DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
10-02-2014, 12:18 PM   #301
Marketplace Reseller
vjacesslav's Avatar
Another confirmation that DA* 55mm 1.4 SDM is suitable for Full Frame
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/274667-test...ml#post2962419
or
vjacesslav: SMC PENTAX DA* 55mm 1.4 SDM WR vs FULL FRAME
11-12-2014, 01:57 PM   #302
zzeitg's Avatar
Hi everybody,
Sigma K mount DC...
-: not usable
now... if there's one day a FF and I mount the 1.4 teleconverter on it, how will it affect the DA lenses / FF camera compatibility?
(another question is of course if the teleconverter will be usable with FF camera...)
11-13-2014, 11:13 AM - 1 Like   #303
mbukal's Avatar
I put DA17-70 / 4 AL with Pentax cmsF x1,7AF the Ricoh KR-10 Super and DA lens has no vignetting - without smcFx1,7AF has a lot of vignetting at the wide end, as I did with DA55-300 / 3.5-5 , 8 ED and also just nowhere vignetting
11-13-2014, 10:05 PM   #304
falconeye's Avatar
DA lens on Full Frame: Test Shots thread
QuoteOriginally posted by zzeitg Quote
AFAIK, the 1.4x TCs are all FF, the new Pentax one included.Maybe, somebody can confirm?
DA lens + 1.4xTC on FF almost performs the same as DA alone on APSC. There are no concerns wether the DA lens is incompatible.
The only concerns are if the TC is optically good enough (like with Nikon's new TC-14Eiii which works with almost no optical degradation); And if the AF would still function properly with one stop slower fstop. (Some FF cameras can AF at F/8. But from experience I'd say it is a degraded experience if light starts to fade. Therefore, DA lenses F5.6 or slower would probably focus better with an APSC body.)
BTW, if you ever add a 1.4x TC to a FF camera in order to continue using your DA lenses, please don't forget to double ISO for comparable results.
11-19-2014, 12:21 PM   #305
hoopsontoast's Avatar
DA14 on MZ-5N (just for giggles)
11-19-2014, 01:12 PM   #306
Jean Poitiers's Avatar
QuoteOriginally posted by hoopsontoast Quote
A picture is worth a thousand words, so they say ... thanks for showing it on film.
11-20-2014, 06:28 PM   #307
Hello everyone,
I see that the Pentax DA* 55mm f/1.4 gets a "+++: no significant difference between APS-C and FF corners" rating. What does it really mean?
Say that next year Pentax launches a FF camera. Does the above mean that I will be able to use the DA* 55mm on that FF camera without any limitation whatsoever (identically to the actual FF labeled lens) or it just means the lens will be usable but there will be some drawbacks...?
Thanks.
11-20-2014, 08:29 PM   #308
mattt's Avatar
I suspect you'd need a different hood.
11-21-2014, 01:41 AM   #309
QuoteOriginally posted by mattt Quote
Agreed. Highly probable.
11-21-2014, 02:48 AM   #310
aurele's Avatar
Yes, the DA*55 work flawlessly on FF. The hood induce a bit of vignetting.
But to be honest, i never use it, the coating of the lens do an outstanding job.
11-21-2014, 02:36 PM   #311
6BQ5's Avatar
QuoteOriginally posted by aurele Quote
What kind of hood did you use? The bayonet hood on my D FA 50mm f/2.8 is long and deep, like a children's cup.
11-21-2014, 04:03 PM   #312
aurele's Avatar
QuoteOriginally posted by 6BQ5 Quote
the standard one of the DA*55. it's the PH-RBH 58mm.
11-21-2014, 04:29 PM   #313
VisualDarkness's Avatar
It's the ciiiiircle of liiiiife!
11-25-2014, 11:34 AM   #314
falconeye's Avatar
QuoteOriginally posted by Moropo Quote
It is meant to mean this:
The FF corners on an FF body, and APSC corners on an APSC body, when both are expressed in lp/PH resolution, are similiar enough.
It does not necessarily mean that on an FF body, the image isn't sharper at the APSC image circle than the FF image circle. But as FF images aren't enlarged as much, this would be ok.
Actually with an +++ rating, the DA* 55/1.4 at F2 on FF may well outperform an equivalent APSC 37mm/1.4 in their respective corners. But there is no test validating this and no comparable lens either.
11-26-2014, 11:48 AM   #315
I think I can confirm this.
We already did a quick test with DA 18-135 WR, HD DA 1.4x TC & MZ-S body and saw no dark circle at all focal length when looking through the OVF. The pictures should be usable although there is still somewhat vignetting. If the TC was 1.5x or 1.7x, the corner would be even better I guess.
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 02:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
