05-12-2010, 04:55 AM   #1
K7 external flash
Hello
I'm buying very soon K7 kit
I have had Fuj s602 'n SunPak auto 3075g.
The SunPak has 197 VDC trigger voltage IIRC.
Too high, I think, so solution is optoisolator or wireless trigger ?
Maybe new flash would still be the best solution: Sigma EF-530 DG Super is my mind for my budjet range flashes.
05-12-2010, 07:02 AM   #2
QuoteOriginally posted by DonX Quote
Hello
Welcome to the club.. Personally I would not mount a 197 volt flash on a modern camera without some protection. You can buy a device made by Wein that will keep the camera end of the trigger voltage at 6 volts. Last time I looked they were pretty expensive, like in the $50 range. At that point, you're well on your way towards the cost of a new flash. I don't have any experience with the Sigma flashes, only Pentax (for wireless), but it is a much better solution than trying to rig something to work.
05-12-2010, 09:16 AM   #3
Just1MoreDave's Avatar
This thread and the web site it points to cover all the possible P-TTL flashes:
https://www.pentaxforums.com/forums/camera-studio-accessories/43215-pentax-p-...omparison.html
Unless there is something really great about the older flashes you have, it is usually cheaper to find an equivalent flash with a safe voltage than isolate the higher voltage.
I bought the Pentax AF540FGZ for my K-7. It's not a budget solution. I like having the compatibility worked out already.
camera, flash, k7, pentax help, photography, solution, sunpak
Do you use an external flash? rustynail925 Flashes, Lighting, and Studio 23 02-28-2010 07:21 AM
need help with my external flash Death2man Flashes, Lighting, and Studio 2 01-17-2010 01:17 AM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
external flash with k-x grakenverb Pentax DSLR Discussion 3 12-25-2009 05:25 PM
Best external flash for the k-7 alman Flashes, Lighting, and Studio 9 07-23-2009 02:54 AM
All times are GMT -7. The time now is 06:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
