DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
02-08-2015, 04:25 AM   #331
zzeitg's Avatar
so what about DA* 60-250mm and its performance on FF sensor?
02-08-2015, 07:06 AM   #332
UncleVanya's Avatar
QuoteOriginally posted by zzeitg Quote
I'd like to know this also. In lieu of the ff sensor, a few shots on film would be nice.
02-08-2015, 09:19 AM - 2 Likes   #333
Barry Pearson's Avatar
In 2013 I tested my DA* 60-250mm on a Pentax film camera, had the film scanned, then uploaded it. (I did the same with several other Pentax lenses, accessible from the link below). See:
DA* 60-250mm f/4 on Z-1p
Conclusion for the 60-250mm:
"This isn't an unqualified FF lens. But neither is it unusable on a 35mm camera. At 60mm on 35mm the corners are soft. At 250mm the corners are darker, but still usable. These improve on stopping down. In other words, similar to (although perhaps worse than) a typical kit lens used on an APS-C sensor. Perhaps that is a way to think about it - an expensive kit lens (unless you already own it, as I do) for an FF camera!
"It appears that this is likely to be a useful lens on an FF camera when used with a 1.4 teleconverter. I am already looking forward to using it on an APS-C sensor as an 84-350mm f/5.6 lens if/when Pentax supply a 1.4x teleconverter. And I think it might be good as an FF lens in that combination."
---------- Post added 8th Feb 2015 at 04:21 PM ----------
Here are some tests of DA and DA* lenses on film that I did in 2013. Their time has come! Spread the word.
Pentax Full Frame tests
02-08-2015, 09:25 AM   #334
UncleVanya's Avatar
Thanks
02-08-2015, 10:26 AM   #335
Weevil's Avatar
QuoteOriginally posted by Barry Pearson Quote
Interesting !
02-08-2015, 10:39 AM   #336
zzeitg's Avatar
OK, thanks! Let's see how much money we'll have to pay for a new glass
02-22-2015, 09:55 AM   #337
KyleWhorten's Avatar
Anybody tried the tamron 70-200 f2.8 ?
02-22-2015, 10:46 AM   #338
Jean Poitiers's Avatar
QuoteOriginally posted by KyleWhorten Quote
Good question to be confirmed. This lens is on my short list and it should be FF since it is a "Di" lens.
The website of my local B&M shop lists the lens as compatible for "24x36" and APS-C.
03-02-2015, 01:28 AM   #339
Although I doubt it is a FF lens, the DA 18-135mm WR is missing from the list in the OP.
03-03-2015, 04:46 AM   #340
falconeye's Avatar
QuoteOriginally posted by yucatanPentax Quote
Yeah. The 18-135mm is a newer lens (this thread was started ages ago ) and even as the OP, I cannot modify my OP anymore
03-03-2015, 05:42 AM   #341
Lots of Canikon guys have
03-03-2015, 10:15 AM   #342
Well, that's a shame. Maybe a note to the Admins and they could insert whatever text you requested into the original post? Just an idea. I honestly had no idea that our "edit" capabilities on our own posts expired, but I've never tried it either. Learn something new every day!
03-03-2015, 11:13 AM   #343
geomez's Avatar
I was wondering why the list was so outdated. It's a real shame you can no longer edit the post. This is important info for all Pentax users I hope the mods can give you the power back, or take the reins and list the info somewhere outside of a thread.
03-30-2015, 01:00 AM   #344
Gerbermiester's Avatar
Anybody tried the Tamron 70-200 f2.8 ?
Yep, the Tamron 70-200mm f/2.8 designed for fullframe. Works like a charm on my PZ-1 and Z1-P film bodies.
03-30-2015, 06:53 PM   #345
K David's Avatar
For kicks, I mounted the new 18-50 collapsing kit lens that comes with the K-S2 on my MG. Obviously, the lens can't be focused without ca camera power source. Nor can it be stopped down. So it's useless except at infinity and wide open with most Pentax bodies. That said, on FF, it vignettes with a clear image circles and corner cut-off in the viewfinder from 18mm to 24mm on the MG. Given that the MG has a smaller viewfinder, it could be assumed that it would vignette up to 28mm. One interesting thing is that the entire image is sharp. I had a vertical slat fence on the side of the viewfinder and there was significantly less distortion at 18mm in the out-of-APS-C-image-circle area than expected. In fact, the out-of-circle area was nearly as sharp as the in-circle area.
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 09:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
