Originally posted by hockmasm I especially liked how he explained that different apertures cause CERTAIN COLOURS to change....what a concept! Like, aperture 22 will cause yellow to look different from aperture 5.6. One makes it dark and muddy while the other crisp and bright.
OK found it on page 60 through 63 , as you correctly said he talks about the effect that different apertures have on certain colours. essentially all he is saying is that if you over or underexpose a image there will be shift in the hue of a colour which is obvious.What he is however pointing out is that this affect some colours more than others yellow being a good example as it will go from a shade of yellow to a ochre if underexposed enough while other colours may not have such a severe reaction.
As this is a book on how to try to get the best exposure with out resorting to hours of PP it a valid point to make , as compensation for a given light situation may rectify the overall exposure but can have side effects.
There are some images to demonstrate this and if they certainly do show how you need to be aware of this phenomenon.
General under exposing darkens and allows recovery later when very often over exposure is not as recoverable.
take three images one 2 stops under; one normal ;and one 2 stops over , you will get the two stops under back to normal most times but often won't with the 2 stops over, IMHO.
Alistair
