DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
04-25-2016, 11:40 PM   #421
Barry Pearson's Avatar
I ran tests on my own lenses, and I posted a link to my results to this thread in 2013.
Since then, on that page of mine I've maintained links to some other such tests that I became aware of. This thread has become so big and cluttered that I don't know if those particular tests are covered in this thread. I think all the lenses they cover are listed, but perhaps a second opinion may be useful.
So here are copies of the links that I have been maintaining, together with the Pentax DA(*) lenses they examine. Given that the K-1 will soon be in many hands, (including mine!), just about everything in this thread will soon be superseded, but here goes. The tests don't all strictly conform to the thread rules; they are not my own tests.
Karl Knipser - Flickr Set
Many test photos of Pentax lenses on both film and a Canon EOS 5D Mark III
DA* 60-250mm f/4
DA* 300mm f/4
DA 12-24mm f/4
DA 15mm f/4
DA 18-135mm f/3.5-f/5.6
DA 18-250mm f/3.5-f/6.3
DA 21mm f/3.2 Limited
DA 35mm f/2.8 Macro
DA 40mm f/2.8
DA 70mm f/2.4 Limited
DA* 16-50mm f/2.8
DA* 50-135 f/2.8
DA* 55mm f/1.4
DA 50-200mm WR
DA 18-55mm
DA 560mm f/5.6
AMMouse aka Pentax_Prime - photobucket:
Some Pentax lenses on a Pentax Z-1p film camera
Pentax DA 55 (?)
Pentax DA 70 (?)
Wallace Koopmans Artlog:
Pentax Full Frame and APS-c Lenses on film
Pentax SMC-DA* 50-135mm f/2.8 ED [IF] SDM
Pentax SMC DA 50mm f/1.8
Pentax SMC DA 35mm f/2.8 Limited macro
Pentax smc PENTAX-DA 40mm F2.8 XS Lens
Eric Tastad at ERPhotoReview:
K Mount Primes
SMC Pentax DFA 100mm f/2.8 Macro WR on Sony A7R
SMC Pentax DA* 55mm f/1.4 on Sony A7R
K Mount Zooms
HD Pentax DA 20-40mm F2.8-4 Limited WR on Sony A7R
04-26-2016, 08:34 AM   #422
falconeye's Avatar
QuoteOriginally posted by Barry Pearson Quote
Barry, thank you so much for your compilation.
Yes, I agree.
I propose someone creates and maintains a moderated thread which collects results for DA lens image quality with the K-1.
04-29-2016, 05:08 PM - 3 Likes   #423
DA70/2.4 on K-1 FF mode
f2.4
There is some vignetting but the lens is totally ok for portrait. Definitely a ++ for me.
05-02-2016, 09:17 PM   #424
Mock's Avatar
When I picked up my K-1 the other day I had a go with the shop's DA* 60-250 f/4, in FF mode naturally. These are straight out of camera, just resized on export from lightroom.
60mm, f/4
88mm, f/4
108mm, f/9
220mm, f/4
250mm, f/4
I'll leave it up to the viewer to determine whether these are usable or not, since my opinion was a bit controversial in this thread.
05-03-2016, 01:45 AM   #425
topace's Avatar
QuoteOriginally posted by Mock Quote
Question: Did you use the in-camera SR? If you did, that might have decreased corner performance.
Not that your results really differ from what I expected.
05-03-2016, 02:12 AM   #426
QuoteOriginally posted by topace Quote
That statement surprised me! I wasn't aware of any such effect.
What is the background to that statement?
05-03-2016, 02:18 AM   #427
topace's Avatar
The SR is created by moving the sensor around, including moving it further away from the center of the image, potentially making the corners both darker and less sharp.
An in-body SR camera quite naturally demands a bigger image, or conversely, an in-body SR camera will have worse corner performance.
05-03-2016, 02:45 AM   #428
Right!
I forgot that with SR operating, at any point on the sensor there is now a contribution from positions of the image circle which would normally be further away from that point, and potentially lower in quality.
This would typically be a tiny effect with a proper FF lens, but the DA* 60-250mm is known to be marginal at the corners on FF. (I posted to this thread in 2013 with a link to my own tests).
When I test the 60-250mm on the K-1, (I intend to publish my results), I'll try it with SR on and off.
05-03-2016, 03:52 AM   #429
gazonk's Avatar
Thanks for showing! I'm a bit surprised that the vignetting is strongest at the longest focal length. For the other focal lengths, it looks highly usable for any subject where a little vignetting doesn't matter (or is desirable).
Edit: I guess you didn't use the lens hood?
05-03-2016, 04:57 AM - 2 Likes   #430
Sigma 8-16mm
@8mm
@12mm
@16mm
---------- Post added 05-03-16 at 12:58 PM ----------
Pentax DA 12-24
@12mm
@18mm
@24mm
---------- Post added 05-03-16 at 12:59 PM ----------
DA15mm
---------- Post added 05-03-16 at 01:00 PM ----------
DA21mm
DA40mm XS
---------- Post added 05-03-16 at 01:09 PM ----------
DA* 50-135mm
@50mm
@75mm
@95mm
@135mm
05-03-2016, 07:40 AM   #431
gazonk's Avatar
The DA15, as expected, is just an APS-C lens and not much more. But it just occured to me that for the square format, it can be used to capture 24x24, i.e. quite a bit more than APS-C, and for 4:3 format, it will cover about 19x26
05-03-2016, 08:16 AM   #432
ChristianRock's Avatar
QuoteOriginally posted by gazonk Quote
And I'm surprised at how much the DA 21 covers. It looks like you could just do a simple 4:3 crop which would give you 24x32 and get away with it. At the very least a 5:4 crop which would give you 24x30! That's almost double the coverage of APS-C, and would give you a 29MP image!
05-03-2016, 08:41 AM   #433
QuoteOriginally posted by ChristianRock Quote
Yeah, I was surprised by that as well. The only shots I've seen on film with that lens had a noticeable rectangle, so they must have been shot with the hood on? I think so far, the sigma 8-16 at 16mm is best ultra wide I've come across for the k-1 (I've got a K18, A20, and the ones above).
05-03-2016, 01:33 PM   #434
gazonk's Avatar
Not quite, I tried a 3:4 crop and that still gave heavy vignetting, 4:5 might work.
I tried to crop down as much as needed to get rid of vignetting with a 2:3 crop, and I estimated it to be (roughly) usable as a 27 mm lens. Not bad compared to an APS-C crop, should be quite useful for anyone who doesn't have a 28 mm prime.
05-03-2016, 01:56 PM   #435
rvannatta's Avatar
QuoteOriginally posted by abhaskare Quote
IMO .. these are not acceptable as FF lenses. The vignetting is just too visible and if you are going to crop, then why bother FF!
I at least take my photos usually leaving so boarder for croppping. unlessyou are putting together a slide show then you can't do this, but I solved most of the problem by keeping my film era lenses.
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 11:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
