05-02-2010, 09:39 AM   #1
newbie with RAW question?
Hi, I recently bought a Pentax K-X having previously used a Nikon compact.Just returned from Cyprus holiday and downloaded jpeg images to computer with no problem but RAW images were not recognised by the Nikon software of by Photoshop CS2. or by Pentax Utility software.
For many years I have been in to SLR work but this digital stuff is way over my head. Any help appreciated.
05-02-2010, 09:52 AM   #2
SpecialK's Avatar
Well, Nikon probably won't recognize Pentax files.
Your CS2 is (I think) a little older, so you should get the latest Adobe Camera Raw (ACR) download. I had to to that with Elements for it to recognize the K20D. In Elements, you just put it in the "plugins" folder.
Make sure you click "show Pentax files" or similar option in the "View" menu of the Pentax software.
Fastone image viewer and editor (free) also recognizes PEFs. I put it on my netbook for travel viewing and storage.
05-02-2010, 10:28 AM   #3
QuoteOriginally posted by leolyd Quote
I assume you used PEF over DNG formated files?
There is (almost) no RAW standard for file storage.
All manufactures use their own format, even each single camera uses small deviations on those file formats.
It is a hell of a job for the software suppliers to keep up with all the new cams and have their s/w to support the flow of new hardware.
The more or less standard RAW format is DNG (Digital Negative) from Adobe.
Your camera can use that! You'll have more chance of being compatible with software usinh DNG!
As specialK said, look for the CS2 updates.
That the Nikon s/w does not recognize recognize anything but Nikon RAW format's seems logical to me.
The Pentax utilities should be able to handle PEF files correctly, I do not understand what goes wrong there.
With older Pentax camera's the compressed DNG format was not supported generating much larger DNG over PEF files. Now (K-7, K-x) it is.
Use DNG over PEF if you can. If you'd ever want to use newer Adobe software like Lightroom 2 or 3, the DNG format makes it also easier to transport edited RAW files.
- Bert
05-02-2010, 12:21 PM   #4
CS2 isn't going to read Kx (or K7) PEF files. You need ACR 5.x or higher and CS2 won't work with it (CS3 doesn't either). If you want to continue using CS2 you can get a converter that will turn your files into DNG files.
I Am a little surprised that you cannot read them with the Pentax software (don't expect it to read the Nikon RAW files though).
05-02-2010, 01:36 PM   #5
Picasa 3 from Google supports Pentax RAW files - and its a free download.
Picasa 3: Free download from Google
You can do cropping and some other light adjustments as well as convert to JPG.
Hope you had a good vacation!!!
05-03-2010, 09:46 AM   #6
Many Thanks!
Just to tender a big 'thank you' to the people who responded so quickly to my query. Just to let you know that, after installing Google Picasa I was able to download all my RAW images. Your help was really appreciated. Cheers guys.
05-04-2010, 01:41 PM   #7
I know this is a bit of a tangent, but can Picasa generate web albums of the kind which you can insert into your own website i.e. a directory structure with index.html at the top?
I have been using the web photo album features in Photoshop but they are crippled; e.g. the large pic is limited to 800 pixels wide.
ISTM that Picasa is intended for generating web albums which are hosted on some google website server, which I don't want.
05-04-2010, 05:06 PM   #8
Wheatfield's Avatar
While CS2 won't work with your PEFs, you can download Adobe's DNG converter which will take your PEFs and conver them to DNG format.
The converted files will then open in CS2.
If you switch your camera over to DNG, they will open in CS2.
05-04-2010, 07:17 PM   #9
If you want to shoot in RAW and use an older version of Adobe's software, just shoot in DNG. The only real benefit to shooting PEF was that the files were a little smaller. Not sure about now, I think Pentax now uses a compressed DNG file that is smaller than the uncompressed ones that they used to use. Anyway, don't hesitate to shoot with DNG.
05-06-2010, 05:06 AM   #10
QuoteOriginally posted by peterh337 Quote
You CAN use Picasa to:
- Improve / edit / alter your photos
- Catalog and store your photos
- Upload to picasaweb web albums.
- Mail photos
- Form albums
- Group by people (recognition done by Picasa)
- Export as JPEG
- Print photos using a wide variety of commerical services
- Create collages, screen savers, wall papers etc.
No, Picasa is not intended to generate a webalbum.
It just is one of its many features.
Picasaweb webalbums can contain pictures with a maximum resolution of 1600 pixels.
You can upload to other websites / albums as well.
- Bert
05-07-2010, 01:39 PM   #11
Sorry - could you clarify?
Do you mean it is NOT one of its many features?
05-07-2010, 01:43 PM   #12
It IS integrated well with Picasaweb, one of the features I mentioned.
It is just one of the many features.
You can perfectly well use Picasa without Picasaweb, just try it, it is free.
- Bert
05-07-2010, 02:16 PM   #13
Ecaterin's Avatar
Yes, it does. There are a few basic templates in Picasa, and then quite a few plugins have been written and most of them do a gorgeous job. You just let Picasa generate the code, then FTP the whole folder structure of the HTML output onto your server
It's dead simple: in Picasa go to 'folder' then 'export as HTML' If you need detailed directions, there's lots of them on the internets
A webpage full of free templates to use if you want fancy stuff :)
05-08-2010, 07:39 AM   #14
Yes, Picasa works quite well for this. A useful addition to the Photoshop photo gallery generator.
Took a little while to find - it is under Export to HTML page
Many thanks.
Interestingly, Picasa doesn't seem to have a feature to force the date stamp from EXIF. This is necessary where images are to be rotated; the rotation changes the date stamp so when one is viewing a folder full of images, one ends up with all the portrait-taken ones at the end. For this reason I continue to use an old copy of ACDSEE.
But ACDSEE is a bit strange in that it does the "lossless Jpeg" rotation in some nonstandard way, and if the rotated image is opened in Photoshop CS3 or later, the rotation is missing. Photoshop 7 would display it correctly.
05-08-2010, 01:50 PM   #15
On a side note ... it was mentioned that .PEFs can't be views in Photoshop CS3 ... this is incorrect. As I can view mine in CS3 (after I downloaded the correct ACR for it.)
I am another fan of Fastone Image Viewer as well ... and it is on my Notebook as well. Love it, works a charm.
camera, images, nikon, pentax, pentax help, photography, software
Raw File format choice (Newbie) holdgaj Troubleshooting and Beginner Help 12 06-10-2009 09:28 PM
newbie question re RAW kleung Digital Processing, Software, and Printing 44 09-08-2008 12:04 AM
Going Raw: Advice for a "raw" newbie krs Digital Processing, Software, and Printing 20 03-31-2008 12:47 PM
another newbie question gokenin Troubleshooting and Beginner Help 3 03-26-2008 07:50 PM
Explain raw to a newbie! xecutech Troubleshooting and Beginner Help 16 01-31-2007 07:15 PM
All times are GMT -7. The time now is 11:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
