Originally posted by adwb The Pentax image viewer is as far as I have found the only software that as you cycle through the images retains a magnification you have set. every other one I have tried [like picassa /all adobe versions,/rawtherapee ect.] if you select to view at 100% it reverts back at the next image. Thats a pain if you have several shots of the same subject and you are looking for the sharpest one.
Alistair
I agree, great feature. Also it stays zoomed in on the same area of the photos as you cycle through. So if you're looking at one corner at 100%, it keeps that corner in the screen. The other thing I love about it is that you can pop up two photos to compare. Not every browser allows this. And it displays your raw photos with the camera settings, allowing you to use the same controls as your camera (e.g. you shoot a portrait in Bright Image tone, and it lets you create a jpeg in Portrait tone). All of the camera settings are available and any one can be diretly manipulated. But the main thing is still the richness of the raw conversion. I sent a raw conversion of some lillies to a friend using Pentax Photo Browser, Picasa and PhotoShop CS3. He could see the difference right away. It's like I had a better lens on the camera.
My work flow has become very very quick. I convert in DCR4 and make minor any minor adjustments to the jpeg in Picasa. If Paint Shop Pro works out, it will replace Picasa, not the Pentax software.
