DA lenses on Full Frame: Test Shots thread
Posted By: falconeye, 07-07-2008, 02:50 PM
Hi everybody,
I would like to open up a thread dedicated to one topic:
DA lens on Full Frame: a sticky test shots thread.
This thread shall be dedicated to test shots of a DA lens mounted to a full frame body (e.g., a film camera body). By test shot, I mean shots dedicated to evaluate the performance. Shots of ordinary subjects aren't suitable to this task, normally, and should not be posted. So, these are the rules:
  • K mount lens dedicated to the APS-C form factor is used.
  • Image is taken full frame 36mm x 24mm.
  • Lens hood was removed.
  • And ideally, no filter is mounted.
  • The aperture used is specified (note that film cameras don't record EXIF...).
  • Sample image shows the entire field of view.
  • Sample image(s) show(s) corner, border and center performance at 10MP-100% (multiple crops, or single not-resized image).
  • The subject is such that resolution and vignetting at the borders can be compared to the center.
The idea behind this thread is obvious: To compile enough data to assess the spectrum of available lenses for a forthcoming full frame DSLR in K mount.
Table of results as obtained in this thread (updated regularly):
SMC Pentax-DA primes...
SMC Pentax-DA zooms...
Sigma K mount DC...
  • Sigma 18-200mm f/3.5-6.3 DC: -
  • Sigma 10-20mm f/4-5.6 DC: - (below 14mm, Gooshin)
Tamron K mount Di-II...
Overall rating scale:
+++: no significant difference between APS-C and FF corners
++: difference but usable at full aperture with a small loss in corner IQ only
+: usable staring at f/4~f/5.6, with no or a small loss in corner IQ only
o: usable at f/11 or with big loss in corner IQ only
-: not usable
02-10-2009, 07:22 PM   #91
Class A's Avatar
Note that 3000 LW/PH is the K20D sensor's resolution.
How did you calculate that?
The K20D's sensor has 3104 visible vertical pixels.
I'm assuming that 3000 LW/PH means that 3000 line widths are resolved across the vertical length of the picture with a 50% loss of relative contrast.
I'm further assuming that 1.3 x the number of line widths will cause a contrast loss of 50%. If I see 1.3 N line width through a N line width grid, then each grid line blurs 1 + 1/3 line widths so the contrast between adjacent grid line widths should be 1/3 : 2/3 = 0.5 (50%).
That would give me 4035 LW/PH but only for a black and white image and assuming that RAW data is evaluated (i.e., omitting any demosaicing).
Due to the bayer array structure of the sensor, the colour resolution will be reduced. The minimum should be 2017 LW/PH but the real LW/PH figure should be somewhere between 2017-4035 values as interpolation can recover information. For instance, for say image positions occupied by red pixels by using information from adjacent green pixels. How much colour resolution can be resolved will depend on the demosaicing algorithm.
All this omits the anti-aliasing filter which will reduce the LW/PH figure.
02-11-2009, 05:00 AM   #92
falconeye's Avatar
Thanks for the insightful comments.
Actually, I just wanted to say that "3104 pixels" and "3000 LW/PH" are close numbers. Contrast doesn't matter much because the iso chart lets you pick the closest line pair you can still distinguish. So, it's rather a 5% contrast figure.
Regarding your 1.3x thought experiment: It would map 4 LW of infinite contrast (2 line pairs) onto 3 pixels showing 1 line pair (2 LW) at 3:1 contrast (or less). In general, you'll get Moiré. You can't get beyond the critical frequency of the Nyquist–Shannon sampling theorem.
On more pratical terms:
If evaluating the iso test chart, take care to not only distinguish the lines, but count them, too (i.e., watch out for Moiré patterns)!
02-19-2009, 03:23 AM   #93
Class A's Avatar
The Nyquist-Shannon sampling theorem states the frequency required (2x highest signal frequency) required in order to allow an exact reconstruction of the signal. I haven't seen a form of it which accounts for an admissable loss in contrast of the signal.
But you are right, in my thought experiment the number of observed lines is less than the actual number of lines which must not happen.
Assuming that actual lines are spaced apart with a distance that is equal to their width then one cannot resolve more LW/PH than the sensor has vertical pixels (and even that requires B&W RAW processing). One could reduce contrast by choosing smaller lines but it would not be admissible to reduce the spacing between the lines accordingly (only by a minute factor, < * 1 / #vertical pixels).
Right, otherwise one may not recognise spurious resolution.
04-06-2009, 02:44 PM   #94
Gooshin's Avatar
adding to the database...
this is the Pentax 10-17 FE at 10mm on a pentax MZ-S
04-06-2009, 04:31 PM   #95
falconeye's Avatar
QuoteOriginally posted by Gooshin Quote
Thanks, this is a nice and welcomed addition.
Cf. post #59 (https://www.pentaxforums.com/forums/344170-post59.html) which lacked an image.
Looks like there would be a lot of extra image exposed w/o the lens hood
Post #61 showed the effect for a Tokina 10-17 (https://www.pentaxforums.com/forums/345566-post61.html).
Is the lens hood of the Pentax DA 10-17 FE removable?
04-06-2009, 08:34 PM   #96
nope... but some people have sawed it off
04-07-2009, 10:29 AM   #97
Gooshin's Avatar
as Simon pointed out, if you are good with delicate tools, its doable.
05-07-2009, 06:20 PM   #98
eyou's Avatar
so any news on the latest DA lenses? (DA* 55, DA* 60-250, DA limited 15)
05-08-2009, 12:34 AM   #99
falconeye's Avatar
Thanks to Steelski post #86, I think we know that the DA*55 doesn't vignette and may have a lens hood made for FF. Seems to be a "+" or better. Not much else yet.
No news for the other two lenses. I don't expect the DA15 to be FF capable. Too small. But I don't actually know.
05-11-2009, 03:15 PM   #100
falconeye's Avatar
According to Asahiflex and this post:
https://www.pentaxforums.com/forums/591340-post13.html
the DA* 60-250 mm is a full frame lens.
07-24-2009, 10:30 AM   #101
DA*55 1.4
07-24-2009, 11:51 AM   #102
kristoffon's Avatar
QuoteOriginally posted by k100d Quote
DA*55 1.4
Is that vignetting or just uneven lighting? Hard to tell.
07-25-2009, 12:26 PM   #103
QuoteOriginally posted by kristoffon Quote
i realized after that it wasn't the best sample shot, i was trying to see what it looked like wide open more than anything else. i believe in the top left corner, the image is still fairly bright, so the amount of vignetting should be acceptable.
i had to use Tv mode and MF on my MZ-S to force it to shoot wide open.
08-15-2009, 12:33 AM   #104
emr
Guest
Boris Liberman has produced great examples of DA lenses on full frame, as you all probably know. Now what I'd like to know is what is it that causes the strangely shaped vigneting at DA 10-17mm fisheye's wide end? http://liberman-family.com/boris/da_on_film/DA10_17_10_220.jpg Is it due to the lens's internal structures or does it come partially from the hood?
08-18-2009, 08:16 AM   #105
Gooshin's Avatar
QuoteOriginally posted by emr Quote
its from the hood.
if you remove the hood you get a full circle
60-250mm, aperture, bodies, body, camera, corner, da, da*, da* 60-250mm, f2.8, f4, ff, film, flickr, focus, frame, k-mount, lens, lenses, op, pentax, pentax lens, pm, post, sdm, sensor, shots, slr lens, tests, thread
DA Lenses on Full Frame (DA 35 ltd) Painter Pentax Full Frame 18 05-29-2016 04:42 PM
DA lenses on Full Frame hjoseph7 Pentax SLR Lens Discussion 6 12-03-2014 01:14 PM
TEST: smc PENTAX DA 35mm 2.8 Macro Limited on Full Frame vjacesslav Pentax SLR Lens Discussion 2 03-17-2012 06:41 AM
DA lenses on Full Frame: Test Shots falconeye Pentax Lens Articles 0 07-07-2008 02:50 PM
DA lenses on full frame sensor ZigDaPig Pentax DSLR Discussion 16 01-05-2008 11:22 AM
All times are GMT -7. The time now is 01:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
