA 10-17 too?!? Are you sure?
05-30-2012, 02:31 AM   #183
Banned
the viewfinder does not show the whole frame. the viewfinder of your p30t, I believe only has 92% coverage. therefore your test is somewhat flawed.
05-30-2012, 02:34 AM   #184
QuoteOriginally posted by Clavius Quote
From 13mm onwards the image in the viewfinder looked fine. This is consistent with the observations detailed in the OP, but I won't draw my own conclusions until the slides are developed.
05-30-2012, 03:45 AM   #185
QuoteOriginally posted by séamuis Quote
I wondered whether that may have been the case. Luckily the truth will be known soon.
07-23-2012, 08:24 AM   #186
bobell69's Avatar
18-135wr
Does anyone know if the 18-135WR will work on a Full Frame or only APSC?
08-06-2012, 03:49 PM - 2 Likes   #187
VisualDarkness's Avatar
QuoteOriginally posted by vjacesslav Quote
Hi there
I made some test photos of DA 55-300mm on Full Frame Pentax MZ-6.
My copy of this lens is definately not +/++ suitable for FULL FRAME.
Here are the results: vjacesslav: SMC PENTAX DA 55-300MM F4-5.8 vs FULL FRAME
It seems to be a "200mm Prime" on full-frame.
08-06-2012, 11:01 PM   #188
QuoteOriginally posted by bobell69 Quote
I checked my 18-135 without the hood on an MX, and the viewfinder shows a solid black circle at all focal lengths. It is completely unusable on FF.
08-06-2012, 11:08 PM   #189
twitch's Avatar
QuoteOriginally posted by VisualDarkness Quote
The images posted weren't anything like in the 3:2 ratio of a 35mm negative though so I'm not sure if solid conclusions can be made.
08-07-2012, 12:51 AM - 1 Like   #190
QuoteOriginally posted by Cannikin Quote
Meh.
In this age of the huge popularity of Instragram and Lomography, that's not an unusable bug - it's a feature! The designers of the 18-135 are simply hipsters at heart.
08-07-2012, 06:12 AM   #191
falconeye's Avatar
the lens hood was removed..
Vjacesslav, ok, so I revised the rating in the opening post.
It applied to the tele end only anyway, but it may not have been sufficiently clear. Now, that you tested the wide end, I gave it an "0" overall.
08-08-2012, 11:30 AM - 1 Like   #192
aurele's Avatar
i've done 3 rolls of films with the DA*55.
From f2 to f22 : no vignetting at all.
From f1.4 to f2 with hood : subtle vigneting with a value around 0.3 - 0.7 EV that is very soft and progressive in the extreme corner (around 5-7% of the width of the frame.)
See below :
DA*55 @f1.4, 1/60, MZ-5n, Ilford HP5+ push 2 stops @1600 iso. light bulb of 100watts at 2m above Florent.
At f1.4 without hood : very subtle vigneting of 0.3 EV (less than on the picture above.)
DA*55 @1.4, 1/125, MZ-5n, Ilford HP5+ push 2 stops @1600 iso. Sunset light only.
To conclude :
I think we can say DA*55 without hood : +++, and DA*55 with hood ++.
Definitely a keeper it completely remplace my A50/1.7 now.
08-08-2012, 11:45 AM   #193
JinDesu's Avatar
Sexy news to hear, that DA*55 is pretty awesome.
08-09-2012, 12:14 AM - 1 Like   #194
aurele's Avatar
Indeed that's'pretty sexy.
Just remember that due to its KAF3 mount, it's'only manual focus on film body.
And i really and strongly suggest you to have a microprism or stygmo or any precision matt focusing screen, because F1.4 on film is unforgiveable when it comes to focusing.
On MZ-5n, with standard matt focusing scrEen, i missed around 50% of my shots.
On SuperA with stygmo and microprism i missed around 20 %.
But the result is really astonishing with B&W film.
08-09-2012, 03:38 AM   #195
falconeye's Avatar
QuoteOriginally posted by aurele Quote
To conclude :
I only collect results w/o hood in this thread. However, in order to embrace the conclusion, I would have to know something about edge and corner resolution. Subtle vignetting is normal for all FF lenses.
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
