DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
05-12-2016, 08:19 PM   #451
UncleVanya's Avatar
QuoteOriginally posted by micromacro Quote
Here is DA 21ltd on K-1 at f3.2; the first picture is with the original lens hood, and the second's with the metal hood for SuperTak 35mm.
Both pictures were taken with the same settings, from exact same spot, and focusing at the same point.
Did you do any without a hood?
05-12-2016, 08:27 PM   #452
micromacro's Avatar
Nope. I can if you'd like to check.
Here. Looks pretty much the same as with Takumar hood
05-12-2016, 08:32 PM   #453
UncleVanya's Avatar
Mostly just curious, but please.
05-12-2016, 08:36 PM   #454
micromacro's Avatar
Done, see above
05-12-2016, 08:45 PM   #455
UncleVanya's Avatar
Thank you. I see slight improvements over the Takumar one - but it's hard to see them side by side. It is subtle at best. Thanks again.
05-12-2016, 08:47 PM   #456
micromacro's Avatar
Not much, plus with that subtle difference hood still may help at day light. I guess.
06-13-2016, 06:48 PM - 2 Likes   #457
Da 35 2.8 al
Hi everyone,
I am a long time Pentax user, and a great fan (and long time lurker) of this forum... This is my first post, so apologies if I am not following site posting etiquette:
I have recently acquired my Pentax K1 and I have been trying out my various DA lenses.
Tonight I tested my DA 35mm f2.4 AL, and I am certainly finding some vignetting between 2.4 and 4.5. Vignette at 2.8 is very pronounced, and quickly recedes after 4.5.
After 4.5, the vignetting was more or less automatically dealt with by Lightroom lens profile correction.
Attached (I hope) are 4 photos I took tonight. RAW from camera and spit out via lightroom.
F2.8, F4.5, F9, F11 respectively.
Cheers
06-13-2016, 07:23 PM   #458
UncleVanya's Avatar
QuoteOriginally posted by coastjunkie Quote
Hi everyone,
Cheers
What would be interesting is to pit this result against an FA 35 f/2 to see if there is a significant improvement in vignetting.
06-14-2016, 01:31 AM   #459
aurele's Avatar
according to photozone, the FA show 0.7 EV of vignetting at f2 and 0.3 EV at f2.8, so it's close overall
http://www.photozone.de/pentax/123-pentax-smc-fa-35mm-f2-al-photozone-review...report?start=1
06-15-2016, 05:18 AM   #460
falconeye's Avatar
Thanks for the test. How about corner sharpness?
I find it interesting that LR applies their profiles despite the fact that the image circle is different. Obviously, Adobe does not keep track of image circles in the profile and the body.
Which is kind of sad as it renders DA profiles useless on full frame bodies and makes full frame profiles for DA lenses impossible. However, hand-made profiles and their manual selection could help here.
06-16-2016, 09:30 AM   #461
kh1234567890's Avatar
Adobe programs should pick up and use the SensorFormatFactor parameter. This is 1.5 in their stock profile for that lens. Adobe profiles of Pentax FF 'approved' lenses, such as the DFA 100mm macro, now have SensorFormatFactor value of 1 and presumably polynomial correction coefficients needed for FF coverage.
06-16-2016, 09:55 AM   #462
has anyone tried the sigma 30mm f/1.4 art yet? I've read some reviews that it vignettes only slightly on canon FF.
06-16-2016, 04:36 PM   #463
Michi Joel's Avatar
QuoteOriginally posted by AtitG Quote
I'm interested too
06-17-2016, 02:36 PM   #464
mee
Hi everyone,
Cheers
Thank you for taking the time to test this DA. I'm curious about the performance though -- is it quick to focus on the K-1? Is it loud?
06-20-2016, 04:46 PM - 1 Like   #465
QuoteOriginally posted by mee Quote
I found the performance of the lens (focus, noise, sharpness) to be reasonable, particularly given the price point, which was just under $200 CDN new.
---------- Post added 06-20-16 at 05:51 PM ----------
I actually returned the lens, so I had to look through the test shots I took to discern corner sharpness. Based on the shots I have on file, I don't see much in discernible sharpness loss on the corners in FF, particularly at the lower apertures.
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 10:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
