Originally posted by eaglem For those that use this Lens for Macro I was wondering if I can get your thoughts on these?
Hi have had both and used both on the 18-55
the answer depends on what you want to achieve. The 250 requires a tripod at all times and has a very very small Depth of field an gives amazing close ups of insects and in my opinion is to much for flowers unless you are a botanist.
excellent for insects BUT I found you rarely get the sort of huge insect eye photos you see posted.
The on 150 on the other hand can be used hand held in some circumstances is brilliant for flowers and will show insects up well but not in huge detail but better than you have probably seen before.
on both I used the clip on attachment on the 55dia lens and on a 49mm dia 50mm prime I use a step down.
as long as the lens dia is smaller than the Raynox then you you don't get the dark corner [ vignette] effect.
I sold the 250 as I rarely used it and it required a specific plan of action to use it and thats not the way I work.
buy a 150 first and use it. after all you you can crop and enlarge if your images are sharp and you get a better D.O.F. to work with.
Alistair
