5 Likes  #1
How & Why Sensor Size Affects Image Quality (APS-C vs FF vs compact)
Posted By: Adam, 06-20-2013, 04:08 PM
Today I wanted to write an article that shows how sensor size affects image quality at a very high level. I'll start by saying that while my results are informal and not perfectly-controlled in every aspect (the ideal test would include 3 cameras with the same number of megapixels), I've tried to eliminate as many inconsistencies as possible in hope that my conclusions will generally be valid. In the remarks to follow, image quality from a compact camera (represented by the Pentax Q7), an APS-C camera (represented by the Pentax K-50), and a full-frame camera (represented by the Nikon D800) will be compared.
I've done the following to reduce the number of confounding factors:
  • All 3 cameras are of the same generation (current models as of the time this post was written)
  • All 3 cameras were using consumer-grade zoom lenses (02 zoom, Sigma 17-70mm F2.8-4 "C", Nikon 24-120mm F4)
  • All photos were taken in aperture priority mode near the sharpest aperture setting
  • All photos were taken at focal lengths delivering virtually the same horizontal field of view (Q7 = 10mm, K-50 = 34mm, D800 = 50mm)
  • All photos were shot at default settings in JPEG mode
  • No post-processing was applied except for monochromatic auto-levels in order to suppress differences in color
    to allow you to focus on differences in detail and dynamic range
  • All images are losslessly compressed (.PNG format)
  • All images were shot at the same sensitivity (ISO)
So, without further ado, here we go.
Everybody says that the bigger the sensor a camera has, the better the image quality. But why is this? Clearly, larger sensors have an advantage in terms of overall surface area. The additional area lets sensor manufacturers improve the sensor in two respects: the size of individual pixels (pixel pitch or pixel area), and the overall number of pixels (resolution).
  1. The bigger the pixel pitch of a sensor, the higher the signal-to-noise ratio. This leads to better color reproduction, detail, and dynamic range as the color values that pixels record will be closer to the true color values.
  2. The higher the resolution, the better the overall clarity. Because most photos are scaled to a smaller size before being printed or displayed, the extra pixels can be used to suppress much of the noise that was found in the original image that was recorded.
Let's look at a few different sensors to compare pixel pitch and resolution:
Camera FormatSensor Area (sq. mm) Resolution (megapixels) Pixel Pitch (micrometers) Pixel Density (megapixels / sq. cm)
Pentax 645DMedium145240.06.02.8
Nikon D800FF86136.34.84.9
Nikon D600FF86124.35.92.8
Nikon D4FF86016.27.31.9
Nikon D7100APS-C36624.03.96.6
Pentax K-50APS-C37116.34.84.4
Pentax Q71/1.7"4312.41.929.3
Pentax Q1/2.3"28.512.41.543.4
Manufacturer-specific/generational hardware differences aside, if we shoot with take the Pentax K-50 and Nikon D800 side-by-side, we should observe very similar levels of overall noise. However, since the D800 has twice the resolution of the K-50, once its files are scaled to a 16-megapixel size, they will appear to have significantly less noise and therefore more clarity. On the other hand, if we took the same photo with the K-50 and the D4, the original file from the D4 should have much less noise due to the fact that its pixels are physically much larger. You can make further comparisons on your own using the data in the table above. Notice how big of a jump 1/1.7" to APS-C is compared to APS-C to FF in terms of sensor area. This jump is of course correlated to the respective difference in image quality.
So why is pixel pitch, resolution, and signal-to-noise ratio such a big deal? The short answer is that if we have low noise, more of the data recorded by the sensor is accurate, and so the overall image is clearer. Similarly, if we have more resolution, we have more room for error in the original image because we can make up for it when scaling photos.
But I want to take my explanation a little bit further than that. Having a background in computing, I have personally implemented and worked with a host of image processing algorithms, including the algorithms that convert raw sensor data to generate full color images. This has given me a great deal of insight into a number of things concerning how images are generated and enhanced. The big issue at hand is that color digital image sensors only record a fraction of the color data (light) that they are trying to portray. Each pixel on a color sensor is only sensitive to one of three color channels: red, green, or blue. Most sensors today are designed using a Bayer pattern, which uniformly lays out the pixels in a checker pattern consisting of 50% green pixels, 25% red pixels, and 25% blue pixel (because green light is the most abundant). Thus, after the sensor captures an image, at each individual pixel location, a computer algorithm has to try to calculate (a.k.a. guess with high accuracy) the intensity of the two missing color channels (this is known as demosaicing). Demosaicing techniques generally work by analyzing the neighbors of each pixel and calculating missing color intensity values based on the intensities found at neighboring locations. But what if the neighboring intensities are not accurate due to noise? The short answer is that the effectiveness of demosaicing drops dramatically, as the guesses about the missing two color channels could be bad or even flat-out wrong. This is what leads to significant loss of edge detail and color noise. If we have a lot of pixels in an image, the probability of having a good guess within any given area is high, and that's why scaling (downsampling) reduces the apparent noise. Similarly, if we have low overall noise to begin with, the original representation of detail and color will be accurate, so we will not need to do any (or as much) downsampling to get a good image.
And this brings us back to sensor sizes. If we have a very large sensor, its tolerance to noise will be higher, either due to higher resolution or due to increased pixel pitch. This, together with the precision of the optics that deliver light to the sensor, is what ultimately dictates image quality. So, when you go to choose a camera & sensor format, the main question you have to ask yourself, as least as far as image quality goes, is when is the difference big enough to warrant a larger sensor size and is my lens good enough.
To help answer this question, I have prepared a number of test photos. Here is the same scene shot with the D800 (FF), K-50 (APS-C), and Q7 (1/1.7" compact size):
1.
2.
3.
Can you guess which is which? It's probably going to be very difficult to tell a difference between the D800 and the K-50 shots, though you might be able to spot a little less detail in the Q7 shot, even at this web resolution. The answer is found in gray below.
#1 is from the K-50, #2 is from the Q7, and #3 is from the D800.
Now, let's zoom by about 2x.
1.
2.
3.
Is the difference more discernible spot now? It should be, but try to guess again!
#1 is from the K-50, #2 is from the D800, and #3 is from the Q7.
Finally, let's zoom in to the limit of the Q7's resolution
1.
2.
3.
Here, it should be obvious that the first photo is from the D800 while the last is from the Q7. The larger the sensor, the better the colors and the more detail you see.
All the photos above were taken at each camera's lowest sensitivity setting, meaning that their respective image quality was at its absolute best. But what happens as you crank up the ISO? Read on for some examples.
06-20-2013, 04:08 PM - 4 Likes   #2
1. Q7 at ISO 400 (100% crop)
2. K-50 at ISO 400 (scaled to match)
3. D800 at ISO 400 (scaled to match)
As the sensitivity goes up, the visible difference between the three photos does as well. Here, the Q7 has a good amount of noise, the K-50 image has very little, and the D800 image has almost none.
1. Q7 at ISO 6400 (100% crop)
2. K-50 at ISO 6400 (scaled to match)
3. D800 at ISO 6400 (scaled to match)
When we increase the sensitivity by a factor of eight, the smaller sensors start to suffer. Here, the Q7 has lost all fine detail, the K-50 shows more detail but also more noise, and the D800 preserves almost all detail though with a very visible layer of grain.
I hope this article gave you some valuable insight into image quality, at least from the perspective of image sensors themselves. I've only brushed the surface as far as technicality goes, and there are of course many other factors that will ultimately affect what camera you decide to get, such as quality of lenses, price, and handling
Here's my personal advice that I'd like to share with you guys. If you're a photographer that's interested in publishing mostly web-sized photos, you will likely be just fine using a smaller-format camera such as 1/1.7" or 1". If you plan on doing a lot of cropping, making big prints, or if you demand good high-ISO performance, APS-C or MFT is where you'll want to be. If you're a professional that needs consistently-high output or an enthusiast that craves high-definition files, then you should go beyond APS-C. Remember, also, that the bigger the sensor, the more it costs, and the bigger the size & cost of your whole system will be. Using cheap lenses with good sensors is worse than using good lenses on poor sensors.
Perhaps later on I will write an article on moire, as its presence is also affected by how demosaicing works.
06-20-2013, 04:30 PM   #3
LFLee's Avatar
Didn't know D800 ISO can goes up to ISO 66400 ! kidding!
Beside this image quality, there are other things that larger sensor is at advantage.
Thanks for putting this together!
06-20-2013, 06:12 PM   #4
Thanks for taking the time to put this together, and to write this up!
06-20-2013, 06:47 PM   #5
Aristophanes's Avatar
At 400ISO the APS-C K-50 sensor does very, very well vis-a-vis the Nikon D800. I suspect that up to 1600 the K-50 sensor holds it own in most lighting situations. The Q (in very good available light nonetheless) doesn't do well at all; it's a P&S sensor, after all. No surprises. overall. Thanks for the testing.
06-20-2013, 06:58 PM   #6
calsan's Avatar
I'd like to know how the Q and K50 stack up in a hand held real world situation. These are on tripods in daylight, so no surprise that the bigger sensor wins.
However, say you're shooting a group of people in poor light and for whatever reason, you forgot or don't want to use a flash.
With the larger cameras you need to stop down to get enough depth of field (More so with the 135 format than the APS. With the Q, no need to stop down, so you can shoot wide open and therefore avoid higher ISOs. I'd like to see the results in that situation. I'd imagine the larger sensor benefit becomes less certain!
06-20-2013, 07:28 PM   #7
hcc
hcc's Avatar
Thank you for sharing your thoughts, Adam. This is very valuable and you use a set of settings that are very clear.
Thanks again.
06-22-2013, 11:49 AM - 1 Like   #8
Opethian's Avatar
And there you have it Pentax. The article that will forever be referred to when the topic of FF is discussed.
06-22-2013, 11:55 AM   #9
LaurenOE's Avatar
Cool.
06-22-2013, 02:07 PM   #10
normhead's Avatar
Thanks Adam, I was hoping the the Q7 would be good enough for birding.... imagine a Q7 and adapter and A-400 giving you almost 1800mm equivalent on a very small package...like the lens really.
Only by people who don't understand how much not using all 12 MP sensors on all formats skewed the results. A test of a K-x a Q7 and a D700 would have been a better test, all 12 MP. But then, I wouldn't have found out that trying to use a Q7, a K-adapter and my A-400 isn't going to give me the feather detail I want. In fact given the title of the thread, I'd have to say the comparison of these three cameras is unfortunate. Comparing a 12 MP small sensor, a 16 MP APS-c and a 36 MP FF is extremely problematic, and that can't be emphasized enough.
Comparing a Q-5 K-5 IIs, a Merril DP2, D7100 and and a D600, @ 100, 800 and 3200 ISO, now that would have been awesome. But full marks to Adam for doing what he could with what he had.
06-22-2013, 02:41 PM   #11
jct us101's Avatar
So then why does my Olympus E-P1, Pentax K-x, and Canon 5D all show the same amount of sharpness and detail even at 100%?
Trust me, I've tested them.
06-22-2013, 03:19 PM   #12
QuoteOriginally posted by jct us101 Quote
The Canon 5D is 4 years older than the K-x and E-P1. The sensor tech has to be roughly of same generation, otherwise you'd be comparing apples to oranges.
06-22-2013, 03:56 PM   #13
Big Dave's Avatar
Thanks Adam for an excellent comparison. The advantages of full frame aren't realized by most users. For those interested, there is an excellent article on the Ken Rockwell forum also. The Full-Frame Advantage I personally am impressed with my full frame Canon 5D performance. It is a pleasure to use.
06-22-2013, 04:24 PM   #14
normhead's Avatar
QuoteOriginally posted by Big Dave Quote
That has to be a troll, good one....
You mean this article?
D40 and its kit lens or my 18-200mm VR 90% of the time for my photos that matter. In the few rare cases that something will sit around and wait for me, I'll pull out my klunky Canon 5D or 4x5" view camera.
You mean this Ken Rockwell?
Good for a...
06-22-2013, 04:53 PM   #15
rayallen's Avatar
Do people actually still read what Ken Rockwell says?
color, d800, image, k-50, noise, pixel, pixels, quality, resolution, sensor
Image size vs quality m112 Pentax K-30 & K-50 7 02-18-2013 08:52 AM
Quick question regarding field of view - FF vs APS-C glass? Julie Pentax SLR Lens Discussion 5 12-23-2012 05:33 PM
Effect of Lenses designed for FF vs APS-C sensors atnbirdie Pentax DSLR Discussion 17 02-10-2012 09:23 AM
APS-C vs FF format mika. Pentax DSLR Discussion 270 01-22-2012 12:18 PM
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
All times are GMT -7. The time now is 12:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
