DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
06-19-2017, 08:38 AM   #496
UncleVanya's Avatar
QuoteOriginally posted by jbondo Quote
I just realized I forgot to post this here.
It's the very carefully controlled and processed series of before and after vignette shots of the DA* 60-250mm F4 ED [IF] SDM rear baffle mod. Hopefully it's the definitive series for anyone with questions.
Also... not shown is that I also did another series with no rear baffle at all. Those results were indistinguishable from the modded configuration so I didn't include them.
As far as sharpness and aberration control goes, it does deteriorate a little (especially CA) at the edges, but overall, perfectly usable.
Did you do tests at multiple focal lengths? I couldn't tell looking quickly at the site.
06-19-2017, 03:40 PM - 1 Like   #497
Loyal Site Supportaxian
jbondo's Avatar
All tests were done to produce the maximum vignette, which happened to be infinity focus at 250mm. So the photos you see are the absolute worst case you will encounter. It was actually much better at shorter focal lengths and at closer focus. Sorry, I didn't take any "best case" photos. The reasoning being that I didn't want to get anyone over optimistic about what to expect. I figured worst case was the way to go.
09-04-2017, 06:25 PM - 5 Likes   #498
Scorpio71GR's Avatar
DA*60-250 on the K-1 with modified baffle I 3D printed. The first set are the 60-250 and the second set are the Tamron 70-200 both on the K-1. The Tamron is included for comparison.
60-250 60mm F4
60-250 135mm F4
60-250 250mm F4
Tamron 70-200 70mm F2.8
Tamron 70-200 130mm F2.8
Tamron 70-200 200mm F2.8
These are the two baffles I made along with the original. I used the one with the cutout.
In the lens before I painted it.
09-15-2017, 08:26 PM   #499
DA 16-45mm, 1:1 mode, no hood
smc PENTAX-DA 16-45mm F4 | Sean Teng | Flickr
09-16-2017, 11:35 AM - 1 Like   #500
PiotrKrochmal's Avatar
K1 DA* 55 1.4@1.4 it is great lens. AF work nice but sloow. I make direct comparison Canon 6D + ART 50mm 1.4 and K1 + 55mm and canon AF beat K1 as boofed Rick.
Picture is uncropped to show how huch vignette there is:
04-08-2018, 10:26 PM   #501
If the DA 35mm AL works on full frame, I wonder if the DA 50mm 1.8 would as well? Anyone try it yet?
04-09-2018, 12:42 AM   #502
Sandy Hancock's Avatar
Yes, I gather that the DA50/1.8 "works" on full frame. It covers the 36x24 frame, but with significant loss of light and image quality in the corners.
Whether or not that is considered to be acceptable is a matter of opinion.
06-08-2018, 04:38 AM   #503
Anyone have experience with the limited 20-40mm on full frame (film). Trying to figure out a travel.kit using K-70 plus a film camera (such as Pentax ZX) with minimal lenses. It looks like there is some small blockage on lengths of 24mm and wider, and no AF, but otherwise it seems to function fine, including focus confirmation. I haven't developed a roll yet and am wondering what to expect.
07-08-2018, 11:48 AM   #504
angerdan's Avatar
With the FF K-1 approaching, new official data about FF compatibility of DA lenses starts to trickle in.
According to Full Frame by PENTAX | RICOH IMAGING (fetched today Xmas 2015 Dec 25), the following lenses support the FF image circle:
- DA* 55/1.4
- DA* 300/4
- DA* 560/5.6
DA* 55mm cover the 35mm image circle, but isn't officially listed for 24x36 compatibility (because the lens hood has to be slightly modificated)
DA* 200mm is officially FF
All DA primes longer than 35mm are usable on FF
07-12-2018, 06:52 PM   #505
QuoteOriginally posted by angerdan Quote
Would you know what those modifications need to be?
07-13-2018, 09:09 AM   #506
angerdan's Avatar
QuoteOriginally posted by dreyes Quote
The outer cover can be removed and then the inner hood can be slightly shortened. After that the outer cover can be mounted without any visible change besides the shorter hood.
07-13-2018, 09:18 AM   #507
UncleVanya's Avatar
By "outer cover" are you talking about the rubber on the hood at he end?
By "inner hood" you mean the plastic part inside this rubber?
Do you know how much needs to be taken off?
07-13-2018, 02:15 PM   #508
angerdan's Avatar
Exactly. I'd only read about it by a forum member who did it.
07-15-2018, 05:30 AM - 1 Like   #509
I purchased a universal 58mm petal hood that works very well. If you want to modify a hood you can buy a hood for the DA 55-300. They have the same mounting style. Then you can shorten that hood back till it no longer causes vignetting. The hood for the DA*55 is difficult to find and expensive. I really do not recommend modifying it, especially if you still plan on using it on ASP-C.
07-15-2018, 08:06 AM   #510
angerdan's Avatar
$38 for the original DA* 55mm PH-RBH58:
Pentax (PH-RBH58,38764 ) | eBay)
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 10:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
