Originally posted by bfo Well.
With the aforementioned settings (flash+1/180)=very over exposed. Thats the problem basically....
Exposure in flash photography has almost nothing to do with shutter speed, since the duration of the flash itself is *much* shorter than the shutter speed. The way you get dark exposure is by stopping down the lens. Google the term "flash guide number formula" for descriptions of how one calculates what aperture to use for any given distance to subject. You'll see shutter speed doesn't enter into it.
This is only necessary when using manual lenses, since these cause the flash to fire full power. With modern lenses, the camera can control the flash output, allowing you to get correct exposures at any aperture (within reason).
Quote: And I don't get why 1/180 is the fastest shutterspeed available either.
Google the phrase "flash sync speed" for an explanation of why cameras have a maximum shutter speed that can be used with flash.
Quote: Anayway, it has a low/min setting. Maybe that will help?
It will, as that will lower the guide number you'll plug into the guide number formula, allowing to shoot with a larger aperture if you so desire.
